I am looking for a battery box for my 68 Barracuda FB. Which ones are popular, tips or things you would do next time. I want to still be able to raise and lower divider but have enough battery to spin my 540.Not alot of room back there. Car will be street driven. I already have pos.cable routed. Looking for quality over economy. Thanks, Steve
If you want it to spin over your 540, make sure to use welding cable (more strands and very flexible) with good connections/crimps. AND use a full length ground cable from the engine block direct to the battery. It will help a lot. Also consider a 16 volt , there are alternators with adj regulators to get the correct charging voltage.
