New modified cut/welded tranny X-member brace #3197815
12/15/23 08:59 PM
12/15/23 08:59 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
I've seen pictures where guys have cut out the crossmember arch that goes over and across the tranny,
then they tied the two cut "ends" together with a reinforced straight piece, under the tranny.
Does anyone make a bolt-on piece that does this ? I'm talking B and E body. A-body I don't know.
You would need to do this if your putting in a physically bigger tranny and need to cut out the tranny tunnel.
Re: New modified cut/welded tranny X-member brace [Re: hemienvy] #3197845
12/16/23 12:07 AM
12/16/23 12:07 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Understand the forces induced here if OEM TB's are still in play, plus the weight the trans mount carries.
If it is a converted coil IFS, the forces are much reduced on this crossmember.
Crash worthiness is another discussion, a cage with a dash bar kinda also needs a lower member to keep the cage in place in that area.
Re: New modified cut/welded tranny X-member brace [Re: hemienvy] #3197860
12/16/23 12:48 AM
12/16/23 12:48 AM
AndyF Offline
AndyF  Offline
Yeah I did that about 30 years ago on my Coronet when I switched over to a Doug Nash 5 speed. It has worked okay over the years. I have a picture of the crossmember that I built back then. I've replaced it with a better design but I don't think I have a picture of the new design.
Re: New modified cut/welded tranny X-member brace [Re: AndyF] #3197961
12/16/23 01:41 PM
12/16/23 01:41 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I cut the floor brace out as needed and on the passenger side splice in a 180°bend of 1-5/8 or 1-3/4 tubing to the oem bracing. On the driver side you can land the tubing perpendicular to the boxed section of the brace. I holesaw through the bottom for weld access.
Re: New modified cut/welded tranny X-member brace [Re: Jeremiah] #3197969
12/16/23 02:57 PM
12/16/23 02:57 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Thanks guys, I could probably practice my butchering techniques,
but I could have sworn I saw somebody that made one.
Can't remember what I put in the search engine.
Re: New modified cut/welded tranny X-member brace [Re: hemienvy] #3197973
12/16/23 03:31 PM
12/16/23 03:31 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
I would think that someone could map out the floor contour.
Then fab tooling (maybe using CAD or whatever) to make a shallower but thicker replacement piece.
Or maybe make a 1/4" plate, formed to match the floor contour, for welding in.
There would seem to be a market for such a thing.
Re: New modified cut/welded tranny X-member brace [Re: hemienvy] #3198169
12/17/23 04:46 PM
12/17/23 04:46 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
BigDad made a really nice crossmember for his silver 64 Plymouth with pics posted many years ago.
Gus beer
64 Plymouth Savoy
Dana 60
Re: New modified cut/welded tranny X-member brace [Re: hemienvy] #3198181
12/17/23 05:38 PM
12/17/23 05:38 PM
AndyF Offline
AndyF  Offline
US Car Tool sells a variety of Mopar transmembers for different swaps and such.
https://store.uscartool.com/
Re: New modified cut/welded tranny X-member brace [Re: AndyF] #3198249
12/17/23 08:29 PM
12/17/23 08:29 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Thanks Andy, I guess those will all work with the OE top connector hoop cut out.
Possibly I'm trying to remember something that I never actually saw.
If I used one of those crossmembers, I would increase the size of the bolts holding it in.
The forces from the T-bars cannot be allowed to flex the floor area.
Re: New modified cut/welded tranny X-member brace [Re: hemienvy] #3198353
12/18/23 10:56 AM
12/18/23 10:56 AM
Maryland
mrob Offline
mrob  Offline
Maryland
Here's an option for a 66-70 B-body. It looks beefy enough to withstand the forces of the torsion bar suspension.
Hope this helps.
https://www.holley.com/products/engine_swap_parts/mounts_and_crossmembers/crossmembers/parts/BHS539
Re: New modified cut/welded tranny X-member brace [Re: mrob] #3198364
12/18/23 11:59 AM
12/18/23 11:59 AM
A collage of whims
A collage of whims
That Holley design looks a lot like what I was thinking, but it seems to capture the trans crossmember.
Not the end of the world, though, I suppose.
But I'd prefer a welded upper arch; maybe a short sleeve at each side for the T-bar member.
Re: New modified cut/welded tranny X-member brace [Re: mrob] #3198379
12/18/23 01:02 PM
12/18/23 01:02 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
That Holley thing looks interesting.
Re: New modified cut/welded tranny X-member brace [Re: hemienvy] #3198409
12/18/23 03:45 PM
12/18/23 03:45 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
1/2" steel strap? eek
Re: New modified cut/welded tranny X-member brace [Re: topside] #3198678
12/19/23 04:58 PM
12/19/23 04:58 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I used a 1/4" steel plate about 4 inches wide and just over 2 feet long welded through the floor pan to the top on the remaining cross member. I had to heat the steel band red hot to bend it and spent time getting it to match the original floor's contour.
I also welded most of the original torsion cross member solidly to the floor pan when I installed the full US Cartool Chassis Stiffening kit. I cut the actual tunnel portion of the cross member down flush, but left the factory flanges and boxed the bottom of the trimmed crossover back in with like-sized steel. I did this fab work with the torsion bars out.
In my case, this was done to fit an overdrive automatic. I may soon be doing further modification, as I'm putting in an even larger automatic to accommodate a more powerful engine.
These are the only pictures that I currently have of the lower modified crossover. I was able to retain the factory cross member bolt locations.
