1971 Thermoquad?
#3198780
12/19/23 11:19 PM
12/19/23 11:19 PM
Posts: 2,763 Myrtle Beach, SC formerly the ...
340wedge
Okay here goes, I just purchased two 4973 1971 Thermoquads which were advertised as parts carburetors. One is complete, one is mostly complete. The air/fuel mixture needles are broken in both base plates. I am thinking am easy out to remove the broken off needles. or drilling and re-tapping? Either way I need to purchase new air/fuel mixture needles. Does anyone know the part# or size of them? I see many years for them but not 1971 which I know if a one year only animal. Thank you !
1971 Sassy Grass Green Duster 340 2006 Charger Daytona GoMango
Re: 1971 Thermoquad?
[Re: 340wedge]
#3198864
12/20/23 12:58 PM
12/20/23 12:58 PM
Posts: 1,760 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
Can't help you with part numbers, but take a look at the attached section of the Carter TQ Service Manual. If you want the full PDF you can grab it HERE. In fact, I've got a couple more things sitting on my Web server, so check these out: 1) 1972 TQ Mopar Reference Booklet2) 1982 TQ Mopar Reference BookletThere were two types of idle mix screws used, and while it does NOT spell out the details and/or differences for the '71-only air circuit, one could expect this to be a reasonable assumption. Further on, when you successfuly extract what's stuck in there right now you'll be able to measure this.
[Re: Cab_Burge]
#3199302
12/22/23 12:49 AM
12/22/23 12:49 AM
Posts: 608 TN
1DGEMAN
TN
CAB you know better than that. 71 is the best factory carb ever.
Real Men shift for themselves
[Re: 340wedge]
#3199423
12/22/23 02:49 PM
12/22/23 02:49 PM
Posts: 15,377 Omaha Ne
TJP
Omaha Ne
you're welcome I do have a old carter book from the 70's and a bunch of carb parts but they are not organized Seriously doubt I would have the mixture screws. Metering rods, jets, a few AVS cores (bare) If you get in a pinch PM me with your needs and give me few days to dig through what's there. My intent at some point is to try and sell all as a lot
[Re: 1DGEMAN]
#3199555
12/23/23 04:01 AM
12/23/23 04:01 AM
Posts: 43,200 Bend,OR USA
Cab_Burge
