Re: 70 E body slant 6 to 440
[Re: Sniper]
#3188010
11/01/23 10:58 AM
11/01/23 10:58 AM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Yes, there were big blocks with auto on the column. You might have to scrounge around for parts but they exist.
2011 Drag Pak Challenger
[Re: rickseeman]
#3188027
11/01/23 12:06 PM
11/01/23 12:06 PM
Posts: 10,731 North Dakota
6PakBee
North Dakota
If you are going to a V8 from a /6, the gearshift is probably the most minor problem you'll have. Brakes and suspension are the first two that come to mind.
[Re: Moparite]
#3188187
11/02/23 03:09 AM
11/02/23 03:09 AM
Posts: 43,214 Bend,OR USA
Cab_Burge
[Re: Z70challenger]
#3188298
11/02/23 03:51 PM
11/02/23 03:51 PM
Posts: 2,920 Calgary, Alberta Canada
a12rag
Hi guys,
I have a 70 challenger, original slant 6 auto on the column. I am looking to put a 440 in the car. I’m looking to see if there was big blocks auto on the column and if I can use the same steering column to do so? Probably more "rare" leaving it the way it is . . . yes, I know how tempting it is to change things - after all, it is YOUR car - do what you want with it !! . . . Cheers, Mark
[Re: skdmark]
#3188431
11/03/23 09:35 AM
11/03/23 09:35 AM
Posts: 4,684 Wichita
GY3
Wichita
Best bet is to find yourself a rotted out C-body with a 440/727 and a K-frame and just transfer engine and transmission over. I did have to grind a bit on one side of the radiator mounting to clear a frame rail and re-drill one hole as I recall. Pretty easy stuff, though.
I did that with a '71 Barracuda and it worked great! The /6 torsion bars work better if you're going to drag race it anyway.
[Re: GY3]
#3188465
11/03/23 12:20 PM
11/03/23 12:20 PM
Posts: 19,456 north of coder
moparx
back in my junkyard ownership days, guys would grab a 383/440 with 727 out of a C-body, then we would cut off the mounts from the C-body K frame. these would be bolted to the engine, then with the /6 mounts cut from whatever K the buyer was working on, the engine and transmission was lowered into the car, the mounts were tacked onto the K, engine/transmission removed, then the mounts were welded into place. back then, nobody removed the K. just pulled the engine from the top. crude, and far from correct, but a ton were done this way and worked out great.
