Stroker Measurement #3205677
01/17/24 04:34 PM
01/17/24 04:34 PM
New Zealand
dart6 Offline OP
dart6  Offline OP
New Zealand
I've got a RR with a 440 stroker that was purchased from a deceased estate without paperwork for the engine build. I've had a few 440s and this is definitely stroked.
Is there a way to determine the displacement with the engine in the car through the spark plug.
Re: Stroker Measurement [Re: dart6] #3205680
01/17/24 04:40 PM
01/17/24 04:40 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
There is a tool that can measure the volume of air that is drawn into the cylinder , not sure what it is called but they use it at some races to check engine cubic inches without taking the engine apart.
Re: Stroker Measurement [Re: dart6] #3205681
01/17/24 04:44 PM
01/17/24 04:44 PM
Cab_Burge Online work
Cab_Burge  Online Work
Yes up but it ain't easy.
Bring up one piston, it will have two pistons at TDC at the same time, one per side, and then use a semi thick liquid to fill that one cylinder until it starts to run out the spark plug hole and then find one of the other two pistons that are at bottom dead center and do the same thing on one of those pistons, do the math on difference between the two and that will get you in the ballpark, NOT dead nuts perfect though tsk grin You can use one of the online calculators and add some more CC for head combustion chamber size to get you in the ballpark wrench scope work twocents
Re: Stroker Measurement [Re: dart6] #3205682
01/17/24 04:48 PM
01/17/24 04:48 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
It's a P and G gauge. Below is some instructions on how they are used. Not your everyday, common tool though. Might be quicker to pull the pan and / or a head to check. PITA If it's running OK.
https://www.precisionmeasure.com/product/cubic-inch-tester-500-670-800/
Re: Stroker Measurement [Re: dart6] #3205684
01/17/24 04:54 PM
01/17/24 04:54 PM
AndyF Offline
AndyF  Offline
No easy way with the heads on, especially if the engine is in the car. If the engine is on an engine stand then you can rotate it over and fill the cylinder with fluid to get a measurement. If it is in the car then just make up a number that your happy with.
Re: Stroker Measurement [Re: AndyF] #3205751
01/17/24 08:24 PM
01/17/24 08:24 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
A P&G gauge is over $1,000. I don't have one and I don't know anyone that does.
2011 Drag Pak Challenger
Re: Stroker Measurement [Re: dart6] #3205765
01/17/24 08:53 PM
01/17/24 08:53 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
A stroker will be increasing the displacement through not so subtle extra stroke...so I'm thinking here that knowing the factory deck height, you might be able to literally put a metering stick of some sorts down the spark plug hole,and as perpendicular to the piston head as possible, and literally measure the distance it travels down into the bore as the piston goes to BDC.
Again, this is entirely relying on that "extra stroker" being around that 0.500" or greater measure....thus "not so subtle" as to be undetectable through such a simple measurement.
Crazy??? ...ummm, maybe, but if you have a compare baseline of some sorts you might be able to guesstime the number you are after!
Re: Stroker Measurement [Re: dart6] #3205869
01/18/24 01:13 PM
01/18/24 01:13 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
For what effort you want to do, Cab's method (or some variation) is the best IMO.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Stroker Measurement [Re: rickseeman] #3205878
01/18/24 01:36 PM
01/18/24 01:36 PM
an8sec70cuda Offline
Just thought this was funny...I remember hearing for some classes they were gonna tech cars w/ a P&G gauge. I've never seen a P&G gauge or saw a car getting checked w/ one, lol.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Stroker Measurement [Re: an8sec70cuda] #3205901
01/18/24 02:49 PM
01/18/24 02:49 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Only one I have ever seen was on drag week. They pump the winners of the classes with cubic inch limits. I think the pump the classes with cubic inch minimums even. There has been some small block cars win big block classes because drag week considers over 430" a big block unless it is a big block by architecture like a 383 chrysler or 396 chevrolet.
68 Barracuda Formula S 340
Re: Stroker Measurement [Re: Bad340fish] #3205939
01/18/24 03:44 PM
01/18/24 03:44 PM
New Zealand
dart6 Offline OP
dart6  Offline OP
New Zealand
I'm getting there is no easy way here. Thanks for your responses
Re: Stroker Measurement [Re: an8sec70cuda] #3205976
01/18/24 05:23 PM
01/18/24 05:23 PM
NHRA use to pump the Pro Stocker back in the days of different C.I. per pounds based on the cylinder heads during pre race tech wrench shruggy
Re: Stroker Measurement [Re: Cab_Burge] #3205983
01/18/24 06:00 PM
01/18/24 06:00 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Round tracks used to use a P & G machine to "pump up" a engine. (it used air to measure the volume) If you know any round track guys local, you may ask them. Not sure if they're used any longer, with so many tracks using "crate" engines (which are sealed). Most just make you pull a cyl head if any question.
But like others have said, it's just a number. What matters is how it runs.
Brian
Re: Stroker Measurement [Re: '72CudaRacer] #3207163
01/22/24 01:04 PM
01/22/24 01:04 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Do you have to know the exact Displacement or just 100% verify that it has been stroked?
Assuming the motor is out of the car and you can put the deck horizontal to the floor/tabe....just get a piston to BDC and pull a plug and keep putting a measurable volume of Marvel mystery oil (or some other light motor oil) compatible fluid into it. allowing some measurable displacement for the distance between the deck height, the head gacsket thickness and the approx distance between the head deck surface and the bottom of the spark plug hole, you can get pretty close. Of course your gonna be off by a bit for combustion chamber and piston eyebrows/dish/dome, but if you just want to do it quick and dirty that will work for a rough guess. A .030 over zero deck 440 would be about 913 ccs (just a little over a quart) plus whatever the make up distance (i mention above would be) is .
so a 4.15 stroke would already take over a litre (a couple ounces more than a quart) to fill just to the deck height. That (conveniently) seems pretty easy to determine.
To empty it, make some sort of nozzle that screws into the spark plug hole and run it through a hose and turn the crank.
WIZE
In Car:
Re: Stroker Measurement [Re: '72CudaRacer] #3207177
01/22/24 01:37 PM
01/22/24 01:37 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Brian
That's what they used at our local dirt track.
My late machinist used to run in a 6 cylinder class back in the 70's. Engine of choice was 292 GM, 300 cube limit IIRC.They noticed when tech checked an engine, they only ever pumped #1 cylinder... Out came the engine, crank sent out to have journals 2 thru 6 offset ground to as much stroke as could be accommodated by whatever junkyard rods and shelf pistons were available.
She was a winner! Lol
Kevin
Re: Stroker Measurement [Re: Streetwize] #3207253
01/22/24 05:12 PM
01/22/24 05:12 PM
New Zealand
dart6 Offline OP
dart6  Offline OP
New Zealand
It does't have to be accurate and engine is in the car
Re: Stroker Measurement [Re: dart6] #3207434
01/23/24 09:44 AM
01/23/24 09:44 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Well....I guess (using some trig) you can figure out the volume of a 440 cylinder layed on a 45 degree angle vs a larger 496 and apply the same test
WIZE
In Car:
