POLY BLOCK/X/R12or3 #3210357
02/03/24 09:31 PM
02/03/24 09:31 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Have a poly block in the shop. Very thick cylinder walls. I'd say I can easily cut .070 minimum for a rebore. Is this poly block as strong as the X or R's.(Just looking at the thickness and weight of the block in general). W2 head well flowed. Looking to go 700HP(+/-).
Re: POLY BLOCK/X/R12or3 [Re: A/MP] #3210397
02/04/24 12:57 AM
02/04/24 12:57 AM
Washington
madscientist Offline
Washington
That Poly block isn’t even as strong as a TA block
Re: POLY BLOCK/X/R12or3 [Re: A/MP] #3210569
02/04/24 05:22 PM
02/04/24 05:22 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Did I miss something?
What does a W2 head have to do with a Poly?
Re: POLY BLOCK/X/R12or3 [Re: jcc] #3210586
02/04/24 05:50 PM
02/04/24 05:50 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
It will bolt to a poly block which can usually go .100 over. Add a 4.125 or 4.250 stroker crank and you get a big block displacement in a small block package.
Kevin
Re: POLY BLOCK/X/R12or3 [Re: Twostick] #3210628
02/04/24 08:31 PM
02/04/24 08:31 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I thought cam lobes have a different cam spacing and are intakes also interchangeable?
That weighs the same as a "B" block?
Re: POLY BLOCK/X/R12or3 [Re: jcc] #3210718
02/05/24 12:33 AM
02/05/24 12:33 AM
PA
Scully Offline
Scully  Offline
PA
The block doesn't weigh much more than an LA block, the heads and cast iron timing case cover are part of what made them weigh much more. The lobe spacing and angle are the same as a normal LA, just need an LA cam and pistons..90"over should be safe if the block checks good.
Re: POLY BLOCK/X/R12or3 [Re: jcc] #3210720
02/05/24 12:43 AM
02/05/24 12:43 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
I've seen people use LA blocks in place or Poly blocks, just not the other way around.
Alan Jones
Re: POLY BLOCK/X/R12or3 [Re: LA360] #3210768
02/05/24 10:16 AM
02/05/24 10:16 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
So it would be possible to put poly heads on an LA 360?
Re: POLY BLOCK/X/R12or3 [Re: 6PakBee] #3210970
02/05/24 10:02 PM
02/05/24 10:02 PM
LA360 Offline
LA360  Offline
Alan Jones
Re: POLY BLOCK/X/R12or3 [Re: LA360] #3211339
02/06/24 11:34 PM
02/06/24 11:34 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Less a few water and oil passages.
Re: POLY BLOCK/X/R12or3 [Re: 6PakBee] #3211378
02/07/24 07:50 AM
02/07/24 07:50 AM
Cab_Burge Online work
Cab_Burge  Online Work
why would you want to? confused shruggy
Re: POLY BLOCK/X/R12or3 [Re: Cab_Burge] #3211386
02/07/24 08:56 AM
02/07/24 08:56 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
To be different? grin
Its an affliction some have.
Re: POLY BLOCK/X/R12or3 [Re: jcc] #3211435
02/07/24 11:31 AM
02/07/24 11:31 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
To build a Q-ship poly. up
Re: POLY BLOCK/X/R12or3 [Re: 6PakBee] #3212268
02/09/24 06:27 PM
02/09/24 06:27 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
X and R blocks are hard to come by and pricey. Just looking to see if could be an alternative.
