What do other drive-to-track guys use for air supply?
#3220647
03/15/24 03:42 PM
03/15/24 03:42 PM
Posts: 1,118 Loudoun County, VA
Brad_Haak
Loudoun County, VA
If you drive your car to the track like I do (as opposed to trailering it), what do you use for an air supply to pump up your tires before driving home, if the track doesn't have an onsite air compressor?
Believe it or not, I've used a high-volume bicycle tire pump in the past when necessary, (about 10 pumps per 1 psi in a car tire), but am now looking at options like a portable air tank or tire inflators that can plug into the car's 12v lighter socket.
Thx
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: What do other drive-to-track guys use for air supply?
[Re: Brad_Haak]
#3220650
03/15/24 03:45 PM
03/15/24 03:45 PM
Posts: 2,296 NE Ohio
DoubleD
NE Ohio
I use a little Milwaukee M-12 air pump and I have the USB charger for it to plug into the car to charge the battery if needed - but never needed to - just by the bigger battery for it - works great
[Re: Brad_Haak]
#3220657
03/15/24 04:25 PM
03/15/24 04:25 PM
Posts: 2,855 Pattison Texas
CSK
Pattison Texas
Thx I bring a small air tank & a cig lighter power small pump JUST in case I run out of air in my tank.
[Re: Brad_Haak]
#3220659
03/15/24 04:50 PM
03/15/24 04:50 PM
Posts: 10,130 A Red State
SNK-EYZ
A Red State
I know several guys that use the 12 volt cigarette lighter plug tire inflators.
I've also seen guys use the rechargeable battery powered versions. Just search "cordless tire inflator with battery and charger" and lots of them come up.
Either one will do the job just fine.
[Re: DoubleD]
#3220685
03/15/24 07:04 PM
03/15/24 07:04 PM
Posts: 8,164 Plymouth, MI
Blusmbl
Plymouth, MI
I use a little Milwaukee M-12 air pump and I have the USB charger for it to plug into the car to charge the battery if needed - but never needed to - just by the bigger battery for it - works great I have the slightly larger M18 one and love it. It has enough oomph to fill up my truck tires after airing down to single digits for offroading too.
[Re: Blusmbl]
#3220693
03/15/24 07:54 PM
03/15/24 07:54 PM
Posts: 7,480 Minnesota
Hemi_Joel
Minnesota
I use the Ryobi 18 volt. It uses the same batteries as all my other ryobi stuff. It shuts off automatically when it reaches the pressure that I set it for. So I can turn it on and walk away and do something else. Jeff has the same thing, except it is Dewalt, they both work about the same.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#3220700
03/15/24 08:31 PM
03/15/24 08:31 PM
Posts: 202 Illinois
gearhead01
Illinois
I use the Milwaukee pump as well.
I can start it on a tire and start putting the rest of my gear in the trunk.
John
1971 Satellite Sebring Plus - 14.46 @ 95.43 1977 Road Runner - N/B 11.02@ 119 Drag Radials
[Re: gearhead01]
#3220712
03/15/24 09:29 PM
03/15/24 09:29 PM
Brad_Haak
Loudoun County, VA
Been reading a lot of reviews on the portable inflators. The good ones aren't cheap, and the fact that I have no existing cordless tools with the same types of batteries & chargers makes the "all in" price a bit ridiculous... $300+ for a bleepin' mini air compressor w/ the necessary accessories. Good think I bought a new bicycle tire pump last year
[Re: Brad_Haak]
#3220716
03/15/24 09:45 PM
03/15/24 09:45 PM
Posts: 31,005 Oregon
AndyF
[Re: Brad_Haak]
#3220763
03/16/24 09:23 AM
03/16/24 09:23 AM
CSK
Pattison Texas
Been reading a lot of reviews on the portable inflators. The good ones aren't cheap, and the fact that I have no existing cordless tools with the same types of batteries & chargers makes the "all in" price a bit ridiculous... $300+ for a bleepin' mini air compressor w/ the necessary accessories. Good think I bought a new bicycle tire pump last year Didn't your Challenger come with a 12volt pump, mine did its in the trunk under the panel that covers the non existing spare tire
[Re: CSK]
#3220778
03/16/24 10:45 AM
03/16/24 10:45 AM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
Buy a small Viair pump and put it in the truck of the car. They are fairly light and work very well. Here is a link to summit but if you shop around can find them cheaper elsewhere https://www.summitracing.com/parts/var-10000
[Re: Brad_Haak]
#3220788
03/16/24 11:42 AM
03/16/24 11:42 AM
DoubleD
NE Ohio
Been reading a lot of reviews on the portable inflators. The good ones aren't cheap, and the fact that I have no existing cordless tools with the same types of batteries & chargers makes the "all in" price a bit ridiculous... $300+ for a bleepin' mini air compressor w/ the necessary accessories. Good think I bought a new bicycle tire pump last year Too funny - and you get some exercise while doing it !!! you can buy it out of your HSA account and claim it as exercise equipment!!
[Re: OUTLAWSSAA]
#3221284
03/18/24 07:24 PM
03/18/24 07:24 PM
Brad_Haak
Loudoun County, VA
You guys mean this? https://www.youtube.com/watch?v=2zcM1Cbg1dYAlso known as "That thing I found under the trunk mat next to the wheel locks I never thought I'd received when I bought the car" I thought it was a 1-shot sealant & pump "for emergency use only" deal; didn't realize the pump was supposed to be reusable.
[Re: Brad_Haak]
#3221297
03/18/24 08:12 PM
03/18/24 08:12 PM
SNK-EYZ
A Red State
You guys mean this? https://www.youtube.com/watch?v=2zcM1Cbg1dYAlso known as "That thing I found under the trunk mat next to the wheel locks I never thought I'd received when I bought the car" I thought it was a 1-shot sealant & pump "for emergency use only" deal; didn't realize the pump was supposed to be reusable. The first one of the factory ones that I used was on my 2007 Chrysler 300 SRT, the one that came in the trunk. About 30 seconds after I plugged it in, it blew the fuse. I've used the one on my 2010 Challenger SRT and so far it seems to work okay. I've also got an aftermarket one that I've used (a cheap one, I think it was a MotorTrend Promo deal) that works but I'm not sure how long it will last before it craps out.
[Re: AndyF]
#3221339
03/18/24 11:31 PM
03/18/24 11:31 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
Bought this 3 years ago. Bought the extra hefty 5a battery and charger. Around 120 bucks for the whole setup. Use it at the track, and extensively on a car lot I own. Light, dependable, cheap. One of the best gadgets I have ever bought In 3 years bet I haven’t had to recharge the thing 8-10 times total..and I use it. Flats. Low tires, adjust pressure at the track, etc, etc https://www.harborfreight.com/20v-c...si-inflatordeflator-tool-only-64533.html
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: Brad_Haak]
#3221369
03/19/24 09:09 AM
03/19/24 09:09 AM
Posts: 4,669 Wichita
GY3
Wichita
Been reading a lot of reviews on the portable inflators. The good ones aren't cheap, and the fact that I have no existing cordless tools with the same types of batteries & chargers makes the "all in" price a bit ridiculous... $300+ for a bleepin' mini air compressor w/ the necessary accessories. Good think I bought a new bicycle tire pump last year I bought the DeWalt DCC0201 mainly because I had their impact, drill, etc. and plenty of batteries. It was a screamin' deal at $100 but now I see they are over $140 in most stores. I use it way more than I thought I would as I keep it in the daily driver and someone always has a low tire at work or two wheel dolly needs air. I almost never fire up the big compressor in the shop anymore after getting this!
