steering box 16:1 or 24:1 #334042
05/31/09 10:01 AM
05/31/09 10:01 AM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
im converting from power to manual steering on the duster.i use a smaller 13" steering wheel.any comments or suggestions on which box to get 16:1 or 24:1 is one easier to turn than the other? .borgeson,steer&gear or flaming river?
Re: steering box 16:1 or 24:1 [Re: mcmopars] #334043
05/31/09 11:26 AM
05/31/09 11:26 AM
The 16:1 will be a bear esp w a 13" steering wheel. I would suggest a 20:1 either a firm feel box or the 20:1 guts from MP & put it into any common 24:1 box. It'd be cheaper & I have not done it but I dont think it'd be difficult. The flaming river one is sealed w no plug to check/add grease/lube which I dont understand/care for. We went from a 24:1(stock)to a 16:1 manual box on our circle track challenger & it was night/day better in the corners,no more hand over hand excessive movement. A buddy has a 16:1 in a BB valiant & he isn't complaining but he rarely drives it. I have a 24:1 in a light 65 dart & I dont like it, too much effort & I am going to change to power!
Re: steering box 16:1 or 24:1 [Re: mcmopars] #334044
05/31/09 11:33 AM
05/31/09 11:33 AM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
I had the 20:1 box (actually the 20:1 sector shaft back when MP sold them) on a 70 Cuda. Manual Steering, 14 or 15" wheel (the basic e-body two-spoke). It was a bear at anything less than a crawl, but GREAT from about 3mph up.
I agree that a 16:1 with a 13 inch wheel will be STIFF.
Re: steering box 16:1 or 24:1 [Re: Pacnorthcuda] #334045
05/31/09 12:15 PM
05/31/09 12:15 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I've got the 20 to 1 in my '66 Charger. Drives pretty good.
Re: steering box 16:1 or 24:1 [Re: bobby66] #334046
05/31/09 01:45 PM
05/31/09 01:45 PM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
so the 24:1 will be easier to turn?that is my big concern that it will be to heavy for street driving.what about if i use a 14 " steering wheel?
Re: steering box 16:1 or 24:1 [Re: mcmopars] #334047
05/31/09 02:06 PM
05/31/09 02:06 PM
germany
440sat72 Offline
440sat72  Offline
germany
i dont know your driving style but i can tell you from my own experience that with a 24:1 box you better pray that you NEVER loose your tail. 5 1/2 turns from lock to lock it's almost impossible to countersteer.
and then, even with 24:1 it is still a bear to steer, parallel parking will make you look like a jerk (at least that's how i felt).
in the end, it's a matter of personal taste. i found it my 24:1 box to be too dangerous and too uncomfortable and went back to power steering. have a firm feel stage 3 power steering pox plus the fast ratio idler an pitman arm (2 1/2 turns from lock to lock) and wouldnt pick anything else even it you gave me money for it.
btw. 16: 1 will give you 3 1/2 turns (like stock powesteering), 20:1 will give you 4 1/2 turns from lock to lock.
Re: steering box 16:1 or 24:1 [Re: 440sat72] #334048
05/31/09 02:36 PM
05/31/09 02:36 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
The 24:1 will be easiest. Many, many stock Mopars came with this setup. If You are going to use wide, sticky tires on the front I'd look at power steering.
Re: steering box 16:1 or 24:1 [Re: mcmopars] #334049
05/31/09 03:30 PM
05/31/09 03:30 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
what size front tires do you have? Does your duster have a small block or big block?
13" steering wheel looks ridiculous.
A 14" wheel is pretty small too. You will have a tough time seeing the gauges. Start with 15" steering wheel. All the facotry ones are over 16"
What cars/trucks have you driven with manual steering?
If you have the 24:1 in your hand now, just run it and see if you like it.
Re: steering box 16:1 or 24:1 [Re: 440sat72] #334050
06/03/09 12:16 AM
06/03/09 12:16 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Mo' Farts
Moderated by "tbagger".
Re: steering box 16:1 or 24:1 [Re: Grizzly] #334051
06/03/09 12:26 AM
06/03/09 12:26 AM
Renton, WA
GreenBlurr Offline
super gas
GreenBlurr  Offline
super gas
Renton, WA
Well he's clearly never driven anything with manual steering.
Yes a 13" steering wheel is totally unacceptable with any ratio of manual steering. You are going to want 15" or larger in diameter. And Do not run any wider than 215 series tires on the front (trust me on this one) If you go with the 24:1, you want as large a wheel as is practical. You CAN one hand drive that, but going into curves and whatnot, your hand will end up in seemingly unfamiliar and odd places in the circle of turning. But that's just something that comes with it. Do not get 16:1 if you are not a strong man. No offense intended there, but that ratio of manual steering box is what separates the men from the boys. So you should only use that if you work manual labor for a living, or are a boxer etc.
