Re: Kil-Kare shutdown length
[Re: 1980volare]
#3172866
09/04/23 04:06 PM
09/04/23 04:06 PM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
Its only 1/8 mile racing generally. I had no issues stopping from 153 in the 1/8 with the Stratus. We have MUCH shorter tracks out here. You wont have an issue.
[Re: Scully]
#3172922
09/04/23 06:43 PM
09/04/23 06:43 PM
Posts: 4,696 On the parachute mount
n20mstr
Pull the chute before the stripe to be safe . After the high gear shift put your hand on the handle and be ready
....BAD A$$ STREET CAR.....
[Re: birdtracker]
#3172948
09/04/23 08:26 PM
09/04/23 08:26 PM
Posts: 9,869 MI, usa
dvw
MI, usa
I'd love to pull the chute. But the car doesn't have one. I believe shutting down from my speed if it was at the 1/8 would be OK. It's the speed at the end of the 1/4 that worries me. Doug
[Re: birdtracker]
#3173005
09/05/23 12:20 AM
09/05/23 12:20 AM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
Wait a week and come to Moparty and run NSS there
[Re: dizuster]
#3173057
09/05/23 10:08 AM
09/05/23 10:08 AM
Posts: 8,032 Tulsa OK
Bad340fish
Tulsa OK
You can actually measure in Google Maps.
Shut Down Lengths for Reference...
Milan: 2046FT
Lapeer: 2083 FT
Mid-Michigan: 1933 FT
Ubly: 2414 FT
US 131: 2073 FT
Kil-Kare: 1571FT
I knew my local track had better than average shutdown.....2682!
68 Barracuda Formula S 340
[Re: Bad340fish]
#3173060
09/05/23 10:21 AM
09/05/23 10:21 AM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
They always bragged about Norwalk having a 1/2 mile. I know at 160mph in my Daytona I didn’t need my chute.
[Re: pittsburghracer]
#3173081
09/05/23 11:31 AM
09/05/23 11:31 AM
Posts: 4,697 Wichita
GY3
Wichita
1,745 at Mo-Kan. Hard on the brakes even at 133 mph.
#3173221
09/05/23 09:10 PM
09/05/23 09:10 PM
B3422W5
Portage,michigan
Having raced extensively at 131 and Norwalk over the years, Norwalk is shorter. First pass at Norwalk I made in my old car I had both driver side tires in the grass making the turn, remember thinking how quick it came up. I have always been kinda slow getting on the brakes, but that really had me change my habits racing there back then.
[Re: B3422W5]
#3173222
09/05/23 09:18 PM
09/05/23 09:18 PM
dvw
MI, usa
I'm going to give it a shot. I talked to a few that have run London Ky at 150. It's even shorter than Kil Kare. Get on the brakes right at the stripe and you have room. And for the record Norwalk has about 75 ft longer shut down than 131. I've run Milan, Mid Michigan, 131, Norwalk, Dragway 42, Quaker City, National trail, Indy, Beech Bend, Clay City. No issue stopping at any of them. Always run 145-150. The shortest of the bunch are 42 and Milan which is my home track. Kil Kare is 250 ft shorter than Milan's main turn off. Doug
[Re: B3422W5]
#3173223
09/05/23 09:22 PM
09/05/23 09:22 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Having raced extensively at 131 and Norwalk over the years, Norwalk is shorter. First pass at Norwalk I made in my old car I had both driver side tires in the grass making the turn, remember thinking how quick it came up. I have always been kinda slow getting on the brakes, but that really had me change my habits racing there back then. I really Dont think Norwalk could get away with this if it wasn’t true. I do know that from going there 45 years or so it’s longer than it used to be. Cars used to e d up in the airport quite often.
#3173359
09/06/23 02:03 PM
09/06/23 02:03 PM
Posts: 4,576 Motor City
6PKRTSE
Motor City
Running at 150 should have a chute anyway. You never know, just in case.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#3173427
09/06/23 06:09 PM
09/06/23 06:09 PM
dvw
MI, usa
Running at 150 should have a chute anyway. You never know, just in case. I've been thinking about it for awhile. I know it's required at 150. And I'm close, usually 147-148. Doug
[Re: dvw]
#3173581
09/07/23 01:53 PM
09/07/23 01:53 PM
6PKRTSE
Motor City
Running at 150 should have a chute anyway. You never know, just in case. I've been thinking about it for awhile. I know it's required at 150. And I'm close, usually 147-148. Doug Mine should talk you into it. Lol. Not seen once the bag is on but I know it is there.
