turbo big blocks #327780
05/24/09 10:12 PM
05/24/09 10:12 PM
Boise, Idaho, U.S.A.
tims69belvedere Offline OP
My brother and I have decided that a budget turbo big block would be sweet in my car. Anybody got turbo big blocks on here???
Re: turbo big blocks [Re: tims69belvedere] #327781
05/24/09 10:21 PM
05/24/09 10:21 PM
MO.
4rsfed mopar Offline
MO.
I wil have one on the road shortly.It's been wired at the shop. 500 inch indy motor efi and twin 88s. 69 charger ladder bar car with raidals on it.
Re: turbo big blocks [Re: 4rsfed mopar] #327782
05/24/09 10:36 PM
05/24/09 10:36 PM
Motor City
Shaker223 Offline
Shaker223  Offline
Motor City
Mopar section at turbomustangs.com is your best bet.
Re: turbo big blocks [Re: tims69belvedere] #327783
05/24/09 11:58 PM
05/24/09 11:58 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
budget and turbo in the same sentance . HA
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: turbo big blocks [Re: go green] #327784
05/25/09 12:09 AM
05/25/09 12:09 AM
Edmonton, Alberta, Canada
Dartman75 Offline
Dartman75  Offline
There are two members on the board that I can think of. I believe that Hemi Fred's i sa big block. And I know CokeBottleKid has a big block charger known as "The Haze". I think I've seen some pics of another one or two, but names escape me. Hopefully they will help you out.
Greg
Re: turbo big blocks [Re: go green] #327785
05/25/09 01:37 AM
05/25/09 01:37 AM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
Actually....my brothers shop has built several for people and they are way cheaper to build that a pro-charged motor if you do everything yourself. The head units are much cheaper....
Re: turbo big blocks [Re: Quicksilver440] #327786
05/25/09 02:00 AM
05/25/09 02:00 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
If you can build a lot fo the stuff needed yourself it can proapbly be done on a budget. I would still expect to spend considerably more than you first assume. This was not a budget buildup, still everything done "at home", and the overall costs really tried my faith. But once it was ready, it was worth it.
Plynouth VIP '67 TT IC EFI
Re: turbo big blocks [Re: jyrki] #327787
05/25/09 12:41 PM
05/25/09 12:41 PM
well I was thinking a stock crank 383 with stock rods and some pistons. With a set of worked over 906's. And than add a couple of 3rd gen cummins turbo's just as an experiment.
Re: turbo big blocks [Re: tims69belvedere] #327788
05/26/09 05:10 PM
05/26/09 05:10 PM
Jarrettsville, MD
cudaman1967 Offline
cudaman1967  Offline
Jarrettsville, MD
From February. Updated photos coming
Cudaman1967 1967 Barracuda Turbo Outlaw 8.50
Re: turbo big blocks [Re: cudaman1967] #327789
05/26/09 09:37 PM
05/26/09 09:37 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
Cool, Lets see some more.
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: turbo big blocks [Re: tims69belvedere] #327790
05/26/09 09:45 PM
05/26/09 09:45 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
That's exactly what I am doing, except that I am using a pair of T04E turbos. stock rods, crank, pistons, 915 heads with big valves, TM6, modified 600DP
Re: turbo big blocks [Re: tims69belvedere] #327791
05/26/09 10:05 PM
05/26/09 10:05 PM
Chicago, IL
blownEFI Offline
blownEFI  Offline
Chicago, IL
Still in progress... 70 Challenger, 572 c.i., 106mm
"These go to eleven", Nigel Tufnel
Re: turbo big blocks [Re: tims69belvedere] #327792
05/27/09 09:07 AM
05/27/09 09:07 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
no such thing as a budget turbo....yeah you can buy the turbo pretty cheap but that's where it stops. Tons of fab work involved, not to mention the cutting up of the engine bay. Try a S/C much easier and 1/10th of the fab work.
On the good side, boost is great. No need for expensive port work, big bumpy cams, high stalls or tall gears.
Coming soon!!!!
Re: turbo big blocks [Re: Mr.Yuck] #327793
05/27/09 10:27 AM
05/27/09 10:27 AM
New Brunswick, Canada
TrxR Offline
TrxR  Offline
Myself Id rather deal with more fab work and go turbo then go with a Super charger. Also depending on the car and size of turbo it can be done without hacking the car up. Also I am not a big fan of putting that pressure of the belt on the snout of the crank.
Re: turbo big blocks [Re: TrxR] #327794
05/27/09 10:52 AM
05/27/09 10:52 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
if you can do the fab work fine if you can't you are looking at big $$$$$$$.
Coming soon!!!!
Re: turbo big blocks [Re: Mr.Yuck] #327795
05/27/09 11:53 AM
05/27/09 11:53 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Yes, you have to do the fab and research work yourself to make it budgetable. But depending on what a guy will use for a long block, power-for-power a turbo setup $$ can be comparable to a hi-hp NA engine. NA engines have to spin higher to make the same power as a boosted engine, and RPM is where the $$$ is at. Low-boost engines need very little special prepwork on the engine.
Yes, a centrifugal supercharger is much easier, but they heat the intake charge more than a turbo's compressor does.
There is a guy on TurboMustangs that was running a 1/2-ton truck into the 12s with a stock/untouched 383 - he bypassed $4000+ worth of engine mods for that performance level.
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: turbo big blocks [Re: Fury Fan] #327796
05/27/09 12:16 PM
05/27/09 12:16 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
this ran 12.0's from 12.90's on a good day w/ no other mods. Probably could have run 11's with some fine tuning. It was a fairly stock cast piston 440 w/ a summit 488 cam. I put the entire S/C togther including fuel system upgrades, bungs sensors and carb prep for around 2k. Could have been under 1800 but I had the tubes done by a local shop as I didn't want to butcher the welds.
Coming soon!!!!
Re: turbo big blocks [Re: Mr.Yuck] #327797
05/27/09 12:28 PM
05/27/09 12:28 PM
SO CAL
BB70DUSTER Offline
BB70DUSTER  Offline
SO CAL
sounds like alot of money to run 12.0s?!? If its all about the $ then squeeze it... my stock 400 with edelbrock heads and a hydraulic cam with a 225 shot strapped to it went 10.50s consistantley for years... on 91 octane no less!!!
Re: turbo big blocks [Re: BB70DUSTER] #327798
05/27/09 12:31 PM
05/27/09 12:31 PM
SO CAL
BB70DUSTER Offline
BB70DUSTER  Offline
SO CAL
I like the idea of a low buck white trash turbo build idea... me and a buddy have been talkin about doing it for awhile now... hes got a couple turbos and a intercooler from a super duty...
Re: turbo big blocks [Re: BB70DUSTER] #327799
05/27/09 12:47 PM
05/27/09 12:47 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
How long is it going to last hitting it w/ a 225 shot? what's it run w/o it? what did the NOS kit cost? what's it cost to fill it? it all adds up boost is FULL TIME it's ALWAYS available. SO not really I had maybe $3800 in the entire engine/trans w/ the S/C. Could have run 11's with some tuning. This was on 5.5lbs of boost and a little sumit 488 cam. I'll bet you had more in your engine. I did get the 8lb pulley on but sold it before I ran it. w/8psi I'd guess the car would have been around 11.60? drove to the track and home sometimes 50+ miles one way. I had 3.91's, if it had 3.73's probably would have been even better as the boost would come in quicker. and if i would have hit it w/ a 150 shot maybe a second faster. Oh yeah and in a 3850lb car at that
Coming soon!!!!
