'69 Dart grille paint scheme: Which one? #334211
05/31/09 02:35 PM
05/31/09 02:35 PM
Vista, California
ChickMaggot Offline OP
Vista, California
Guys,
I picked up a super straight '69 Dart grille & headlight bezels yesterday.
Problem #1: It was entirely covered in thick gold & orange spray paint.
Problem #2: Solving problem #1 has removed ALL paint from the metal and I can't tell where to apply the new paint.
Searching the net has shown two prominent paint schemes. Which one is correct? Is it dictated by model, build date, etc.?
Gold car?
You can lead a gift horse to water, but you
can't look in his mouth.
Re: '69 Dart grille paint scheme: Which one? [Re: ChickMaggot] #334212
05/31/09 02:36 PM
05/31/09 02:36 PM
Vista, California
Vista, California
Or green car?
Re: '69 Dart grille paint scheme: Which one? [Re: ChickMaggot] #334213
05/31/09 02:41 PM
05/31/09 02:41 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
GTS got the blackout scheme; all others got the non-blackout.
I know there's at least one '69 Swinger with the blackout, last seen in Big Bear, CA around 1979, because I did it, and I'm sure I'm not the only one...
Re: '69 Dart grille paint scheme: Which one? [Re: topside] #334214
05/31/09 03:01 PM
05/31/09 03:01 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
IIRC, It sort of looked like this 69 Western Sport Special had a hood replaced once. But this is an original painted 69 Grill. But not 110% sure it is the grille it left the assembly line with.
Re: '69 Dart grille paint scheme: Which one? [Re: autoxcuda] #334215
05/31/09 03:05 PM
05/31/09 03:05 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
That's the standard scheme right there. Nice closeups.
Re: '69 Dart grille paint scheme: Which one? [Re: autoxcuda] #334216
05/31/09 03:09 PM
05/31/09 03:09 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
It doesn't show up very well, but there is quite a bit of silver painted sections too. The flash is killing the paint lines on the silver paint.
Notice the black paint of top of the grille. It must show through when you look at it. That kind of blackout stuff was almost always done by the factory on purpose for some kind of visual appearance deal.
Re: '69 Dart grille paint scheme: Which one? [Re: topside] #334217
05/31/09 03:20 PM
05/31/09 03:20 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Thanks, I try to take pictures of original stuff like that when you get a chance and remember to. Once it's restored, the infomation is gone forever.
Do you think that green GTS has the correct blackout. Looks like it was restored and got a little over blacked out
To me it looks like the factory had a cutout templete/die to spray the black through. That's why all the edges don't look crisp like a tape masking line. You can see how the templete gets off center just a little and the blackout shifts all to one side in some grilles.
Re: '69 Dart grille paint scheme: Which one? [Re: autoxcuda] #334218
05/31/09 04:52 PM
05/31/09 04:52 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The GTS looks correct to me; there was a narrow perimeter kind of inside the upper & lower halves.
I've noticed the same fuzzy edges on most everything Chrysler (more likely their vendors) masked and added color too, including hubcaps, '68 RR rear Decor panels, and Duster sharktooth grilles.
Re: '69 Dart grille paint scheme: Which one? [Re: topside] #334219
06/01/09 05:57 PM
06/01/09 05:57 PM
Northern BC
Canucklehead Offline
Northern BC
According to the factory parts book, LL, LM and LH cars had the non blackout and the LP and LS had the blackout. I thought the LH cars had it but apparently not.
Re: '69 Dart grille paint scheme: Which one? [Re: Canucklehead] #334220
06/01/09 07:27 PM
06/01/09 07:27 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
GTS and GT got the blackout scheme with two ribs left silver. What model do you have?
JB Rhinehart, Realist
A-Body's RULE!
Re: '69 Dart grille paint scheme: Which one? [Re: Rhinodart] #334221
06/02/09 11:48 AM
06/02/09 11:48 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yup, GT also had blackout; my error stating only GTS.
Re: '69 Dart grille paint scheme: Which one? [Re: topside] #334222
06/03/09 11:57 PM
06/03/09 11:57 PM
capac michigan
MCB Restorations Offline
capac michigan
Here's how we paint the GTS and GT grills. This particular grill our corners are a little to sharp, but the overall scheme is correct for GTS and GT based on what we've done over the years.
Matt @ MCB Metal Restoration www.tuffwheelrestoration.com
Stainless Steel and Aluminum trim restoration by MCB Restorations. We offer show quality trim restoration for all brands but specialize in Mopar. See our website for other examples www.mcbrestorations.com or give us a call at (810) 395-7162
Re: '69 Dart grille paint scheme: Which one? [Re: ChickMaggot] #334223
06/04/09 09:13 AM
06/04/09 09:13 AM
Vista, California
Vista, California
What shade of silver should I use when repainting? It looks pretty light.
Re: '69 Dart grille paint scheme: Which one? [Re: ChickMaggot] #334224
06/04/09 10:24 PM
06/04/09 10:24 PM
Vista, California
Vista, California
