Alignment off after a wheelstand #3184307
10/16/23 08:42 AM
10/16/23 08:42 AM
an8sec70cuda Offline OP
Last run I made w/ my cuda had a hard landing when it stood up. Smashed the oil pan pretty good, but I didn't see any witness marks on anything else, so I think the pan was the only thing that hit the ground.
Drove the car a few weeks ago and it's pulling to the RIGHT. Found a sticking brake caliper on the LEFT. Just got the brakes fixed and back together this weekend, but haven't been able to drive it due to rain and too many other things to do.
I don't see anything that looks bent or obviously damaged, but I know that it would have to be pretty bad to actually be able to see it. The steering wheel is no longer centered when straight. I don't think the car is damaged as far as frame structure b/c all the door gaps still seem fine.
My question is what have yall found damaged in the suspension after a hard landing? I'm hoping to get it aligned this coming weekend and hopefully they'll be able to tell me what happened. I would like to have an idea of what to look for if any of you have had this issue.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Alignment off after a wheelstand [Re: an8sec70cuda] #3184311
10/16/23 08:58 AM
10/16/23 08:58 AM
Connellsville
71Demon528 Offline
71Demon528  Offline
Connellsville
We had to replace my dads idler arm after he did the same thing, then re checked the tow and can’t remember if he had to adjust it much or not.
Re: Alignment off after a wheelstand [Re: an8sec70cuda] #3184312
10/16/23 08:59 AM
10/16/23 08:59 AM
Minn
SportF Offline
SportF  Offline
Minn
Steering box mount, or even a cracked mount on the box itself.
Re: Alignment off after a wheelstand [Re: SportF] #3184322
10/16/23 09:24 AM
10/16/23 09:24 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
When my son did the 330 foot wheelie last year it bent the strut plate that connects to the rack. Not sure what type of set up you have.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Alignment off after a wheelstand [Re: pittsburghracer] #3184323
10/16/23 09:28 AM
10/16/23 09:28 AM
Forgot to add that the car still has all stock front suspension and steering. up
CHIP
Re: Alignment off after a wheelstand [Re: an8sec70cuda] #3184335
10/16/23 10:05 AM
10/16/23 10:05 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Yeah….. we got an alignment after the wheel stand all right.
Re: Alignment off after a wheelstand [Re: J_BODY] #3184357
10/16/23 12:07 PM
10/16/23 12:07 PM
gregsdart Offline
gregsdart  Offline
If there is a good front end alignment shop near you that specializes in race cars, they can check your car over and set it for the track.
Re: Alignment off after a wheelstand [Re: an8sec70cuda] #3184358
10/16/23 12:08 PM
10/16/23 12:08 PM
NY
B1duster Offline
B1duster  Offline
NY
I would put the car on ramps or a drive on lift.
Put the steering wheel perfectly straight and eyeball down each side of car.
Most likely one wheel will be straight and the other toed in or toed out.
Take a good look at side that doesn’t look right
Re: Alignment off after a wheelstand [Re: B1duster] #3184371
10/16/23 12:55 PM
10/16/23 12:55 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Start by checking the toe. If the wheel is off the toe has changed. Usually a toe change is caused by a camber change. It doesn't take much. Look at the front tires. Are they layed in? Check with a digital level. If the wheel has only moved 1/8 turn or so nothing has probably moved very far.
Doug
Re: Alignment off after a wheelstand [Re: an8sec70cuda] #3184375
10/16/23 01:10 PM
10/16/23 01:10 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Yeah we've done that a few times now, last time was the worst after bending the wheelie bar mounts. After starting to move right it came down hard enough to buckle the pan, bend the QA1 cross member where it touched the floor and spring the spot welds off a little panel that attaches to the shock mount and fender on the RHS (it wasn't that good in the first place by the look of it). We have engine bars tied to the cage, I can also remember hurting my back.
