Re: 68-72 B body fuel sending unit
[Re: MOPAULY]
#3216698
02/27/24 08:22 PM
02/27/24 08:22 PM
Posts: 5,783 ohio
ruderunner
ohio
72 tank is m9re cube shaped than 68 to70.
I'm going with no on this.
Angry white pureblood male
[Re: topside]
#3216769
02/28/24 10:21 AM
02/28/24 10:21 AM
Posts: 7,843 Spring Mount, PA
MOPAULY
Spring Mount, PA
Mounting, electrical and drop could be the same - maybe see if Rock Auto or whomever shows the same part # for the 2 years ? Or perhaps, the OP could modify the earlier unit. Yeah, since I have to drop the tank anyway, I may just buy an extra sending unit for my 68 and see if it fits properly in the tank.
[Re: 72roadrunnergtx]
#3216991
02/29/24 10:21 AM
02/29/24 10:21 AM
MOPAULY
Spring Mount, PA
There is nothing in common between the ’68-70 and the ’71-72 tanks or senders. Aeromotive sells a modified Spectrum 10a ’71 and up to mid-year ’72 efi fuel tank (vent ports on the driver’s side rear). Don’t see how it would fit however, the fuel pump ports are on top, top of the tank is right up against the trunk floor. That tank incorporates the feed and return lines at the fuel sending unit - they moved the vent lines to the drivers side rear; I'm just trying to avoid the $720 price tag. I did some measuring in the garage yesterday and I think the Holley drop in pump just might fit.
[Re: MOPAULY]
#3217266
03/01/24 01:11 PM
03/01/24 01:11 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
I made my own pick-up/return with pump for a pretty low cost. I also use a surge tank up front. Fuel flows to and from the surge tank at high volume, but near zero pressure. The surge tank to fuel rail return loop has the high pressure with no cavitation or air from a low main tank level even while road coursing with a couple gallons in the main tank.
Note the larger sized return line I silver soldered in to reduce fuel return restriction, and the submerged fuel line is rated submersible. Regular fuel line will disintegrate rapidly.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
