Good starter that will work with an Indy Maxx block.... #335094
06/01/09 11:18 AM
06/01/09 11:18 AM
Oklahoma
silverfish Offline OP
Oklahoma
I know everybody seems to have great luck with a factory mini starter and it will work with an Indy block but for some reason I don't have any luck at all. Another one broke this weekend. What other options are there for a good starter that will crank when I need it to? I have a 540" motor with an Indy alum block that has the extra ribs. 14:1 compression. The RobbMc won't work because of the extra ribs on the alum block, already tried it. Every Mopar mini starter I've tried will fit but it seems to die shortly after installation. Any other suggestions??? Anyone have any experience with the Powermaster XS starters?
Re: Good starter that will work with an Indy Maxx block.... [Re: silverfish] #335095
06/01/09 11:49 AM
06/01/09 11:49 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I used the Factory Mini starter on the almost same engine. Mine was 557 CID, which was a 4.44 bore x 4.5 stroke. Compression was measured at 15.5:1 which I ran with alky injection.
No problems at all.
Re: Good starter that will work with an Indy Maxx block.... [Re: silverfish] #335096
06/01/09 12:20 PM
06/01/09 12:20 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
Just an idea? Starter just a bit of? Not lined
up with fly wheel? To much heat by the starter?
I don't think powermaster will be any better.
The 440 source starters are just as good.
You could try the MSD starter, or the Meziere.
If that doesn't work, then something isn't
lined up right or it's a heat problem.
Snap your neck, mega G-force launch, is all I want!
Re: Good starter that will work with an Indy Maxx block.... [Re: BDS871Cuda] #335097
06/01/09 12:25 PM
06/01/09 12:25 PM
Barboursville, VA
belvedere383 Offline
Barboursville, VA
i have powermaster xs on a 13:1 500 inch motor, it seems to work awesome. The powermaster starters to me look alot beefier but who knows.
65' Belvedere
496'' Stroker
Indy Heads
Re: Good starter that will work with an Indy Maxx block.... [Re: belvedere383] #335098
06/01/09 12:31 PM
06/01/09 12:31 PM
I use a MSD starter on my Indy alloy motor, works great, also Meiserie works well..I had no luck with the powermaster or the factory stuff...
Re: Good starter that will work with an Indy Maxx block.... #335099
06/01/09 01:31 PM
06/01/09 01:31 PM
Oklahoma
Oklahoma
I checked and double checked the alignment several times and everything checks good. I use a powerglide with an ultrabell and I thought maybe there is something not machined right in the bellhousing??? I don't know. The flywheel looked good when we had the motor out last time, I always inspect the teeth on it everytime the motor is out. Like I said I just don't know. There are so many people that say they just use the mopar factory mini starters and never have problems but I've had problems on the last two motors with them.
Post deleted by Defbob [Re: silverfish] #335100
06/01/09 02:15 PM
06/01/09 02:15 PM
Re: Good starter that will work with an Indy Maxx block.... #335101
06/01/09 05:50 PM
06/01/09 05:50 PM
MEZIERE TS 104,best starter you will ever buy hands down.
those powermasters wont help you,
mezieres spin like youve never seen a starter spin before.
also double check your ring gear to bendix contact point and double check your timing.
Re: Good starter that will work with an Indy Maxx block.... #335102
06/01/09 05:56 PM
06/01/09 05:56 PM
Oklahoma
Oklahoma
is it bottoming out on full engagement?
JW's also have been known to be off center and need alighment
I think that it is a JW so I will check all that real close this evening when I get home. How do you align them and get them correct if they are off?
Re: Good starter that will work with an Indy Maxx block.... [Re: silverfish] #335103
06/01/09 09:55 PM
06/01/09 09:55 PM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
Not all mini starters are made the same, check with a dealer. I do have a mini, works fine, but my dealer buddy picked out a specific one.
Also, an 80's 318 starter is 1/2 way between a mini and a 60's full size starter size wise.
Hope this helps.
