Master cylinder heat shield - options? #3172749
09/04/23 09:46 AM
09/04/23 09:46 AM
Windsor, ON, Canada
Diplomat360 Offline OP
Windsor, ON, Canada
1980 Diplomat coupe here, the stroker W2 motor was installed this season and with it I made the move to the 1-7/8" primary tube TTIs from the 1-5/8" Hookers, and boy, did it get HOT under the hood!
Given the temps and the fact that that MC sits right over the exhaust, and thus the radiant heat is just baking that thing (so fluid gets hot, but so does the plastic fluid container) I am looking to install a heat shield.
Looking around I found a couple of choices:
1) Accurate Exhuast
2) Mancini Racing
...so I'm curious how well these things work?
I do not mind spending the $$$ if either one is a good solution...but for what seems to be just a sheet of metal bent into a not too complex of a shape, the asking price is a little high???
Re: Master cylinder heat shield - options? [Re: Diplomat360] #3172757
09/04/23 10:07 AM
09/04/23 10:07 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I think that a member here Andy F makes one or did.He makes a lot of nice stuff that works Might be the one Mancin sells
Chrysler Firepower
Re: Master cylinder heat shield - options? [Re: therocks] #3172764
09/04/23 10:24 AM
09/04/23 10:24 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Looks ugly but the exhaust wrap sold in 2” wide roles will keep the heat in the pipe not deflect it. Hose clamp on each end, get it tight and it won’t move.
Re: Master cylinder heat shield - options? [Re: cudaman1969] #3172767
09/04/23 10:45 AM
09/04/23 10:45 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've used one - IIRC, it was the Accurate design - years ago on my '63 Savoy Maxie tribute.
I'd done a dual MC conversion, and the big Maxie manifolds, and 1st ride into town the MC was getting overheated to the point of soft brake pedal.
Added that heat shield, and no problems afterward.
Re: Master cylinder heat shield - options? [Re: cudaman1969] #3172775
09/04/23 11:04 AM
09/04/23 11:04 AM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Doesn't that stuff rot out headers quicker?
Re: Master cylinder heat shield - options? [Re: MarkZ] #3172776
09/04/23 11:08 AM
09/04/23 11:08 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Yes, and it's not from retained moisture, its thermal fatigue thru exaggerated expansion contraction cycles because it allows the header to operate at much higher temps, and it promotes high temperature oxidation which is and looks much like rust.
I would never use the stuff on anything I felt was valuable.
Try the heat shield, it hurts nothing.
Re: Master cylinder heat shield - options? [Re: Diplomat360] #3172779
09/04/23 11:13 AM
09/04/23 11:13 AM
So Cal
Sinitro Online content
Sinitro  Online Content
So Cal
1) Accurate Exhuast
2) Mancini Racing
Here U go...
Mancini carries the Mopar part..
Just my $0.02... wink
https://www.manciniracing.com/mascylheatsh.html
Re: Master cylinder heat shield - options? [Re: therocks] #3172780
09/04/23 11:13 AM
09/04/23 11:13 AM
Windsor, ON, Canada
Windsor, ON, Canada
'Andy F' is AREngineering, right?
Yeah, I found an older post of his on another forum, but the link is DEAD now and looking at his site I do not see a 'heat shield' anything listed on there.
Re: Master cylinder heat shield - options? [Re: Sinitro] #3172782
09/04/23 11:18 AM
09/04/23 11:18 AM
Windsor, ON, Canada
Windsor, ON, Canada
Originally Posted by Sinitro
Here U go...
...right, it's one of the two parts I listed in my original post, and my question re: how well do these work stems partially from the fact that the surface area of the Mancini shield is rather small, see the photo they show:
So I'm curious if this is actually sufficient to block/re-direct that amount of radiant heat?
Re: Master cylinder heat shield - options? [Re: Diplomat360] #3172793
09/04/23 11:51 AM
09/04/23 11:51 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
On an a-body with big block and fender well headers, we made up one using a large aluminum sheet with asbestos attached. But you need as much air gap as possible without touching the header pipe.
Re: Master cylinder heat shield - options? [Re: cudaman1969] #3172809
09/04/23 12:48 PM
09/04/23 12:48 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
But no one should ignore the fact Alum transmits heat 15? times better than SS when fabbing heat shields.
Re: Master cylinder heat shield - options? [Re: jcc] #3172838
09/04/23 02:07 PM
09/04/23 02:07 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Here's a pic of our homemade shield, Don't know if we actually needed it, but....
Joe
Re: Master cylinder heat shield - options? [Re: Diplomat360] #3172858
09/04/23 03:33 PM
09/04/23 03:33 PM
AndyF Online content
AndyF  Online Content
I sold the design to Mancini so it isn't on my website anymore. They make them off of my original prints. Those shields work pretty well with HP manifolds and most headers. I always ran one when I had HP manifolds.
Re: Master cylinder heat shield - options? [Re: jlatessa] #3172877
09/04/23 04:29 PM
09/04/23 04:29 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Joe
I stand by my 15 times previous comment. That being said, IMO it would seem best to keep heat away from actual cylinder first, and your DIY heatshield seems like it extends in addition to far above the manifold heat, and the extra conductivity of alum might work in your favor and be an inherent heat sink to the lower half of the alum shield, especially being its vertical. Meaning, don't change anything. grin
FWIW, I use Andy's shields on my cars. for decades?
