What do other drive-to-track guys use for air supply? #3220647
03/15/24 03:42 PM
03/15/24 03:42 PM
Loudoun County, VA
Brad_Haak Offline OP
Loudoun County, VA
If you drive your car to the track like I do (as opposed to trailering it), what do you use for an air supply to pump up your tires before driving home, if the track doesn't have an onsite air compressor?
Believe it or not, I've used a high-volume bicycle tire pump in the past when necessary, (about 10 pumps per 1 psi in a car tire), but am now looking at options like a portable air tank or tire inflators that can plug into the car's 12v lighter socket.
Thx
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: What do other drive-to-track guys use for air supply? [Re: Brad_Haak] #3220650
03/15/24 03:45 PM
03/15/24 03:45 PM
NE Ohio
DoubleD Online content
DoubleD  Online Content
NE Ohio
I use a little Milwaukee M-12 air pump and I have the USB charger for it to plug into the car to charge the battery if needed - but never needed to - just by the bigger battery for it - works great
Re: What do other drive-to-track guys use for air supply? [Re: Brad_Haak] #3220657
03/15/24 04:25 PM
03/15/24 04:25 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Thx
I bring a small air tank & a cig lighter power small pump JUST in case I run out of air in my tank.
Re: What do other drive-to-track guys use for air supply? [Re: Brad_Haak] #3220659
03/15/24 04:50 PM
03/15/24 04:50 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
I know several guys that use the 12 volt cigarette lighter plug tire inflators.
I've also seen guys use the rechargeable battery powered versions.
Just search "cordless tire inflator with battery and charger" and lots of them come up.
Either one will do the job just fine.
Re: What do other drive-to-track guys use for air supply? [Re: Brad_Haak] #3220680
03/15/24 06:46 PM
03/15/24 06:46 PM
AndyF Offline
AndyF  Offline
Nissan Leafs come with a cool little air compressor in a plastic case. It plugs into the lighter socket if you have one of those. If you don't have a lighter socket it only takes a few minutes to put clamps on the ends so you can run it off your battery. If you go wrecking yard hunting you can find the Leaf compressors for cheap or you can buy them off of ebay or Amazon.
Re: What do other drive-to-track guys use for air supply? [Re: DoubleD] #3220685
03/15/24 07:04 PM
03/15/24 07:04 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
I have the slightly larger M18 one and love it. It has enough oomph to fill up my truck tires after airing down to single digits for offroading too.
Re: What do other drive-to-track guys use for air supply? [Re: Blusmbl] #3220693
03/15/24 07:54 PM
03/15/24 07:54 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I use the Ryobi 18 volt. It uses the same batteries as all my other ryobi stuff. It shuts off automatically when it reaches the pressure that I set it for. So I can turn it on and walk away and do something else. Jeff has the same thing, except it is Dewalt, they both work about the same.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: What do other drive-to-track guys use for air supply? [Re: Hemi_Joel] #3220700
03/15/24 08:31 PM
03/15/24 08:31 PM
Illinois
gearhead01 Offline
gearhead01  Offline
Illinois
I use the Milwaukee pump as well.
I can start it on a tire and start putting the rest of my gear in the trunk.
John
1971 Satellite Sebring Plus - 14.46 @ 95.43
1977 Road Runner - N/B 11.02@ 119 Drag Radials
Re: What do other drive-to-track guys use for air supply? [Re: gearhead01] #3220712
03/15/24 09:29 PM
03/15/24 09:29 PM
Loudoun County, VA
Loudoun County, VA
Been reading a lot of reviews on the portable inflators. The good ones aren't cheap, and the fact that I have no existing cordless tools with the same types of batteries & chargers makes the "all in" price a bit ridiculous... $300+ for a bleepin' mini air compressor w/ the necessary accessories.