8.30's @3400 lbs
Re: Good starter that will work with an Indy Maxx block.... [Re: Mike Swann] #335104
06/01/09 10:59 PM
06/01/09 10:59 PM
San Diego, CA
brktracr Offline
super street
brktracr  Offline
super street
San Diego, CA
I too was breaking the Mopar mini starters, went with a Powermaster XS and haven't had a problem in 5 years now. The Meziere starter is an very excellent piece also.
1.298 60 ft 6.001 1/8 mile 114 mph 9.52 1/4 mile 140.87 mph @ 3110 lbs
Re: Good starter that will work with an Indy Maxx block.... [Re: brktracr] #335105
06/01/09 11:14 PM
06/01/09 11:14 PM
Oklahoma
Oklahoma
Ok I put the car on jackstands to check everything out. It is all lined up perfectly. The wear marks on the flywheel where the starter gear is making contact with it are just right also. What I found is just what I expected, the pinion is broken on the starter. You can take a screwdriver and just freewheel it both directions. Thats usually what happens to every one of them. I think I will try the Meziere or Powermaster now. One other thing....does it matter that I am using a Chevy/powerglide flywheel with a mopar starter? Just wondering if the teeth still line up correctly?? Its a JW flywheel with the adapter to bolt to my Mopar crank. Nothing out of the ordinary that anyone else uses when utilizing a powerglide but I thought I would ask to make sure....
Where is the best place to get a Meziere starter?
Re: Good starter that will work with an Indy Maxx block.... [Re: silverfish] #335106
06/01/09 11:24 PM
06/01/09 11:24 PM
Oklahoma
Oklahoma
Are you guys using a start retard? If so how much...10 or 20 degrees?
Post deleted by Defbob [Re: silverfish] #335107
06/02/09 12:20 AM
06/02/09 12:20 AM
Re: Good starter that will work with an Indy Maxx block.... [Re: silverfish] #335108
06/02/09 12:35 AM
06/02/09 12:35 AM
Carson City, Nevada
RobbMc Offline
RobbMc  Offline
Carson City, Nevada
I'm not sure how that works. Chevy 153 and 168 tooth starter ring gears are 12/14 pitch and Mopar 130 and 143 tooth ring gears are 10 pitch. The pinion teeth are not compatible. Unless I am missing something here..........
Designing a better mouse trap always seems to lead to the evolution of smarter mice. www.robbmcperformance.com
Re: Good starter that will work with an Indy Maxx block.... #335109
06/02/09 09:07 AM
06/02/09 09:07 AM
Oklahoma
Oklahoma
no and if you are throw it away it's the reason they are breaking. it causes kickbacks
Well I had a 20 degree retard programmed into it and with this last starter I changed it to a 10 degree retard. I have heard mixed opinions about this issue so I guess I will take the retard completely out now and see how that works for me. Thanks for the info.
Re: Good starter that will work with an Indy Maxx block.... [Re: silverfish] #335110
06/02/09 02:19 PM
06/02/09 02:19 PM
Oklahoma
hemiiroc Offline
hemiiroc  Offline
Oklahoma
Are you spinning the engine then hitting the ignition?
Re: Good starter that will work with an Indy Maxx block.... [Re: hemiiroc] #335111
06/02/09 02:46 PM
06/02/09 02:46 PM
Oklahoma
Oklahoma
Not on this car. My other car is set up like that but this car still has the stock keyswitch in it. Is that harder or easier on the starter? I've always heard its easier on it but not really sure.
Re: Good starter that will work with an Indy Maxx block.... [Re: silverfish] #335112
06/02/09 03:20 PM
06/02/09 03:20 PM
Oklahoma
hemiiroc Offline
hemiiroc  Offline
Oklahoma
Much easier to start.
Re: Good starter that will work with an Indy Maxx block.... [Re: hemiiroc] #335113
06/02/09 03:28 PM
06/02/09 03:28 PM
Oklahoma
Oklahoma
I agree with that for sure. I hope to be able to rewire the Cuda this winter to make it that way also. I don't know if that has contributed to my starter problems or not. I'm gonna order a Meziere, Powermater, or CSR this time...I just can't decide which one to get. There good and bad opinions about all of them.
