stage 5 hemi heads #3217569
03/02/24 08:46 PM
03/02/24 08:46 PM
s. e. pa.
calrobb2000 Online content OP
calrobb2000  Online Content OP
s. e. pa.
hi
will stage 5 heads replace original 426 hemi heads or are here other changes needed to make them work with stock intake and exhaust ?
port shapes
port location
oiling
rocker gear
thank you !
Re: stage 5 hemi heads [Re: calrobb2000] #3217572
03/02/24 08:52 PM
03/02/24 08:52 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If they are the standard replacement heads they should go right on and use stock gear.
If they are the ones to put on a wedge head block the rocker gear is different and the top row of bolts are in the intake port instead of being a stud in the vaalley.
Re: stage 5 hemi heads [Re: calrobb2000] #3217587
03/02/24 10:17 PM
03/02/24 10:17 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
Awesome heads, look stock and fit like stock. Way better heads than most offerings these days. I bought a set of ported ones from Tim Banning at For Hemi's Only.
Re: stage 5 hemi heads [Re: 469runner] #3217597
03/02/24 10:54 PM
03/02/24 10:54 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have a pair of twin plug Stage V heads for my next twin turbo Hemi build.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: stage 5 hemi heads [Re: JohnRR] #3217610
03/03/24 12:23 AM
03/03/24 12:23 AM
s. e. pa.
s. e. pa.
hi .
sooooo there are only 2 types the stock replacment OR ones for wege engines ?
none for other odd combos , iis that right ? port locations , odd valve angles ect ?
thank you !
Re: stage 5 hemi heads [Re: calrobb2000] #3217620
03/03/24 02:27 AM
03/03/24 02:27 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
The replacement heads were available with stock exhaust port locations, or with raised exhaust ports. Standard headers will fit the raised port bolt pattern, but will cover the top 1/4" or so of the ports. So You need to know which you are buying.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: stage 5 hemi heads [Re: Hemi_Joel] #3217643
03/03/24 09:27 AM
03/03/24 09:27 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I was under the impression the Stage 5 head used a 2" installed height. I'm assuming the valves are longer than stock. If so how can the stock stands fit do to the fact that the valve stem heights are taller and further apart?
Doug
Re: stage 5 hemi heads [Re: dvw] #3217656
03/03/24 10:01 AM
03/03/24 10:01 AM
NY
B1duster Offline
B1duster  Offline
NY
http://www.stagev.com/pages/426hemihead.html
I think they had stopped offering the replacement heads. ???
The Custom heads are a better casting with semi finished dual plugs.
I have a set with standard exhaust port and 2.25 &1.94 valves.
I sent them to Ray Barton to have cnc ‘d.
https://www.raybarton.com/products/stage-v-bare-aluminum-hemi-head
Re: stage 5 hemi heads [Re: 469runner] #3217658
03/03/24 10:13 AM
03/03/24 10:13 AM
West Palm Beach, Florida
Craig J Offline
Craig J  Offline
Did you get them recently? I just got my BMP block, I want a set of heads that look stock for my Plymouth.
Thanks,
Craig
Re: stage 5 hemi heads [Re: Craig J] #3217673
03/03/24 10:55 AM
03/03/24 10:55 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
The Stage V guy died. Tim at FHO has bought Stage V. I don't know how long it will be before he has heads available. It will most likely take a while. Stage V's would look closest to stock but you do have a BMP block. If you want heads anytime soon, buy Edelbrocks. And they will cost you 1/2 as much. If you are looking at used Stage V's you will have to know which ones they are (there are a couple of different variations) and if they will work for you. I love Stage V's, but right now is a bad time to be needing some.
2011 Drag Pak Challenger
Re: stage 5 hemi heads [Re: rickseeman] #3217688
03/03/24 11:54 AM
03/03/24 11:54 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I have a pair from Tim. How do you tell which ones you have visually? Its never been clear to me how you tell the difference.
Re: stage 5 hemi heads [Re: mopar dave] #3217698
03/03/24 12:20 PM
03/03/24 12:20 PM
central il.
second 70 Offline
second 70  Offline
central il.
They had replacement heads that would work fine as stock and I believe the bigger performance heads were called millennial heads.
Re: stage 5 hemi heads [Re: mopar dave] #3217708
03/03/24 12:53 PM
03/03/24 12:53 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Of the heads they were selling for the last 10 or more years that we would use, the replacement heads were made from a 1965 street hemi casting head. So you will see the normal Mopar date tag on the left under the valve cover.
The custom heads will say HANSEN there.
Re: stage 5 hemi heads [Re: rickseeman] #3217732
03/03/24 02:10 PM
03/03/24 02:10 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Looks like I have the custom heads. What is the differences between the replacement head and the custom head? Not sure the TTI A body headers will fit my application.
Re: stage 5 hemi heads [Re: mopar dave] #3217734
03/03/24 02:17 PM
03/03/24 02:17 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
The custom heads have more meat in them for porting, strength etc. And you can get them in 16 plug, raised exhaust port, 21-1/2 degree exhaust angle etc. TTI does make headers for Stage V heads with raised exhaust port, but not in an A-body.
Re: stage 5 hemi heads [Re: rickseeman] #3217777
03/03/24 04:31 PM
03/03/24 04:31 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
That sucks. What are the header options for A body with the custom head?
Re: stage 5 hemi heads [Re: mopar dave] #3217785
03/03/24 05:08 PM
03/03/24 05:08 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I don't know of any except custom. We used to have a guy around here that built beautiful custom headers cheap, but that's not the case anymore.
Re: stage 5 hemi heads [Re: rickseeman] #3217940
03/04/24 09:23 AM
03/04/24 09:23 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Do the heads he have come standard with raised exh ports and the 2 1/2 angle change or are those options ?
Re: stage 5 hemi heads [Re: JohnRR] #3217942
03/04/24 09:26 AM
03/04/24 09:26 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I went to the stage v site and it looks like the custom heads can be ordered with different angle valve and raised or standard exhaust port. I do not know which i have.
Re: stage 5 hemi heads [Re: JohnRR] #3217947
03/04/24 10:04 AM
03/04/24 10:04 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
The raised exhaust ports and 1-1/2 exhaust angle change are options, like the 2.375" intake valve (or other sizes).
