Head Gasket Woes? Fel-Pro 1009 #3222633
03/25/24 08:56 AM
03/25/24 08:56 AM
Pennsylvania
19_Dart_68 Offline OP
Pennsylvania
Hey all. So, I'm in the process of mocking up my 505 stroker...440, .030 over, etc...(Factory iron block, TrickFlow aluminum heads)
I have Fel-Pro 1009 gaskets, and I drop one on the block and to my dismay, the fire ring is over-hanging the factory chamfer by a noticeable amount. These gaskets are supposed to be 4.410" in diameter. Everything I am reading says this is a no-no situation because it will trap combustion pressure under the ring and lift the gasket...
So, what are my options? Cometic MLS 4.500" ? Rubber-coated Copper 4.500"? LS swap? (J/K)
68 Dart - 440 Swap in Progress...please stand by
Re: Head Gasket Woes? Fel-Pro 1009 [Re: 19_Dart_68] #3222638
03/25/24 09:16 AM
03/25/24 09:16 AM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
Some blocks have a gigantic chamfer in the top of the bore frown and all I know to do is go to a gasket with a bigger hole. My friend recently had the same problem. I feel your pain. The Fel-Pro 1105 is real big, gasket hole 4.59. I wonder if they have anything in between? If not you will have to change brand.
2011 Drag Pak Challenger
Re: Head Gasket Woes? Fel-Pro 1009 [Re: 19_Dart_68] #3222640
03/25/24 09:25 AM
03/25/24 09:25 AM
N
NITROUSN Offline
NITROUSN  Offline
N
FelPro 8519PT1
Re: Head Gasket Woes? Fel-Pro 1009 [Re: 19_Dart_68] #3222642
03/25/24 09:28 AM
03/25/24 09:28 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
If you think the block is bad check it out on the head. Edelbrock head fit is terrible
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Head Gasket Woes? Fel-Pro 1009 [Re: NITROUSN] #3222647
03/25/24 10:02 AM
03/25/24 10:02 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Originally Posted by NITROUSN
FelPro 8519PT1
THIS !!!
Re: Head Gasket Woes? Fel-Pro 1009 [Re: NITROUSN] #3222653
03/25/24 10:38 AM
03/25/24 10:38 AM
Pennsylvania
Pennsylvania
Is this one is ok for 10.5:1 compression ratio?
Re: Head Gasket Woes? Fel-Pro 1009 [Re: 19_Dart_68] #3222655
03/25/24 11:08 AM
03/25/24 11:08 AM
AndyF Offline
AndyF  Offline
With Trick Flow heads you should go straight to Cometic gaskets. Don't bother with any of the cheap stuff, order the correct parts and do it once.
Re: Head Gasket Woes? Fel-Pro 1009 [Re: AndyF] #3222658
03/25/24 11:15 AM
03/25/24 11:15 AM
Pennsylvania
Pennsylvania
iagree
Re: Head Gasket Woes? Fel-Pro 1009 [Re: Stanton] #3222671
03/25/24 12:17 PM
03/25/24 12:17 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
FelPro 8519PT1
THIS !!!
x3
I ran them at 14 to 1.
10.5 should be no sweat I think fel-pro says good to 12 to 1
Re: Head Gasket Woes? Fel-Pro 1009 [Re: AndyF] #3222686
03/25/24 01:06 PM
03/25/24 01:06 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
x4!
I tried Fel-Pro's with my 505 build initially and had issues.
No issues with Cometics (I've used 2 different thicknesses) over the last 9 years.
Lots of abuse and a rowdy jug!
'63 Dodge 330
11.19 @ 121 mph
Re: Head Gasket Woes? Fel-Pro 1009 [Re: GY3] #3222849
03/26/24 10:16 AM
03/26/24 10:16 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
My suggestion is anyone considering the Fel-Pro 8519 look into the 17059 Marine gasket instead: https://board.moparts.org/ubbthread...38/fel-pro-17059-marine-head-gasket.html
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Head Gasket Woes? Fel-Pro 1009 [Re: Brad_Haak] #3222943
03/26/24 05:28 PM
03/26/24 05:28 PM
Indiana
Gabby63 Offline
Gabby63  Offline
Indiana
I used the marine gasket 17059 on my stock block .060 over with Indy heads , zero issues . Gary
Mainly for the larger bore , & the finish on the block was not up to specs for cometic gaskets .
Re: Head Gasket Woes? Fel-Pro 1009 [Re: Gabby63] #3223043
03/27/24 09:09 AM
03/27/24 09:09 AM
Bowler Wisconsin
Smoparmike Offline
Smoparmike  Offline
Bowler Wisconsin
I also used the 17059 marine gasket no problems
