Re: Fel-Pro 17059 marine head gasket
[Re: mopar dave]
#2727050
12/26/19 12:54 PM
12/26/19 12:54 PM
Thumperdart
State of confusion
Been running those forever w/my 470.............
[Re: mopar dave]
#2727087
12/26/19 02:58 PM
12/26/19 02:58 PM
Thumperdart
State of confusion
My pistons are -.002 in the hole............
[Re: Cab_Burge]
#2727332
12/27/19 11:40 AM
12/27/19 11:40 AM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
The FP 17059 has a stainless steel solid core and a stainless steel folded over armor for each cylinder. Stainless steel will not rust in salt-water/marine environments.
It does not have the "Performance" internal wire ring that is common within the Fel-Pro Performance racing gaskets, such as the #1009 (big-block). That internal wire ring gives the superior combustion sealing assurance with high CRs, as well as combats against any detonation/pre-ignition inside the chamber... which is the #1 cause of burnt out head gaskets at the combustion seal area. The "FP Performance" head gasket also only have a tin-plate solid metal core... no need for SS since the environment will most likely not be salt-water/marine.
I'm a former FP engineer... so, this info should settle your concerns.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar Mitch]
#2727348
12/27/19 12:04 PM
12/27/19 12:04 PM
Posts: 20,204 PA.
pittsburghracer
"Little"John
"Little"John
PA.
. Most of use moved away from the 1009 and started using the 17059 because the wire Oring would overhang the Head chamber on heads like Edelbrock and Stealths. I could never understand why FelPro wouldn’t re-engineer the 1009 gasket to address this issue.
[Re: pittsburghracer]
#2727891
12/29/19 02:04 AM
12/29/19 02:04 AM
Mopar Mitch
Pittsburgh -- I suggest that you (and others) make a direct call into the Federal-Mogul Tech Line and speak your peace about this matter on the 1009 having the bore diameter a little too small... make an issue about it. (For those that don't know, Federal-Mogul bought out Fel-Pro back in 1998... )
Mopar Mitch
[Re: Mopar Mitch]
#2727931
12/29/19 10:07 AM
12/29/19 10:07 AM
Posts: 20,204 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Pittsburgh -- I suggest that you (and others) make a direct call into the Federal-Mogul Tech Line and speak your peace about this matter on the 1009 having the bore diameter a little too small... make an issue about it. (For those that don't know, Federal-Mogul bought out Fel-Pro back in 1998... ) It doesn’t affect me anymore. Most of us have found ways around this issue years ago