Good think I bought a new bicycle tire pump last year wink
Re: What do other drive-to-track guys use for air supply? [Re: Brad_Haak] #3220716
03/15/24 09:45 PM
03/15/24 09:45 PM
AndyF Offline
AndyF  Offline
Re: What do other drive-to-track guys use for air supply? [Re: Brad_Haak] #3220763
03/16/24 09:23 AM
03/16/24 09:23 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Didn't your Challenger come with a 12volt pump, mine did its in the trunk under the panel that covers the non existing spare tire
Re: What do other drive-to-track guys use for air supply? [Re: CSK] #3220778
03/16/24 10:45 AM
03/16/24 10:45 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Buy a small Viair pump and put it in the truck of the car. They are fairly light and work very well. Here is a link to summit but if you shop around can find them cheaper elsewhere
https://www.summitracing.com/parts/var-10000
Re: What do other drive-to-track guys use for air supply? [Re: Brad_Haak] #3220788
03/16/24 11:42 AM
03/16/24 11:42 AM
NE Ohio
NE Ohio
Too funny - and you get some exercise while doing it !!! you can buy it out of your HSA account and claim it as exercise equipment!!
Re: What do other drive-to-track guys use for air supply? [Re: CSK] #3220880
03/16/24 06:24 PM
03/16/24 06:24 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
[/quote]
Didn't your Challenger come with a 12volt pump, mine did its in the trunk under the panel that covers the non existing spare tire [/quote]
You beat me to it. I was going to say the same thing. All the new Challengers have that pump.
Re: What do other drive-to-track guys use for air supply? [Re: OUTLAWSSAA] #3221284
03/18/24 07:24 PM
03/18/24 07:24 PM
Loudoun County, VA
Loudoun County, VA
You guys mean this? https://www.youtube.com/watch?v=2zcM1Cbg1dY
Also known as "That thing I found under the trunk mat next to the wheel locks I never thought I'd received when I bought the car"
I thought it was a 1-shot sealant & pump "for emergency use only" deal; didn't realize the pump was supposed to be reusable.
work
Re: What do other drive-to-track guys use for air supply? [Re: Brad_Haak] #3221297
03/18/24 08:12 PM
03/18/24 08:12 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
work
laugh2
The first one of the factory ones that I used was on my 2007 Chrysler 300 SRT, the one that came in the trunk.
About 30 seconds after I plugged it in, it blew the fuse. drumhit
I've used the one on my 2010 Challenger SRT and so far it seems to work okay.
I've also got an aftermarket one that I've used (a cheap one, I think it was a MotorTrend Promo deal) that works but I'm not sure how long it will last before it craps out. laugh2
Re: What do other drive-to-track guys use for air supply? [Re: Brad_Haak] #3221338
03/18/24 10:59 PM
03/18/24 10:59 PM
AndyF Offline
AndyF  Offline
Yep, that is the same as the ones for sale on Amazon and ebay. Just don't use the sealant when you air up the tires at the track. Try it out and see how it works. If it works for you then you solved the problem without spending any more money.
Re: What do other drive-to-track guys use for air supply? [Re: AndyF] #3221339
03/18/24 11:31 PM
03/18/24 11:31 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Bought this 3 years ago. Bought the extra hefty 5a battery and charger. Around 120 bucks for the whole setup.
Use it at the track, and extensively on a car lot I own. Light, dependable, cheap. One of the best gadgets I have ever bought
In 3 years bet I haven’t had to recharge the thing 8-10 times total..and I use it. Flats. Low tires, adjust pressure at the track, etc, etc
https://www.harborfreight.com/20v-c...si-inflatordeflator-tool-only-64533.html
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: What do other drive-to-track guys use for air supply? [Re: Brad_Haak] #3221369
03/19/24 09:09 AM
03/19/24 09:09 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I bought the DeWalt DCC0201 mainly because I had their impact, drill, etc. and plenty of batteries. It was a screamin' deal at $100 but now I see they are over $140 in most stores.
I use it way more than I thought I would as I keep it in the daily driver and someone always has a low tire at work or two wheel dolly needs air. I almost never fire up the big compressor in the shop anymore after getting this!
'63 Dodge 330
11.19 @ 121 mph
Re: What do other drive-to-track guys use for air supply? [Re: GY3] #3221375
03/19/24 09:57 AM
03/19/24 09:57 AM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
Me too. I bought the Milwaukee version because I had their impact, drill, etc. and plenty of batteries also.
It is durable.It can be dragged down the road for a 1/2 mile and still work.
