'69 Dart grille paint scheme: Which one?
#334211
05/31/09 02:35 PM
05/31/09 02:35 PM
Posts: 1,612 Vista, California
ChickMaggot
Vista, California
Guys,
I picked up a super straight '69 Dart grille & headlight bezels yesterday.
Problem #1: It was entirely covered in thick gold & orange spray paint.
Problem #2: Solving problem #1 has removed ALL paint from the metal and I can't tell where to apply the new paint.
Searching the net has shown two prominent paint schemes. Which one is correct? Is it dictated by model, build date, etc.?
Gold car?
You can lead a gift horse to water, but you can't look in his mouth.
Re: '69 Dart grille paint scheme: Which one?
[Re: autoxcuda]
#334216
05/31/09 03:09 PM
05/31/09 03:09 PM
Posts: 27,468 So Cal
autoxcuda
So Cal
It doesn't show up very well, but there is quite a bit of silver painted sections too. The flash is killing the paint lines on the silver paint.
Notice the black paint of top of the grille. It must show through when you look at it. That kind of blackout stuff was almost always done by the factory on purpose for some kind of visual appearance deal.
[Re: topside]
#334219
06/01/09 05:57 PM
06/01/09 05:57 PM
Posts: 327 Northern BC
Canucklehead
Northern BC
GTS got the blackout scheme; all others got the non-blackout. I know there's at least one '69 Swinger with the blackout, last seen in Big Bear, CA around 1979, because I did it, and I'm sure I'm not the only one...
According to the factory parts book, LL, LM and LH cars had the non blackout and the LP and LS had the blackout. I thought the LH cars had it but apparently not.
[Re: topside]
#334222
06/03/09 11:57 PM
06/03/09 11:57 PM
Posts: 144 capac michigan
MCB Restorations
capac michigan
Here's how we paint the GTS and GT grills. This particular grill our corners are a little to sharp, but the overall scheme is correct for GTS and GT based on what we've done over the years. Matt @ MCB Metal Restoration www.tuffwheelrestoration.com
Stainless Steel and Aluminum trim restoration by MCB Restorations. We offer show quality trim restoration for all brands but specialize in Mopar. See our website for other examples www.mcbrestorations.com or give us a call at (810) 395-7162
[Re: ChickMaggot]
#334223
06/04/09 09:13 AM
06/04/09 09:13 AM
ChickMaggot
Vista, California
What shade of silver should I use when repainting? It looks pretty light.
