Master cylinder heat shield - options?
#3172749
09/04/23 09:46 AM
09/04/23 09:46 AM
Posts: 1,755 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
1980 Diplomat coupe here, the stroker W2 motor was installed this season and with it I made the move to the 1-7/8" primary tube TTIs from the 1-5/8" Hookers, and boy, did it get HOT under the hood! Given the temps and the fact that that MC sits right over the exhaust, and thus the radiant heat is just baking that thing (so fluid gets hot, but so does the plastic fluid container) I am looking to install a heat shield. Looking around I found a couple of choices: 1) Accurate Exhuast2) Mancini Racing...so I'm curious how well these things work? I do not mind spending the $$$ if either one is a good solution...but for what seems to be just a sheet of metal bent into a not too complex of a shape, the asking price is a little high???
Re: Master cylinder heat shield - options?
[Re: Diplomat360]
#3172757
09/04/23 10:07 AM
09/04/23 10:07 AM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
I think that a member here Andy F makes one or did.He makes a lot of nice stuff that works Might be the one Mancin sells
Chrysler Firepower
[Re: therocks]
#3172764
09/04/23 10:24 AM
09/04/23 10:24 AM
Posts: 8,240 fredericksburg,va
cudaman1969
fredericksburg,va
Looks ugly but the exhaust wrap sold in 2” wide roles will keep the heat in the pipe not deflect it. Hose clamp on each end, get it tight and it won’t move.
[Re: cudaman1969]
#3172775
09/04/23 11:04 AM
09/04/23 11:04 AM
Posts: 4,405 Michigan
MarkZ
Worthy
Worthy
Looks ugly but the exhaust wrap sold in 2” wide roles will keep the heat in the pipe not deflect it. Hose clamp on each end, get it tight and it won’t move. Doesn't that stuff rot out headers quicker?
[Re: MarkZ]
#3172776
09/04/23 11:08 AM
09/04/23 11:08 AM
Posts: 22,696 Bitopia
jcc
Bitopia
Yes, and it's not from retained moisture, its thermal fatigue thru exaggerated expansion contraction cycles because it allows the header to operate at much higher temps, and it promotes high temperature oxidation which is and looks much like rust. I would never use the stuff on anything I felt was valuable. Try the heat shield, it hurts nothing.
[Re: Diplomat360]
#3172779
09/04/23 11:13 AM
09/04/23 11:13 AM
Posts: 5,439 So Cal
Sinitro
So Cal
1980 Diplomat coupe here, the stroker W2 motor was installed this season and with it I made the move to the 1-7/8" primary tube TTIs from the 1-5/8" Hookers, and boy, did it get HOT under the hood! Given the temps and the fact that that MC sits right over the exhaust, and thus the radiant heat is just baking that thing (so fluid gets hot, but so does the plastic fluid container) I am looking to install a heat shield. Looking around I found a couple of choices: 1) Accurate Exhuast2) Mancini Racing...so I'm curious how well these things work? I do not mind spending the $$$ if either one is a good solution...but for what seems to be just a sheet of metal bent into a not too complex of a shape, the asking price is a little high??? Here U go... Mancini carries the Mopar part.. Just my $0.02... https://www.manciniracing.com/mascylheatsh.html
[Re: therocks]
#3172780
09/04/23 11:13 AM
09/04/23 11:13 AM
Diplomat360
Windsor, ON, Canada
I think that a member here Andy F makes one or did.He makes a lot of nice stuff that works Might be the one Mancin sells 'Andy F' is AREngineering, right? Yeah, I found an older post of his on another forum, but the link is DEAD now and looking at his site I do not see a 'heat shield' anything listed on there.
[Re: cudaman1969]
#3172809
09/04/23 12:48 PM
09/04/23 12:48 PM
jcc
Bitopia
But no one should ignore the fact Alum transmits heat 15? times better than SS when fabbing heat shields.
[Re: Diplomat360]
#3172858
09/04/23 03:33 PM
09/04/23 03:33 PM
Posts: 31,000 Oregon
AndyF
I think that a member here Andy F makes one or did.He makes a lot of nice stuff that works Might be the one Mancin sells 'Andy F' is AREngineering, right? Yeah, I found an older post of his on another forum, but the link is DEAD now and looking at his site I do not see a 'heat shield' anything listed on there. I sold the design to Mancini so it isn't on my website anymore. They make them off of my original prints. Those shields work pretty well with HP manifolds and most headers. I always ran one when I had HP manifolds.
[Re: jlatessa]
#3172877
09/04/23 04:29 PM
09/04/23 04:29 PM
jcc
Bitopia
Here's a pic of our homemade shield, Don't know if we actually needed it, but....
Joe I stand by my 15 times previous comment. That being said, IMO it would seem best to keep heat away from actual cylinder first, and your DIY heatshield seems like it extends in addition to far above the manifold heat, and the extra conductivity of alum might work in your favor and be an inherent heat sink to the lower half of the alum shield, especially being its vertical. Meaning, don't change anything. FWIW, I use Andy's shields on my cars. for decades?
