Re: SB head comparisions, Indy 360 versus ported iron T/A heads?
[Re: P7 Engineering]
#3175856
09/17/23 04:24 PM
09/17/23 04:24 PM
Posts: 4,410 Michigan
MarkZ
Worthy
Worthy
Don't those T/A heads have a significant value to the restoration crowd?
[Re: Cab_Burge]
#3176638
09/20/23 11:44 AM
09/20/23 11:44 AM
Posts: 9,875 Weddington, N.C.
Streetwize
Weddington, N.C.
Check with Brian Halfinger (IMM Racing engines) , I'd like to hear his opinion
I have a set of the Airwolfs that are I believe were CNC ported Pro Comps, they flow really well but they only made a few sets of them on my 414. They flow around 310 @ .600 the only downside to them is the roof to spring pocket thickness is very thin but I don't run a very high spring pressure so they work fine in my motor/combination.
I believe the Pro-comps were actually cast thicker in this area then the Edelbrocks, so I think that's probably where much of the additional flow potential comes from. If I was running a .750 lift solid with a lot of spring pressure I'd be a bit nervous but i think if I wanted to run that big a Cam I'd be looking at a W9 (or something similar) anyway.
[Re: Streetwize]
#3176644
09/20/23 11:52 AM
09/20/23 11:52 AM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
Vote here for the Bloomer heads Rod and Vic Bloomer designed and sell They are a factory replacement type head( like an Edelbrock) that take all factory type parts( headers, intakes, rocker gear, etc) Make excellent power as delivered( fully CNC’ed, 2.08 valve, springs of choice) I am very happy with the set I have. A friend is running them on his 2880 pound AMX, and has been as quick as 5.94 I believe at 113+, just the way they come. My best with them is in my signature, plenty more I could do(bigger and or roller cam) but with stock block I don’t want to push any further. I took ported Eddie’s off, swapped on these heads and new headers, have thus far picked up 3 tenths over 5 mph.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: Streetwize]
#3176807
09/20/23 09:12 PM
09/20/23 09:12 PM
Posts: 43,180 Bend,OR USA
Cab_Burge
#3176822
09/20/23 10:31 PM
09/20/23 10:31 PM
Posts: 9,456 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Would not touch those swap meet half machined commando heads... For an entry level motor, I would advise just going with a set of out of the box Edelbrock heads. Most cost effective route. Or you can buy the Large port commandos I just posted in the small block engine classifieds. Shameless plug. Sorry. LOL
STOP POTATO HATE!
[Re: justinp61]
#3176901
09/21/23 11:37 AM
09/21/23 11:37 AM
B3422W5
Portage,michigan
I was well pleased with my ported Edelbrocks. On my 10.8-1 408 they went 6.57 @ 104 and change at 3230ish pounds on pump 93 with an off the shelf flat solid cam. Was one of the best running combos ever!
[Re: Cab_Burge]
#3176959
09/21/23 02:39 PM
09/21/23 02:39 PM
Posts: 5,485 SoCal
Brian Hafliger
SoCal
That right there is the reason I prefer to keep clear of you. Unfortunate to see your still the same.
Brian Hafliger
[Re: Brian Hafliger]
#3177305
09/22/23 08:03 PM
09/22/23 08:03 PM
Posts: 324 Northport, al.
tvt59
Northport, al.
I I beleave that Bloomers heads make more power than any other conventional LA style head. But I don't know what he sells them for. My AMX weighs 2910 with me in it. It goes 5.94 @114.5 in the 1/8. And 9.43 @ 139 in the 1/4. Have not played with the timing or jetting yet. This is with a unported super victor. I beleave that there's a few more hundredths and 1 more mph to be had in my combo. If you can fit his heads in the budget you'll be glad that you did.
Nothing worth anything comes easy. It is always harder to do the right thing.
My Grandfather
[Re: B3422W5]
#3177520
09/23/23 04:27 PM
09/23/23 04:27 PM
Posts: 982 western pennsylvania
b1dartsport
Vote here for the Bloomer heads Rod and Vic Bloomer designed and sell They are a factory replacement type head( like an Edelbrock) that take all factory type parts( headers, intakes, rocker gear, etc) Make excellent power as delivered( fully CNC’ed, 2.08 valve, springs of choice) I am very happy with the set I have. A friend is running them on his 2880 pound AMX, and has been as quick as 5.94 I believe at 113+, just the way they come. My best with them is in my signature, plenty more I could do(bigger and or roller cam) but with stock block I don’t want to push any further. I took ported Eddie’s off, swapped on these heads and new headers, have thus far picked up 3 tenths over 5 mph. How much did you pay for your Bloomer Heads?
