Re: POLY BLOCK/X/R12or3
[Re: A/MP]
#3210397
02/04/24 12:57 AM
02/04/24 12:57 AM
Posts: 4,457 Washington
madscientist
Washington
Have a poly block in the shop. Very thick cylinder walls. I'd say I can easily cut .070 minimum for a rebore. Is this poly block as strong as the X or R's.(Just looking at the thickness and weight of the block in general). W2 head well flowed. Looking to go 700HP(+/-). That Poly block isn’t even as strong as a TA block
[Re: A/MP]
#3210569
02/04/24 05:22 PM
02/04/24 05:22 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Have a poly block in the shop. Very thick cylinder walls. I'd say I can easily cut .070 minimum for a rebore. Is this poly block as strong as the X or R's.(Just looking at the thickness and weight of the block in general). W2 head well flowed. Looking to go 700HP(+/-). Did I miss something? What does a W2 head have to do with a Poly?
[Re: jcc]
#3210586
02/04/24 05:50 PM
02/04/24 05:50 PM
Posts: 6,562 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Have a poly block in the shop. Very thick cylinder walls. I'd say I can easily cut .070 minimum for a rebore. Is this poly block as strong as the X or R's.(Just looking at the thickness and weight of the block in general). W2 head well flowed. Looking to go 700HP(+/-). Did I miss something? What does a W2 head have to do with a Poly? It will bolt to a poly block which can usually go .100 over. Add a 4.125 or 4.250 stroker crank and you get a big block displacement in a small block package. Kevin
[Re: Twostick]
#3210628
02/04/24 08:31 PM
02/04/24 08:31 PM
jcc
Bitopia
I thought cam lobes have a different cam spacing and are intakes also interchangeable? That weighs the same as a "B" block?
[Re: jcc]
#3210718
02/05/24 12:33 AM
02/05/24 12:33 AM
Posts: 201 PA
Scully
PA
I thought cam lobes have a different cam spacing and are intakes also interchangeable? That weighs the same as a "B" block? The block doesn't weigh much more than an LA block, the heads and cast iron timing case cover are part of what made them weigh much more. The lobe spacing and angle are the same as a normal LA, just need an LA cam and pistons..90"over should be safe if the block checks good.
[Re: LA360]
#3210768
02/05/24 10:16 AM
02/05/24 10:16 AM
Posts: 10,721 North Dakota
6PakBee
North Dakota
I've seen people use LA blocks in place or Poly blocks, just not the other way around. So it would be possible to put poly heads on an LA 360?
[Re: 6PakBee]
#3211378
02/07/24 07:50 AM
02/07/24 07:50 AM
Posts: 43,193 Bend,OR USA
Cab_Burge
I've seen people use LA blocks in place or Poly blocks, just not the other way around. So it would be possible to put poly heads on an LA 360? why would you want to?
[Re: Cab_Burge]
#3211386
02/07/24 08:56 AM
02/07/24 08:56 AM
jcc
Bitopia
To be different? Its an affliction some have.
[Re: jcc]
#3211435
02/07/24 11:31 AM
02/07/24 11:31 AM
6PakBee
North Dakota
To be different? Its an affliction some have. To build a Q-ship poly.
