70 E body slant 6 to 440 #3187983
11/01/23 08:26 AM
11/01/23 08:26 AM
United States
Z
Z70challenger Offline OP
Z
United States
Hi guys,
I have a 70 challenger, original slant 6 auto on the column. I am looking to put a 440 in the car. I’m looking to see if there was big blocks auto on the column and if I can use the same steering column to do so?
Re: 70 E body slant 6 to 440 [Re: Z70challenger] #3187991
11/01/23 09:02 AM
11/01/23 09:02 AM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
That would more depend on what trans you have now, 727? recycle the existing shift linkage, though kick down will be different.
If a 904 style, I dunno, not an E body guy. But I also have never done a 904 to 727 swap so there may not even be an issue there either? I tend to go automatic to stick in my transmission swaps.
Re: 70 E body slant 6 to 440 [Re: Sniper] #3188010
11/01/23 10:58 AM
11/01/23 10:58 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Yes, there were big blocks with auto on the column. You might have to scrounge around for parts but they exist.
2011 Drag Pak Challenger
Re: 70 E body slant 6 to 440 [Re: rickseeman] #3188027
11/01/23 12:06 PM
11/01/23 12:06 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
If you are going to a V8 from a /6, the gearshift is probably the most minor problem you'll have. Brakes and suspension are the first two that come to mind.
Re: 70 E body slant 6 to 440 [Re: 6PakBee] #3188099
11/01/23 05:02 PM
11/01/23 05:02 PM
United States
Z
Z
United States
Ok thank you all for the posts. Maybe it’s worth doing it on the floor? Are there any good websites/books, etc that people recommend for a good source of info for a slant 6 to big block conversion?
Re: 70 E body slant 6 to 440 [Re: Sniper] #3188100
11/01/23 05:03 PM
11/01/23 05:03 PM
United States
Z
Z
United States
Interesting..ok I will take a look. It is a 904 to 727 swap….
Re: 70 E body slant 6 to 440 [Re: Z70challenger] #3188116
11/01/23 06:37 PM
11/01/23 06:37 PM
rust belt
Moparite Offline
Moparite  Offline
rust belt
You need to replace the K frame.
Re: 70 E body slant 6 to 440 [Re: Moparite] #3188187
11/02/23 03:09 AM
11/02/23 03:09 AM
iagree wrench up
I would replace the torsion bars and front brakes if your car has small (nine inch) front brakes also like a lot of the slant six cars had originally scope up
I'm not sure about the stock front brake size on the E bodies though confused
Re: 70 E body slant 6 to 440 [Re: Cab_Burge] #3188231
11/02/23 10:26 AM
11/02/23 10:26 AM
IMGTX Offline
IMGTX  Offline
My /6 has 9 inch brakes front and rear.
It also has a 7-1/4 axle with smaller U-bolts. I would swap the rear axle and you will need shock plates.
Going from 904 to 727 will also require new driveshaft and yoke.
A lot of suspension & linkage can come from B bodies. 71 and 72 are almost identical except axle widths and driveshaft lengths. A lot of suspension & linkage can come from 70 and older B body and some linkage from 73 and later b body. Its hit or miss on the linkage after 72.
The /6 will probably not have a sway bar and you will want one. Aftermarket assembly or new tabs/lower control arms if going oem.
I am not sure about the front spindles and upgrading the brakes but spindles from mid 60's b body to 72 b body will work.
Maybe more years.
The wiring is the same but connectors are located in different locations V8 to /6. A little lengthening or shortening of the wiring will be easy.
Re: 70 E body slant 6 to 440 [Re: Z70challenger] #3188298
11/02/23 03:51 PM
11/02/23 03:51 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Originally Posted by Z70challenger
Hi guys,
Probably more "rare" leaving it the way it is . . . yes, I know how tempting it is to change things - after all, it is YOUR car - do what you want with it !! . . .
Cheers,
Mark
Re: 70 E body slant 6 to 440 [Re: a12rag] #3188363
11/02/23 09:14 PM
11/02/23 09:14 PM
SE-WI
skdmark Offline
skdmark  Offline
SE-WI
Don't forget the radiator.
Re: 70 E body slant 6 to 440 [Re: skdmark] #3188431
11/03/23 09:35 AM
11/03/23 09:35 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Best bet is to find yourself a rotted out C-body with a 440/727 and a K-frame and just transfer engine and transmission over. I did have to grind a bit on one side of the radiator mounting to clear a frame rail and re-drill one hole as I recall. Pretty easy stuff, though.
I did that with a '71 Barracuda and it worked great! The /6 torsion bars work better if you're going to drag race it anyway.
'63 Dodge 330
11.19 @ 121 mph
Re: 70 E body slant 6 to 440 [Re: GY3] #3188465
11/03/23 12:20 PM
11/03/23 12:20 PM
moparx Offline
moparx  Offline
back in my junkyard ownership days, guys would grab a 383/440 with 727 out of a C-body, then we would cut off the mounts from the C-body K frame.
these would be bolted to the engine, then with the /6 mounts cut from whatever K the buyer was working on, the engine and transmission was lowered into the car, the mounts were tacked onto the K, engine/transmission removed, then the mounts were welded into place.
back then, nobody removed the K. just pulled the engine from the top.
crude, and far from correct, but a ton were done this way and worked out great.
beer
