Re: turbo big blocks
[Re: go green]
#327785
05/25/09 01:37 AM
05/25/09 01:37 AM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
budget and turbo in the same sentance . HA
Actually....my brothers shop has built several for people and they are way cheaper to build that a pro-charged motor if you do everything yourself. The head units are much cheaper....
[Re: tims69belvedere]
#327790
05/26/09 09:45 PM
05/26/09 09:45 PM
Posts: 3,619 Norwich CT USA
Defbob
Norwich CT USA
well I was thinking a stock crank 383 with stock rods and some pistons. With a set of worked over 906's. And than add a couple of 3rd gen cummins turbo's just as an experiment.
That's exactly what I am doing, except that I am using a pair of T04E turbos. stock rods, crank, pistons, 915 heads with big valves, TM6, modified 600DP
#327792
05/27/09 09:07 AM
05/27/09 09:07 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
My brother and I have decided that a budget turbo big block would be sweet in my car. Anybody got turbo big blocks on here???
no such thing as a budget turbo....yeah you can buy the turbo pretty cheap but that's where it stops. Tons of fab work involved, not to mention the cutting up of the engine bay. Try a S/C much easier and 1/10th of the fab work.
On the good side, boost is great. No need for expensive port work, big bumpy cams, high stalls or tall gears.
[Re: TrxR]
#327794
05/27/09 10:52 AM
05/27/09 10:52 AM
Mr.Yuck
Brookeville, Md
Myself Id rather deal with more fab work and go turbo then go with a Super charger. Also depending on the car and size of turbo it can be done without hacking the car up. Also I am not a big fan of putting that pressure of the belt on the snout of the crank.
if you can do the fab work fine if you can't you are looking at big $$$$$$$.
[Re: Mr.Yuck]
#327795
05/27/09 11:53 AM
05/27/09 11:53 AM
Posts: 3,533 Indiana
Fury Fan
Indiana
Yes, you have to do the fab and research work yourself to make it budgetable. But depending on what a guy will use for a long block, power-for-power a turbo setup $$ can be comparable to a hi-hp NA engine. NA engines have to spin higher to make the same power as a boosted engine, and RPM is where the $$$ is at. Low-boost engines need very little special prepwork on the engine.
Yes, a centrifugal supercharger is much easier, but they heat the intake charge more than a turbo's compressor does.
There is a guy on TurboMustangs that was running a 1/2-ton truck into the 12s with a stock/untouched 383 - he bypassed $4000+ worth of engine mods for that performance level.
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
[Re: Fury Fan]
#327796
05/27/09 12:16 PM
05/27/09 12:16 PM
Mr.Yuck
Brookeville, Md
this ran 12.0's from 12.90's on a good day w/ no other mods. Probably could have run 11's with some fine tuning. It was a fairly stock cast piston 440 w/ a summit 488 cam. I put the entire S/C togther including fuel system upgrades, bungs sensors and carb prep for around 2k. Could have been under 1800 but I had the tubes done by a local shop as I didn't want to butcher the welds.
[Re: Mr.Yuck]
#327797
05/27/09 12:28 PM
05/27/09 12:28 PM
Posts: 4,436 SO CAL
BB70DUSTER
SO CAL
sounds like alot of money to run 12.0s?!? If its all about the $ then squeeze it... my stock 400 with edelbrock heads and a hydraulic cam with a 225 shot strapped to it went 10.50s consistantley for years... on 91 octane no less!!!
[Re: BB70DUSTER]
#327799
05/27/09 12:47 PM
05/27/09 12:47 PM
Mr.Yuck
Brookeville, Md
Yes, you have to do the fab and research work yourself to make it budgetable. But depending on what a guy will use for a long block, power-for-power a turbo setup $$ can be comparable to a hi-hp NA engine. NA engines have to spin higher to make the same power as a boosted engine, and RPM is where the $$$ is at. Low-boost engines need very little special prepwork on the engine. Yes, a centrifugal supercharger is much easier, but they heat the intake charge more than a turbo's compressor does.
How long is it going to last hitting it w/ a 225 shot? what's it run w/o it? what did the NOS kit cost? what's it cost to fill it? it all adds up boost is FULL TIME it's ALWAYS available. SO not really I had maybe $3800 in the entire engine/trans w/ the S/C. Could have run 11's with some tuning. This was on 5.5lbs of boost and a little sumit 488 cam. I'll bet you had more in your engine. I did get the 8lb pulley on but sold it before I ran it. w/8psi I'd guess the car would have been around 11.60? drove to the track and home sometimes 50+ miles one way. I had 3.91's, if it had 3.73's probably would have been even better as the boost would come in quicker. and if i would have hit it w/ a 150 shot maybe a second faster. Oh yeah and in a 3850lb car at that
