Need front sway bar frame brackets
#3204275
01/13/24 09:55 AM
01/13/24 09:55 AM
Posts: 8,844 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
I didn't see a sub page to post this in.... I need a pair of the brackets that bolt to the frame rails that hold the front bushings up (sway bar bushings) Need to be from a 80s up to at least 1990 dodge truck ramcharger (d100/d150)2 wheel drive NOT 4x4 as they are totally different Thank you
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: Need front sway bar frame brackets
[Re: toplescuda]
#3204277
01/13/24 10:01 AM
01/13/24 10:01 AM
Posts: 5,792 ohio
ruderunner
ohio
Iirc they're nothing fancy, could be made from channel though I believe OEM were Z shaped.
Angry white pureblood male
[Re: ruderunner]
#3204523
01/14/24 09:12 AM
01/14/24 09:12 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
Yes they are nothen fancy. At the moment I have no way of fab any of them
[Re: toplescuda]
#3204543
01/14/24 11:11 AM
01/14/24 11:11 AM
Posts: 16,141 Mesa, Arizona
dart4forte
Mesa, Arizona
I didn't see a sub page to post this in.... I need a pair of the brackets that bolt to the frame rails that hold the front bushings up (sway bar bushings) Need to be from a 80s up to at least 1990 dodge truck ramcharger (d100/d150)2 wheel drive NOT 4x4 as they are totally different Thank you I think I have a couple in my suspension box.
Abe Lincoln
[Re: dart4forte]
#3204894
01/15/24 05:43 AM
01/15/24 05:43 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
That would be awsome if you did. Let me know please
[Re: toplescuda]
#3205330
01/16/24 06:47 PM
01/16/24 06:47 PM
dart4forte
Mesa, Arizona
Sorry, got waylaid, I’ll check tomorrow. Just to be clear, you need the two front brackets?
Abe Lincoln
[Re: toplescuda]
#3205331
01/16/24 07:00 PM
01/16/24 07:00 PM
dart4forte
Mesa, Arizona
That would be awsome if you did. Let me know please Ran out to the shop, I have a PST packaged brackets and bushings
Abe Lincoln
[Re: NITROUSN]
#3206280
01/19/24 05:32 PM
01/19/24 05:32 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
I think I located a pair. Will know f9r sure this weekend. Thanks guys
[Re: toplescuda]
#3208812
01/28/24 03:54 PM
01/28/24 03:54 PM
Posts: 570 USA
Hooligan
USA
If all else fails. I had a1974 D100 without the factory front sway bar. I'm not sure what year trucks have the same frames. Well, I wanted a larger diameter anyway. I bought a 1.125" bar from a '72 Chevy C10. It came with mounting brackets, which I bolted right to the bottom of the frame rails.
Looked way better than the factory bar hanging down bellow the strut rods. Dilled holes in the lower control arms for the supplied 90 degree brackets. Just had to grind a little clearance on the lower control arms for the end link bolts.
[Re: Hooligan]
#3208942
01/29/24 01:44 AM
01/29/24 01:44 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
I have found some brackets. Thanks every one
