1971 Thermoquad? #3198780
12/19/23 11:19 PM
12/19/23 11:19 PM
Myrtle Beach, SC formerly the ...
340wedge Offline OP
340wedge  Offline OP
Okay here goes, I just purchased two 4973 1971 Thermoquads which were advertised as parts carburetors. One is complete, one is mostly complete. The air/fuel mixture needles are broken in both base plates. I am thinking am easy out to remove the broken off needles. or drilling and re-tapping? Either way I need to purchase new air/fuel mixture needles. Does anyone know the part# or size of them? I see many years for them but not 1971 which I know if a one year only animal. Thank you !
1971 Sassy Grass Green Duster 340
2006 Charger Daytona GoMango
Re: 1971 Thermoquad? [Re: 340wedge] #3198855
12/20/23 12:11 PM
12/20/23 12:11 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
If you don't get the answers you need here, you might try this group on Facebook.
https://www.facebook.com/groups/254276841687055
If the link does not work it is titled:
Carter Thermoquad Club/MANLEY Thermoquads
Re: 1971 Thermoquad? [Re: 340wedge] #3198864
12/20/23 12:58 PM
12/20/23 12:58 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Can't help you with part numbers, but take a look at the attached section of the Carter TQ Service Manual. If you want the full PDF you can grab it HERE.
In fact, I've got a couple more things sitting on my Web server, so check these out:
1) 1972 TQ Mopar Reference Booklet
2) 1982 TQ Mopar Reference Booklet
There were two types of idle mix screws used, and while it does NOT spell out the details and/or differences for the '71-only air circuit, one could expect this to be a reasonable assumption. Further on, when you successfuly extract what's stuck in there right now you'll be able to measure this.
Re: 1971 Thermoquad? [Re: 340wedge] #3198899
12/20/23 03:29 PM
12/20/23 03:29 PM
You mess up buying them pieces of crap tsk shruggy
There were many resaons Carter made those carbs for one year only work shruggy
I hope you do well with them, no matter your intentions are on, with, them up luck
Re: 1971 Thermoquad? [Re: Cab_Burge] #3198901
12/20/23 03:37 PM
12/20/23 03:37 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Years ago I was told by a very knowledgeable individual that the 71 TQ's were based off the carter competition series thermoquad's. I have also read the same in several articles. Might be of some help wink
Re: 1971 Thermoquad? [Re: Cab_Burge] #3199177
12/21/23 04:52 PM
12/21/23 04:52 PM
MN
Droop69 Offline
Droop69  Offline
MN
Maybe he needs one for a correct 340 application. 1971 Thermoquads are a one year only application, guys are always looking for them.
Re: 1971 Thermoquad? [Re: Droop69] #3199203
12/21/23 06:31 PM
12/21/23 06:31 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
That carb turned strong 340 Stockers into record-holders - like the car in my sig pic.
Many a '70 got '71 trim to take that advantage.
Had one on a 408" SB street Duster that was done by Demonsizzler, and it was utterly perfect.
And yeah, good ones are $$$ to the right guys.
Re: 1971 Thermoquad? [Re: topside] #3199275
12/21/23 10:45 PM
12/21/23 10:45 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Found these on the bay LINKY part # is per the listing is 30A 207
shruggy beer
Re: 1971 Thermoquad? [Re: TJP] #3199284
12/21/23 11:06 PM
12/21/23 11:06 PM
340wedge Offline OP
340wedge  Offline OP
Thank you !
Re: 1971 Thermoquad? [Re: Cab_Burge] #3199302
12/22/23 12:49 AM
12/22/23 12:49 AM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
CAB you know better than that. 71 is the best factory carb ever.
Real Men shift for themselves
Re: 1971 Thermoquad? [Re: 1DGEMAN] #3199347
12/22/23 10:24 AM
12/22/23 10:24 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
From the stock guys, 71 carb is faster than later carbs. 71 is a total different animal. I one good one from 2 cores to use if I run 71 TQ or 70 AVS.
Re: 1971 Thermoquad? [Re: 340wedge] #3199423
12/22/23 02:49 PM
12/22/23 02:49 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted by 340wedge
Thank you !
you're welcome wink
I do have a old carter book from the 70's and a bunch of carb parts but they are not organized frown Seriously doubt I would have the mixture screws. Metering rods, jets, a few AVS cores (bare) If you get in a pinch PM me with your needs and give me few days to dig through what's there.
My intent at some point is to try and sell all as a lot wink
Re: 1971 Thermoquad? [Re: TJP] #3199528
12/22/23 11:19 PM
12/22/23 11:19 PM
340wedge Offline OP
340wedge  Offline OP
Thank you again TJP!
Re: 1971 Thermoquad? [Re: 1DGEMAN] #3199555
12/23/23 04:01 AM
12/23/23 04:01 AM
haha whistling work stirthepot
I liked racing the Max Wedges, street hemis and six pack cars: up: twocents
