Trick Flow 270 Heads #3229625
04/28/24 01:05 AM
04/28/24 01:05 AM
Cascade, CO
reknapp52 Offline OP
Cascade, CO
I'm starting to put another engine together, and considering the Trick Flow 270 heads. What is the go-to rocker shaft system to use on them?
Re: Trick Flow 270 Heads [Re: reknapp52] #3229627
04/28/24 01:51 AM
04/28/24 01:51 AM
sweden
carter Offline
carter  Offline
sweden
Harland Sharp is a good choice and budget friendly rocker, bought my first set in -91.
https://www.summitracing.com/parts/csp-s70016ke/make/chrysler
Re: Trick Flow 270 Heads [Re: carter] #3229629
04/28/24 02:23 AM
04/28/24 02:23 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Im running Crane 1.5s on mine
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Trick Flow 270 Heads [Re: tex013] #3229667
04/28/24 09:34 AM
04/28/24 09:34 AM
Cascade, CO
Cascade, CO
Thanks for that input guys--I was thinking that the 270s would take a rocker similar to the ones used on the Edelbrock Victor heads, which have more offset away from the intake port. I guess the 270s take a rocker with a more standard configuration?
Re: Trick Flow 270 Heads [Re: reknapp52] #3229697
04/28/24 11:27 AM
04/28/24 11:27 AM
Plymouth, MI
Blusmbl Online content
Blusmbl  Online Content
Plymouth, MI
Correct, they use standard offset rockers. Trick Flow recommends the E suffix standard offset Harland Sharps that were designed for the Edelbrock RPM head.
Re: Trick Flow 270 Heads [Re: reknapp52] #3229712
04/28/24 12:15 PM
04/28/24 12:15 PM
AndyF Offline
AndyF  Offline
Trick Flow designed the 270 heads to accept a standard offset rocker. I highly recommend using T&D rockers if you're building a race engine and you are going to run a solid roller cam. If you are running a hyd roller cam then you can use a less expensive rocker setup. For street use I'd go with the Comp Cams steel rockers.
Re: Trick Flow 270 Heads [Re: AndyF] #3229716
04/28/24 12:25 PM
04/28/24 12:25 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Again agree with Andy. T&D would be my choice.
Re: Trick Flow 270 Heads [Re: reknapp52] #3229757
04/28/24 03:39 PM
04/28/24 03:39 PM
AndyF Offline
AndyF  Offline
I did a lot of dyno testing with the 270 heads when they first came out. Made close to 800 hp with a pump gas 470 using the TF270 heads. I tested a lot of different rocker arms. They all worked just fine but the T&D were by far the best setup in terms of quality, fit and function. Here is an article where I used a fairly aggressive cam lobe with the Comp dual conical valve springs and a set of 1.65 ratio T&D rockers. I think the engine was making around 750 hp in this configuration. https://www.motortrend.com/articles/dyno-tested-dual-conical-valve-springs/
Re: Trick Flow 270 Heads [Re: AndyF] #3229759
04/28/24 03:43 PM
04/28/24 03:43 PM
AndyF Offline
AndyF  Offline
Here is the rocker arm test article: https://www.motortrend.com/articles/trying-find-extra-power-rocker-arm-testing/
The rocker arm testing was done on TF240 castings but the fit is exactly the same on the TF270 heads. I transferred parts back and forth between the 240 and 270 castings without any issues.
Re: Trick Flow 270 Heads [Re: AndyF] #3229769
04/28/24 04:42 PM
04/28/24 04:42 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I also recommend the T&D's....Very nice step up from the others.
Re: Trick Flow 270 Heads [Re: AndyF] #3229775
04/28/24 04:59 PM
04/28/24 04:59 PM
Cascade, CO
Cascade, CO
Andy, I enjoyed both of those articles--Great equipment and well presented. I'm a little surprised that the higher ratio rockers didn't make very much difference. A few questions--
1. Do the T&D rockers maintain their side-to-side clearance with different sizes of "sleeves" on the shaft or are there some thin shim washers in there that I couldn't see?
2. How many different rocker ratios did you test? Looks like 2 or 3 different manufacturers.
3. On the Summit website the Trick Flow 270s show a max valve lift of .680. Different valve springs needed to accommodate higher lift camshafts?
4. You mentioned that I should pressure test my block. How is that done? Block off water pump holes and bolt a set of heads on? What PSI to test to?
Thanks!
