Brake parts, what are they for? #3190040
11/10/23 12:30 PM
11/10/23 12:30 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
I had a friend just drop off some disc brake parts and I don't recognize them straight off. The resemble Dodge Dakota to me but I doubt that's what they're for.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Brake parts, what are they for? [Re: cdstl] #3190058
11/10/23 01:44 PM
11/10/23 01:44 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Looks like B van to me
Angry white pureblood male
Re: Brake parts, what are they for? [Re: cdstl] #3190073
11/10/23 02:49 PM
11/10/23 02:49 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
Someone had suggested '73-'74 B body.
Re: Brake parts, what are they for? [Re: cdstl] #3190145
11/10/23 09:13 PM
11/10/23 09:13 PM
IMGTX Offline
IMGTX  Offline
My 73 & 74's have pin type calipers but aside from that they look just like those assemblies.
Maybe later B, C or M body? shruggy
Re: Brake parts, what are they for? [Re: IMGTX] #3190192
11/11/23 12:57 AM
11/11/23 12:57 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
Does you car have the bar that goes between both bushings on the control arm like this one has?
Re: Brake parts, what are they for? [Re: cdstl] #3190207
11/11/23 08:48 AM
11/11/23 08:48 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
From Cass aka Dr. Diff
F/M/J body front disc brakes. If you remove the upper control arms, they will also fit B/E (and '73-'76 A-bodies) bodies.
Thanks Cass.
Re: Brake parts, what are they for? [Re: cdstl] #3190224
11/11/23 10:57 AM
11/11/23 10:57 AM
IMGTX Offline
IMGTX  Offline
Yes. On the 73 and up isolated K frame B bodies they have that bar between the control arm bushings.
The upper control arms are not mounted to the body but a bracket mounted to the K Frame.
