Kil-Kare shutdown length #3172817
09/04/23 01:20 PM
09/04/23 01:20 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Thinking about running Kil-Kare next weeked. The event will be 1/4 mile. I'm sure they normally run 1/8. My car runs 147-149 mph. It stops well. I've run 1/4 at Dragway 42 with no issue. How's the shutdown length?
Doug
Re: Kil-Kare shutdown length [Re: dvw] #3172826
09/04/23 01:41 PM
09/04/23 01:41 PM
PA
Scully Offline
Scully  Offline
PA
Google shows it to be about 1,000' at the first turnoff and a hair over 1,500' at the end before the sand traps so at almost 200' shorter than Island I'd say it's a very short shutdown. I like to use the second turnoff at Numidia which is almost 1,800' and I think that's short running in the low mid 120's.
Re: Kil-Kare shutdown length [Re: dvw] #3172847
09/04/23 02:31 PM
09/04/23 02:31 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
pull the chute
Re: Kil-Kare shutdown length [Re: nss guy] #3172862
09/04/23 03:46 PM
09/04/23 03:46 PM
Dayton, OH
1980volare Offline
My man card has just been revoked.
1980volare  Offline
Dayton, OH
It’s short, but I’ve seen way shorter. I trapped mid 140s I’d pull the chute every time. I think you’ll be ok. That’s my home track.
Re: Kil-Kare shutdown length [Re: 1980volare] #3172866
09/04/23 04:06 PM
09/04/23 04:06 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Its only 1/8 mile racing generally. I had no issues stopping from 153 in the 1/8 with the Stratus. We have MUCH shorter tracks out here. You wont have an issue.
Re: Kil-Kare shutdown length [Re: Scully] #3172922
09/04/23 06:43 PM
09/04/23 06:43 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Pull the chute before the stripe to be safe . After the high gear shift put your hand on the handle and be ready
....BAD A$$ STREET CAR.....
Re: Kil-Kare shutdown length [Re: n20mstr] #3172928
09/04/23 07:25 PM
09/04/23 07:25 PM
birdtracker Offline
birdtracker  Offline
DVW: This track is in my back yard.my car has the original A body disc brakes on the front and disc on the rear. At 150 mph with only brakes the shutdown is short. I usually avoided this track for years due to the shutdown and went to Muncie.At the end of the shut down is a creek. Many cars have went in the creek. If a wrecker couldn't get them out easily they would leave them in and continue with the racing program since they have a midnight curfew. Use the chute and be ready to deploy. Be safe. Birdtracker
Re: Kil-Kare shutdown length [Re: birdtracker] #3172948
09/04/23 08:26 PM
09/04/23 08:26 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
I'd love to pull the chute. But the car doesn't have one. I believe shutting down from my speed if it was at the 1/8 would be OK. It's the speed at the end of the 1/4 that worries me.
Doug
Re: Kil-Kare shutdown length [Re: dvw] #3172963
09/04/23 09:06 PM
09/04/23 09:06 PM
birdtracker Offline
birdtracker  Offline
no better time than the present. Birdtracker
Re: Kil-Kare shutdown length [Re: birdtracker] #3173005
09/05/23 12:20 AM
09/05/23 12:20 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Wait a week and come to Moparty and run NSS there
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Kil-Kare shutdown length [Re: B3422W5] #3173048
09/05/23 09:32 AM
09/05/23 09:32 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
You can actually measure in Google Maps.
Shut Down Lengths for Reference...
Milan: 2046FT
Lapeer: 2083 FT
Mid-Michigan: 1933 FT
Ubly: 2414 FT
US 131: 2073 FT
Kil-Kare: 1571FT
Re: Kil-Kare shutdown length [Re: dizuster] #3173057
09/05/23 10:08 AM
09/05/23 10:08 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Milan: 2046FT
Lapeer: 2083 FT
Ubly: 2414 FT
US 131: 2073 FT
Kil-Kare: 1571FT
I knew my local track had better than average shutdown.....2682!
68 Barracuda Formula S 340
Re: Kil-Kare shutdown length [Re: Bad340fish] #3173060
09/05/23 10:21 AM
09/05/23 10:21 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
They always bragged about Norwalk having a 1/2 mile. I know at 160mph in my Daytona I didn’t need my chute.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Kil-Kare shutdown length [Re: pittsburghracer] #3173081
09/05/23 11:31 AM
09/05/23 11:31 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
1,745 at Mo-Kan.
Hard on the brakes even at 133 mph. nervous
'63 Dodge 330
11.19 @ 121 mph
Re: Kil-Kare shutdown length [Re: pittsburghracer] #3173221
09/05/23 09:10 PM
09/05/23 09:10 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Having raced extensively at 131 and Norwalk over the years, Norwalk is shorter. First pass at Norwalk I made in my old car I had both driver side tires in the grass making the turn, remember thinking how quick it came up. I have always been kinda slow getting on the brakes, but that really had me change my habits racing there back then.
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Kil-Kare shutdown length [Re: B3422W5] #3173222
09/05/23 09:18 PM
09/05/23 09:18 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
I'm going to give it a shot. I talked to a few that have run London Ky at 150. It's even shorter than Kil Kare. Get on the brakes right at the stripe and you have room. And for the record Norwalk has about 75 ft longer shut down than 131. I've run Milan, Mid Michigan, 131, Norwalk, Dragway 42, Quaker City, National trail, Indy, Beech Bend, Clay City. No issue stopping at any of them. Always run 145-150. The shortest of the bunch are 42 and Milan which is my home track. Kil Kare is 250 ft shorter than Milan's main turn off.
Doug
Re: Kil-Kare shutdown length [Re: B3422W5] #3173223
09/05/23 09:22 PM
09/05/23 09:22 PM
PA.
"Little"John
"Little"John
PA.
I really Dont think Norwalk could get away with this if it wasn’t true. I do know that from going there 45 years or so it’s longer than it used to be. Cars used to e d up in the airport quite often.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Kil-Kare shutdown length [Re: pittsburghracer] #3173359
09/06/23 02:03 PM
09/06/23 02:03 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Running at 150 should have a chute anyway. You never know, just in case.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Kil-Kare shutdown length [Re: 6PKRTSE] #3173427
09/06/23 06:09 PM
09/06/23 06:09 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
I've been thinking about it for awhile. I know it's required at 150. And I'm close, usually 147-148.
Doug
Re: Kil-Kare shutdown length [Re: dvw] #3173581
09/07/23 01:53 PM
09/07/23 01:53 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Doug
Mine should talk you into it. Lol. Not seen once the bag is on but I know it is there.
Challenger Progress 018 [640x480].jpgChallenger Progress 020.jpg100_1663.jpg