Re: Trick Flow 270 Heads [Re: reknapp52] #3229794
04/28/24 06:17 PM
04/28/24 06:17 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
I used comp irons, had to mill the stands a bit to get alignment and side clearance right then use a B3 correction kit to fix the valve tip sweep.
Re: Trick Flow 270 Heads [Re: reknapp52] #3229797
04/28/24 06:26 PM
04/28/24 06:26 PM
AndyF Offline
AndyF  Offline
I tested four ratios, 1.5, 1.6, 1.65 and 1.70. We're not sure why the engine didn't pick up power with the additional ratio but what we think is that the cam lobe was as fast as it needed to be at 1.50 so the higher ratio was just wasting energy by opening faster than what the engine needed. There is only so much air that is going to flow into that size of port in a certain amount of time. In this case evidently the valve action wasn't the "cork" in the system. With some testing we probably could've found a slower cam lobe that did require a high ratio rocker arm to work correctly. So if we ran the dyno tests with a slower cam lobe we probably would've picked up power every time we added rocker ratio. That is what you would want to do if you were selling high ratio rocker arms.
The T&D rockers use spacers between the rocker arms. I don't recall any shims but perhaps there is a thin shim between the rocker arm and the spacer.
Yes, if you are going to go past 0.680 then you'll need to change springs. If that is the case then you might want to think carefully about which head to buy. I'd buy the heads with the springs that are easiest to sell which is probably the hyd roller heads. Then you pull those springs and sell them and buy the springs that you need. Or just go ahead and buy the solid roller heads and sell the existing springs, but keep the good retainers and locks. If you look at my for sale ads in the race section you can see that I'm selling new parts which I didn't need. Most likely because I did this exact trick.
I used to sell pressure checker kits for BB and Hemi engines. I stopped selling them but I have a few on the shelf if you need on. It is a very simple tool. Bolt on a head with a good head gasket and then fill the block with water at least half full and then hit it with a little bit of air. I wouldn't go more than a few psi. Whatever your radiator cap is rated at is a good limit.
Re: Trick Flow 270 Heads [Re: AndyF] #3229896
04/29/24 07:46 AM
04/29/24 07:46 AM
NC
440Jim Offline
440Jim  Offline
NC
FYI,
The Trick Flow valley plate is back in stock at Summit. O-ring seal on the removable center cover (for lifter maintenance, etc.). up
Trick Flow® Valley Plates TFS-61600830
And Summit shows 0.700" max valve lift with the solid roller heads, TFS-6161T784-C01. And if you look at the PAC springs that come with them, you can likely run a tiny bit more. But check actual installed height, coil bind, lash, etc.
Re: Trick Flow 270 Heads [Re: 440Jim] #3229915
04/29/24 10:26 AM
04/29/24 10:26 AM
Cascade, CO
Cascade, CO
Thanks for that info Jim--I did see that I was looking at the specs on heads that they were selling for a hydraulic roller motor. The solid roller heads will probably fit my needs. And I love the removeable valley covers, especially if equipped with clear Lexan. We recently detected a cracked cylinder wall in my current motor after noticing some condensation forming on the Lexan cover.
Re: Trick Flow 270 Heads [Re: reknapp52] #3229921
04/29/24 10:43 AM
04/29/24 10:43 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Those Trick Flow valley pans are very sexy but bear in mind they don't work on an RB, only a B, according to Trick Flow's website. (You didn't say which one you were building.)
2011 Drag Pak Challenger
Re: Trick Flow 270 Heads [Re: rickseeman] #3229924
04/29/24 10:52 AM
04/29/24 10:52 AM
Cascade, CO
Cascade, CO
I've been running low-deck motors, but this Keith Black block I got is a RB. Hmmmmm.....
Re: Trick Flow 270 Heads [Re: reknapp52] #3229938
04/29/24 11:45 AM
04/29/24 11:45 AM
AndyF Offline
AndyF  Offline
Trick Flow has both B and RB valley covers and so does Indy. I used to build them too but I stopped making them after Trick Flow introduced theirs.
Re: Trick Flow 270 Heads [Re: AndyF] #3229994
04/29/24 02:56 PM
04/29/24 02:56 PM
Cascade, CO
Cascade, CO
Yep, I have a couple of yours smile
Re: Trick Flow 270 Heads [Re: reknapp52] #3230021
04/29/24 04:20 PM
04/29/24 04:20 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Everything Andy makes is sexy. I have many of his items.