I personally have 16:1 manual on one of my cars that i street drive all the time right now. People always ask when I put the power steering into it, because i make it look that easy. But I also have the engine compartment lightened up to less weight than a factory small block, and the battery in the trunk. I of course also run 215/70 tires and keep them around 40 psi for easier low speed turning. But I do also work manual labor for a living, and my dad tells everyone I'm built like a brick youknowwhat house, and years of practice with said box all make it kind of a special case.
Track yourself down a 20:1 worm gear if you can find one, and have firm feel install it for ya.
It'll be the best of both worlds. And for the love of god get a REAL factory/factory sized steering wheel.
Re: steering box 16:1 or 24:1 [Re: Grizzly] #334052
06/03/09 12:36 AM
06/03/09 12:36 AM
Glendale Az
Darryls-Demon Offline
Glendale Az
I have the 20:1 box in my Challenger. 440 With Alum Heads, Alum Rad. battery in the trunk and manual brakes. Oh and so far no hood. The steering is stiff at slow speeds but is nice after that. If I was to do it over I think would have just used a 24:1 box.
Re: steering box 16:1 or 24:1 [Re: mcmopars] #334053
06/03/09 03:38 AM
06/03/09 03:38 AM
Hamburg / Germany
Den300 Offline
Den300  Offline
Hamburg / Germany
20:1 in c-body and a smaller steering wheel. no problem.
had the "normal" coupler in before and
switched to a flaming river coupler. steering was much easier after.
the flaming river coupler was a BIG improvement!
Hamburg/Germany
69 Chrysler 300
446cui Dual Quad
12.64 @ 110.7
Re: steering box 16:1 or 24:1 [Re: Den300] #334054
06/03/09 03:40 AM
06/03/09 03:40 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Interesting that the change from a coupler to the flaming river universal joint actually made the steering effort significantly easier.
Re: steering box 16:1 or 24:1 [Re: autoxcuda] #334055
06/03/09 03:44 AM
06/03/09 03:44 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
What he said
Re: steering box 16:1 or 24:1 [Re: goldmember] #334056
06/03/09 10:02 AM
06/03/09 10:02 AM
GA
roadrunninMark Offline
GA
which steering u joint did you use?
Re: steering box 16:1 or 24:1 [Re: roadrunninMark] #334057
06/03/09 11:47 PM
06/03/09 11:47 PM
northeast ohio
mkdart Offline
mkdart  Offline
northeast ohio
Mancini racing spring flyer has 20:1 worm gear on clearance 139.95. I have one in my smallblock dart and like it. Mike
Re: steering box 16:1 or 24:1 [Re: mkdart] #334058
06/04/09 03:31 AM
06/04/09 03:31 AM
germany
440sat72 Offline
440sat72  Offline
germany
i'd really recommend to have a ride in a car with manual steering before converting your car ... this could really help you decide wether it's a worthy swap or not.
Re: steering box 16:1 or 24:1 [Re: autoxcuda] #334059
06/04/09 04:01 AM
06/04/09 04:01 AM
Hamburg / Germany
Den300 Offline
Den300  Offline
Hamburg / Germany
I guess it was to a non optimized steering geometry.
sometimes (with the old couplers) the insulator felt off
and the alignment never looked 100% straight.
i think it went better because the flaming river one
uses a universal joint that compensates this miss alignment.
last weekend we had the biggest car meeting in north germany
and i tried the super bee from a friend. 24:1 with the
original steering wheel and the normal coupler.
it was as heavy as mine to steer. big surprise for him.
Hamburg/Germany
69 Chrysler 300
446cui Dual Quad
12.64 @ 110.7
Re: steering box 16:1 or 24:1 [Re: 440sat72] #334060
06/04/09 09:13 AM
06/04/09 09:13 AM
best idea yet & you'd then know what the 24:1 boxes feel like
Re: steering box 16:1 or 24:1 [Re: RapidRobert] #334061
06/04/09 10:38 AM
06/04/09 10:38 AM
Hamburg / Germany
Den300 Offline
Den300  Offline
Hamburg / Germany
but keep in mind that weight of the carīs front, tire pressure,
steering wheel diameter und width of the tires play an
important rule too! also if you can wash your arm in a coke bottle or not
Hamburg/Germany
69 Chrysler 300
446cui Dual Quad
12.64 @ 110.7