The steering was a little toed out after that too, we checked stuff and re-assembled after replacing the QA1 cross member. The cross member was a little tight width wise to get in so we may have tweaked the frame rails a little. Then I spent a day with a castor camber gauge and a toe gauge, had to add some +ve camber on the LHS which meant adjusting the castor all over again but we got it in the end after going back and forth with the settings. Car ran OK with no issues on return but we had to wait some time for the QA1 stuff.
Re: Alignment off after a wheelstand [Re: Tig] #3184380
10/16/23 01:44 PM
10/16/23 01:44 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Stock K frame ? Don’t forget the idler arm and the lower arms locate off the K . If it touched one or all of this could move . Check the alignment settings where they are now , that will be best indicator of what moved
....BAD A$$ STREET CAR.....
Re: Alignment off after a wheelstand [Re: n20mstr] #3184384
10/16/23 01:53 PM
10/16/23 01:53 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
My car, a 69 Barracuda, cracked the mount for the left front upper control arm bushing after it started doing wheelstands, however this was before the giant smash the pan and headers wheelie it had pre wheelie bars.
Re: Alignment off after a wheelstand [Re: 340Cuda] #3184489
10/16/23 10:53 PM
10/16/23 10:53 PM
Kansas
Thelma133 Offline
Thelma133  Offline
Kansas
Mine was not quite as high as yours is in the picture. I put an alterkation on my dart. It’s bullet proof. Have you thought about wheelie bars?
Re: Alignment off after a wheelstand [Re: Thelma133] #3184550
10/17/23 08:26 AM
10/17/23 08:26 AM
The steering box and mounts all look good. Idler arm doesn't look bent, but I'm not 100% sure b/c I didn't take it apart. I held a good one up close to it to eyeball it, lol.
The rear UCA cam bolt on the driver's side looks like it may have moved, but I don't see any damage to anything around the UCA bushings.
Gonna take it in for an alignment and see how it goes.
No wheelie bars allowed in the usual classes I run. This car is going way faster than it should be for what's done to it. Seriously considering either making some changes in the near future or just hanging it up for a while.
CHIP
Re: Alignment off after a wheelstand [Re: an8sec70cuda] #3184554
10/17/23 08:50 AM
10/17/23 08:50 AM
OH
TheBlackCar Offline
TheBlackCar  Offline
OH
I put reference marks with a paint pen on the UCA adjustment bolts/washers for a quick visual check in the future. Also look at the Upper BJ cup if you have aftermarket UCA's, stretched a couple of those.
Re: Alignment off after a wheelstand [Re: TheBlackCar] #3184594
10/17/23 12:50 PM
10/17/23 12:50 PM
MD
HEMI472 Offline
HEMI472  Offline
MD
its all ways going to happen till you get rid of the cam bolts
Re: Alignment off after a wheelstand [Re: dvw] #3184595
10/17/23 12:52 PM
10/17/23 12:52 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Doug
That's a good idea - never thought about using a digital level - just ordered one!
Re: Alignment off after a wheelstand [Re: TheBlackCar] #3184596
10/17/23 01:01 PM
10/17/23 01:01 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I did that with my car. No huge wheelstands, but so far nothing has moved.
69 GTX 68 Road Runner
Re: Alignment off after a wheelstand [Re: an8sec70cuda] #3185843
10/23/23 08:49 AM
10/23/23 08:49 AM
The driver's side rear cam bolt moved a lot and rounded out the hole in the cam washer. Also both upper ball joints were in rough shape.
Replaced both upper ball joints and all 4 UCA bushings. Going to get it aligned ASAP and hopefully be good to go for the KOS race on 11/18 in Rockingham.
CHIP
Re: Alignment off after a wheelstand [Re: an8sec70cuda] #3186336
10/25/23 07:44 AM
10/25/23 07:44 AM
Long Island, NY
ValiantRich Offline
ValiantRich  Offline
Long Island, NY
I have had similar problems and the cure is to have a roller bearing idler arm. Mine was done by MR2 performance. The upper control arm cams were tack welded to the body after front end alignment. I do have to set the toe in periodically but nothing drastic like it used to be. Hope this helps.
