thoughts on 727 transmission pan studs ? #3224998
04/04/24 12:27 PM
04/04/24 12:27 PM
moparx Offline OP
moparx  Offline OP
was thinking on swapping out the usual bolts for studs while swapping the MP chrome pan for a cast aluminum pan.
however, the "stud kits" i have seen are just long 5/16x18 set screws. i would much rather prefer the 5/16x18 to 5/16x24 style studs, then use 5/16x24 serrated flange nuts to secure the cast pan.
thoughts/opinions, pros/cons on this ?
TIA ! up
beer
Re: thoughts on 727 transmission pan studs ? [Re: moparx] #3225004
04/04/24 12:37 PM
04/04/24 12:37 PM
NC
440Jim Offline
440Jim  Offline
NC
I have only ever used bolts. But those castings can easily be stripped, so studs sound like a nice touch to me.
Everything you said about the serrated nuts sounds good also, since the gasket should NOT be over torqued.
Might be a little overkill, but I can't knock it.
If you want to spend the money on ARP studs, be my guest. But simple coarse threads with common serrated flanged nuts should be just fine, IMO.
Check around the shifter area. If the cable bracket mounts to the pan, there might be a reason to use bolts for maintenance/space reasons. shruggy
And if the pan has an internal baffle around the filter, the pan might not drop down far enough to clear the studs without moving rearward. Measure twice...
Re: thoughts on 727 transmission pan studs ? [Re: moparx] #3225008
04/04/24 12:44 PM
04/04/24 12:44 PM
I'm using 5/16 set screws along with the serrated nuts on my all aluminum KB wedge motor oil pan fasteners on the aluminum Charlies oil pan up
I hope they hold up okay luck shruggy
Re: thoughts on 727 transmission pan studs ? [Re: Cab_Burge] #3225074
04/04/24 05:38 PM
04/04/24 05:38 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
I don't think studs should pose any problems. Check AuVeCo and see what they offer.
Angry white pureblood male
Re: thoughts on 727 transmission pan studs ? [Re: ruderunner] #3225116
04/04/24 09:46 PM
04/04/24 09:46 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Don't over think it. It's just trans pan fasteners.
If the 5/16-18 bolts worked on millions of torqflites, why worry about 5/16-24 now?
Re: thoughts on 727 transmission pan studs ? [Re: moparx] #3225164
04/05/24 08:01 AM
04/05/24 08:01 AM
Byron, NY
W.I.N. Racing Offline
Byron, NY
TIA ! up
beer
This would be my preference also...if I were to stud a Transmission pan
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: thoughts on 727 transmission pan studs ? [Re: W.I.N. Racing] #3225192
04/05/24 10:48 AM
04/05/24 10:48 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have my pan studed with ARP studs. 50+ year old cases. It does help from stripping any case threads.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: thoughts on 727 transmission pan studs ? [Re: 6PKRTSE] #3225208
04/05/24 12:01 PM
04/05/24 12:01 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
The problem I had with studding the oil pan was that trying to remove the pan while in the car. The front of the pan near the K frame could not drop down far enough to clear the studs,so I had to use bolts in the front by the K frame and studs for the rest of the pan. Some cars may have more clearance than others.
Re: thoughts on 727 transmission pan studs ? [Re: OUTLAWSSAA] #3225250
04/05/24 03:15 PM
04/05/24 03:15 PM
Mo.
racerx Offline
racerx  Offline
Mo.
iagreeX2 on the pan studs but i have an aftermarket K.I will be replacing the studs with bolts.
Re: thoughts on 727 transmission pan studs ? [Re: OUTLAWSSAA] #3225308
04/05/24 09:54 PM
04/05/24 09:54 PM
You need to buy 4 shorter studs or set screws to allow the nuts to come off easily up scope wrench twocents
I have used nuts on the threaded long ends above the block to lock and hold them in place scope up
Re: thoughts on 727 transmission pan studs ? [Re: Cab_Burge] #3225318
04/05/24 11:26 PM
04/05/24 11:26 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Since we are talking about transmission pans and using studs in the case, or not...
studs would be okay, but I typically Heli-coil all the holes, before they get striped. And use a torque wrench to tighten the bolts. You're not going to damage the case using the proper tools and torque specs.
Re: thoughts on 727 transmission pan studs ? [Re: CMcAllister] #3225423
04/06/24 01:44 PM
04/06/24 01:44 PM
moparx Offline OP
moparx  Offline OP
any thoughts about using blue loc-tite on the studs or set screws in the transmission case ?
i would heli-coil the case, but the transmission is still in the car.
beer
