68-72 B body fuel sending unit #3216667
02/27/24 05:07 PM
02/27/24 05:07 PM
Spring Mount, PA
MOPAULY Offline OP
MOPAULY  Offline OP
Spring Mount, PA
Does anyone know if a 68-70 fuel sending unit will work with a 72? tanks are different but visually they look similar.
I ask as I am preparing to install a Holley Sniper EFI on my 72 Charger, and Holley makes an in tank electric pump/sending unit for the 68 - if I could use that it would save me the $720 of purchasing an Aeromotive tank with the EFI components pre-installed.
Re: 68-72 B body fuel sending unit [Re: MOPAULY] #3216698
02/27/24 08:22 PM
02/27/24 08:22 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
72 tank is m9re cube shaped than 68 to70.
I'm going with no on this.
Angry white pureblood male
Re: 68-72 B body fuel sending unit [Re: ruderunner] #3216721
02/27/24 10:44 PM
02/27/24 10:44 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Mounting, electrical and drop could be the same - maybe see if Rock Auto or whomever shows the same part # for the 2 years ?
Or perhaps, the OP could modify the earlier unit.
Re: 68-72 B body fuel sending unit [Re: topside] #3216769
02/28/24 10:21 AM
02/28/24 10:21 AM
Spring Mount, PA
MOPAULY Offline OP
MOPAULY  Offline OP
Spring Mount, PA
Yeah, since I have to drop the tank anyway, I may just buy an extra sending unit for my 68 and see if it fits properly in the tank.
Re: 68-72 B body fuel sending unit [Re: MOPAULY] #3216957
02/29/24 01:13 AM
02/29/24 01:13 AM
Shoreline, Washington
72roadrunnergtx Offline
There is nothing in common between the ’68-70 and the ’71-72 tanks or senders. Aeromotive sells a modified Spectrum 10a ’71 and up to mid-year ’72 efi fuel tank (vent ports on the driver’s side rear). Don’t see how it would fit however, the fuel pump ports are on top, top of the tank is right up against the trunk floor.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: 68-72 B body fuel sending unit [Re: 72roadrunnergtx] #3216991
02/29/24 10:21 AM
02/29/24 10:21 AM
Spring Mount, PA
MOPAULY Offline OP
MOPAULY  Offline OP
Spring Mount, PA
That tank incorporates the feed and return lines at the fuel sending unit - they moved the vent lines to the drivers side rear; I'm just trying to avoid the $720 price tag. I did some measuring in the garage yesterday and I think the Holley drop in pump just might fit.
Re: 68-72 B body fuel sending unit [Re: MOPAULY] #3217266
03/01/24 01:11 PM
03/01/24 01:11 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I made my own pick-up/return with pump for a pretty low cost. I also use a surge tank up front. Fuel flows to and from the surge tank at high volume, but near zero pressure. The surge tank to fuel rail return loop has the high pressure with no cavitation or air from a low main tank level even while road coursing with a couple gallons in the main tank.
Note the larger sized return line I silver soldered in to reduce fuel return restriction, and the submerged fuel line is rated submersible. Regular fuel line will disintegrate rapidly.
Re: 68-72 B body fuel sending unit [Re: jbc426] #3217274
03/01/24 01:37 PM
03/01/24 01:37 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Good to see your setup with a surge tank. Back in my Projection days I learned the hard way that just having the same in tank setup you have didn't work. It would suck air and kill the engine with a hard stop or turn at anything less than half a tank and as it got lower it happened even easier.
Re: 68-72 B body fuel sending unit [Re: Sniper] #3218209
03/05/24 04:34 AM
03/05/24 04:34 AM
California
E
ercynic Offline
ercynic  Offline
E
California
Could you please verify with Rock Auto or someone else whether the component number is the same for both years? It's possible that the mounting, electrical, and drop components are the same.
