Re: Trick Flow 270 Heads
[Re: carter]
#3229629
04/28/24 02:23 AM
04/28/24 02:23 AM
Posts: 2,470 Sydney,Australia
tex013
Sydney,Australia
Im running Crane 1.5s on mine
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: reknapp52]
#3229697
04/28/24 11:27 AM
04/28/24 11:27 AM
Posts: 8,182 Plymouth, MI
Blusmbl
Plymouth, MI
Correct, they use standard offset rockers. Trick Flow recommends the E suffix standard offset Harland Sharps that were designed for the Edelbrock RPM head.
[Re: reknapp52]
#3229712
04/28/24 12:15 PM
04/28/24 12:15 PM
Posts: 31,073 Oregon
AndyF
Thanks for that input guys--I was thinking that the 270s would take a rocker similar to the ones used on the Edelbrock Victor heads, which have more offset away from the intake port. I guess the 270s take a rocker with a more standard configuration? Trick Flow designed the 270 heads to accept a standard offset rocker. I highly recommend using T&D rockers if you're building a race engine and you are going to run a solid roller cam. If you are running a hyd roller cam then you can use a less expensive rocker setup. For street use I'd go with the Comp Cams steel rockers.
[Re: AndyF]
#3229716
04/28/24 12:25 PM
04/28/24 12:25 PM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
Again agree with Andy. T&D would be my choice.
[Re: AndyF]
#3229896
04/29/24 07:46 AM
04/29/24 07:46 AM
Posts: 16,930 NC
440Jim
NC
FYI, The Trick Flow valley plate is back in stock at Summit. O-ring seal on the removable center cover (for lifter maintenance, etc.). Trick Flow® Valley Plates TFS-61600830 And Summit shows 0.700" max valve lift with the solid roller heads, TFS-6161T784-C01. And if you look at the PAC springs that come with them, you can likely run a tiny bit more. But check actual installed height, coil bind, lash, etc.
[Re: 440Jim]
#3229915
04/29/24 10:26 AM
04/29/24 10:26 AM
Posts: 427 Cascade, CO
reknapp52
Cascade, CO
Thanks for that info Jim--I did see that I was looking at the specs on heads that they were selling for a hydraulic roller motor. The solid roller heads will probably fit my needs. And I love the removeable valley covers, especially if equipped with clear Lexan. We recently detected a cracked cylinder wall in my current motor after noticing some condensation forming on the Lexan cover.
[Re: reknapp52]
#3229921
04/29/24 10:43 AM
04/29/24 10:43 AM
Posts: 2,678 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Those Trick Flow valley pans are very sexy but bear in mind they don't work on an RB, only a B, according to Trick Flow's website. (You didn't say which one you were building.)
2011 Drag Pak Challenger
