Re: stage 5 hemi heads
[Re: calrobb2000]
#3217572
03/02/24 08:52 PM
03/02/24 08:52 PM
Posts: 75,002 U.S.S.A.
JohnRR
U.S.S.A.
If they are the standard replacement heads they should go right on and use stock gear.
If they are the ones to put on a wedge head block the rocker gear is different and the top row of bolts are in the intake port instead of being a stud in the vaalley.
[Re: 469runner]
#3217597
03/02/24 10:54 PM
03/02/24 10:54 PM
Posts: 4,565 Motor City
6PKRTSE
Motor City
I have a pair of twin plug Stage V heads for my next twin turbo Hemi build.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: calrobb2000]
#3217620
03/03/24 02:27 AM
03/03/24 02:27 AM
Posts: 7,489 Minnesota
Hemi_Joel
Minnesota
The replacement heads were available with stock exhaust port locations, or with raised exhaust ports. Standard headers will fit the raised port bolt pattern, but will cover the top 1/4" or so of the ports. So You need to know which you are buying.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: 469runner]
#3217658
03/03/24 10:13 AM
03/03/24 10:13 AM
Posts: 166 West Palm Beach, Florida
Craig J
Awesome heads, look stock and fit like stock. Way better heads than most offerings these days. I bought a set of ported ones from Tim Banning at For Hemi's Only. Did you get them recently? I just got my BMP block, I want a set of heads that look stock for my Plymouth. Thanks, Craig
[Re: Craig J]
#3217673
03/03/24 10:55 AM
03/03/24 10:55 AM
Posts: 2,641 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
The Stage V guy died. Tim at FHO has bought Stage V. I don't know how long it will be before he has heads available. It will most likely take a while. Stage V's would look closest to stock but you do have a BMP block. If you want heads anytime soon, buy Edelbrocks. And they will cost you 1/2 as much. If you are looking at used Stage V's you will have to know which ones they are (there are a couple of different variations) and if they will work for you. I love Stage V's, but right now is a bad time to be needing some.
2011 Drag Pak Challenger
[Re: mopar dave]
#3217708
03/03/24 12:53 PM
03/03/24 12:53 PM
rickseeman
Stuttgart, Arkansas
I have a pair from Tim. How do you tell which ones you have visually? Its never been clear to me how you tell the difference. Of the heads they were selling for the last 10 or more years that we would use, the replacement heads were made from a 1965 street hemi casting head. So you will see the normal Mopar date tag on the left under the valve cover. The custom heads will say HANSEN there.
[Re: mopar dave]
#3217734
03/03/24 02:17 PM
03/03/24 02:17 PM
rickseeman
Stuttgart, Arkansas
The custom heads have more meat in them for porting, strength etc. And you can get them in 16 plug, raised exhaust port, 21-1/2 degree exhaust angle etc. TTI does make headers for Stage V heads with raised exhaust port, but not in an A-body.
[Re: mopar dave]
#3217785
03/03/24 05:08 PM
03/03/24 05:08 PM
rickseeman
Stuttgart, Arkansas
I don't know of any except custom. We used to have a guy around here that built beautiful custom headers cheap, but that's not the case anymore.
[Re: rickseeman]
#3217940
03/04/24 09:23 AM
03/04/24 09:23 AM
JohnRR
U.S.S.A.
The custom heads have more meat in them for porting, strength etc. And you can get them in 16 plug, raised exhaust port, 21-1/2 degree exhaust angle etc. TTI does make headers for Stage V heads with raised exhaust port, but not in an A-body. Do the heads he have come standard with raised exh ports and the 2 1/2 angle change or are those options ?
[Re: JohnRR]
#3217947
03/04/24 10:04 AM
03/04/24 10:04 AM
rickseeman
Stuttgart, Arkansas
The custom heads have more meat in them for porting, strength etc. And you can get them in 16 plug, raised exhaust port, 21-1/2 degree exhaust angle etc. TTI does make headers for Stage V heads with raised exhaust port, but not in an A-body. Do the heads he have come standard with raised exh ports and the 2 1/2 angle change or are those options ? The raised exhaust ports and 1-1/2 exhaust angle change are options, like the 2.375" intake valve (or other sizes).
