Trunk mounted battery #3177030
09/21/23 07:30 PM
09/21/23 07:30 PM
STL ,MO
Handygun Offline OP
Handygun  Offline OP
STL ,MO
I am looking for a battery box for my 68 Barracuda FB. Which ones are popular, tips or things you would do next time. I want to still be able to raise and lower divider but have enough battery to spin my 540.Not alot of room back there. Car will be street driven. I already have pos.cable routed. Looking for quality over economy. Thanks, Steve
Re: Trunk mounted battery [Re: Handygun] #3177086
09/21/23 09:29 PM
09/21/23 09:29 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I used a Moroso and have no complaints.
Re: Trunk mounted battery [Re: justinp61] #3177116
09/22/23 12:00 AM
09/22/23 12:00 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I use this aluminum battery box powder coated black with a lightweight AGM racing battery on the street. It vents through the trunk.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Trunk mounted battery [Re: Handygun] #3177148
09/22/23 09:18 AM
09/22/23 09:18 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
If you want it to spin over your 540, make sure to use welding cable (more strands and very flexible) with good connections/crimps. AND use a full length ground cable from the engine block direct to the battery. It will help a lot. Also consider a 16 volt , there are alternators with adj regulators to get the correct charging voltage.
....BAD A$$ STREET CAR.....
