Brake parts, what are they for?
#3190040
11/10/23 12:30 PM
11/10/23 12:30 PM
Posts: 1,487 STL
cdstl
STL
I had a friend just drop off some disc brake parts and I don't recognize them straight off. The resemble Dodge Dakota to me but I doubt that's what they're for.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Brake parts, what are they for?
[Re: cdstl]
#3190073
11/10/23 02:49 PM
11/10/23 02:49 PM
Posts: 1,487 STL
cdstl
STL
Someone had suggested '73-'74 B body.
[Re: IMGTX]
#3190192
11/11/23 12:57 AM
11/11/23 12:57 AM
Posts: 1,487 STL
cdstl
STL
Does you car have the bar that goes between both bushings on the control arm like this one has?
[Re: cdstl]
#3190207
11/11/23 08:48 AM
11/11/23 08:48 AM
Posts: 1,487 STL
cdstl
STL
From Cass aka Dr. Diff
F/M/J body front disc brakes. If you remove the upper control arms, they will also fit B/E (and '73-'76 A-bodies) bodies.
Thanks Cass.
[Re: cdstl]
#3190224
11/11/23 10:57 AM
11/11/23 10:57 AM
Posts: 12,234 Looking for a way out of Middl...
IMGTX
Does you car have the bar that goes between both bushings on the control arm like this one has? Yes. On the 73 and up isolated K frame B bodies they have that bar between the control arm bushings. The upper control arms are not mounted to the body but a bracket mounted to the K Frame.
