2 step reaction time #3171201
08/28/23 08:06 PM
08/28/23 08:06 PM
westerly, ri. usa
440lebaron Offline OP
westerly, ri. usa
installed switch on brake pedal for 2 step rpm staging, was using stock brake light switch, (to much throw) was only able to do .110-.130, now best i can do is .060 4000 lbs cordoba, need to be at least .030, more starting line rpm ? smaller front tire? anything else?
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: 2 step reaction time [Re: 440lebaron] #3171221
08/28/23 09:26 PM
08/28/23 09:26 PM
PA
moparacer Offline
moparacer  Offline
PA
what rpm was you leaving at? I say more 2 step rpm then go to the front tires.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: 2 step reaction time [Re: 440lebaron] #3171224
08/28/23 09:33 PM
08/28/23 09:33 PM
Dunnellon, FL
longram60 Offline
longram60  Offline
Dunnellon, FL
I adjusted the depth of the brake pedal switch to get my reaction times down. Also went to a hard sole shoe to-remove flexing of the sole.
1979 AMC Spirit, NHRA Q/SA
Re: 2 step reaction time [Re: 440lebaron] #3171232
08/28/23 10:17 PM
08/28/23 10:17 PM
Cab_Burge Online work
Cab_Burge  Online Work
Check the wheelbase to make sure one side is not longer or shorter than the other side. Smaller front tires and better adjustable front shocks may help also scope work twocents
How about reducing the weight also work shruggy
So many ways to speed up or slow a car down that can drive you crazy finding them work :), Good luck up
Re: 2 step reaction time [Re: Cab_Burge] #3171252
08/29/23 07:16 AM
08/29/23 07:16 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Honestly with a car that heavy and likely not to get any lighter soon, I would put the TB switch on the steering wheel or somewhere convenient. You will be more consistant, and be able to shim the switch better. Not that slowing it down helps, but you do get more range.
Normally when we need a quicker reaction time, we raise the launch rpm and or front tire pressure...That's about it. I have never had to speed mine up, I always had to figure out how to slow it down.
Re: 2 step reaction time [Re: Dragula] #3171257
08/29/23 08:03 AM
08/29/23 08:03 AM
westerly, ri. usa
westerly, ri. usa
thanks, running stock, no thumb/finger switch allowed, switch is adjusted all the way down, now leaving at 2500, converter should hold till 3000/3500, will try all ideas
Re: 2 step reaction time [Re: 440lebaron] #3171259
08/29/23 08:17 AM
08/29/23 08:17 AM
PA
moparacer Offline
moparacer  Offline
PA
1000 rpm should be enough to help that 60 light. Raise it 200 RPM at a time and find the sweet spot.
Re: 2 step reaction time [Re: moparacer] #3171261
08/29/23 08:37 AM
08/29/23 08:37 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Guys I know use an adjustable pressure switch in the brake line. Then you can set the pressure at different psi to release the two step.
Doug
Re: 2 step reaction time [Re: dvw] #3171331
08/29/23 12:43 PM
08/29/23 12:43 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Not knowing what button you have but the button itself can make a great difference. In my truck, I have a plain old Moroso type button (Delay bypass for reverser shifting ) and an adjustable height soft button (thru the delay box) my reaction times are much more consistent (and quicker) with the soft touch button than the Moroso button. If you put a soft/short throw button in the pedal it may help twocents
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: 2 step reaction time [Re: W.I.N. Racing] #3171369
08/29/23 02:20 PM
08/29/23 02:20 PM
I used a wide open throttle switch on my old S/P car as a backup on the trans brake button circuit, which ever one work first released the trans brake up scope work
Re: 2 step reaction time [Re: 440lebaron] #3171376
08/29/23 02:46 PM
08/29/23 02:46 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Is the horn button considered a thumb/finger switch ?
Re: 2 step reaction time [Re: JohnRR] #3171404
08/29/23 04:08 PM
08/29/23 04:08 PM
westerly, ri. usa
westerly, ri. usa
i was using the horn button, (most likely would not pass tech) just a ground switch was going thru horn relay .140-.180 lights. switch on brake pedal is transbrake fast switch, will try tire pressure and starting line rpm
Re: 2 step reaction time [Re: 440lebaron] #3171423
08/29/23 05:09 PM
08/29/23 05:09 PM
tboomer Offline
tboomer  Offline
I never had much luck with the button on the brake pedal. I put a Dedenbaer on the steering wheel.
Re: 2 step reaction time [Re: tboomer] #3171434
08/29/23 05:50 PM
08/29/23 05:50 PM
PA
moparacer Offline
moparacer  Offline
PA
I drove a stocker one time that had a button on the pedal. Didn't like it either. Seemed to be inconsistent.
Re: 2 step reaction time [Re: moparacer] #3171467
08/29/23 07:27 PM
08/29/23 07:27 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Quite honestly, at that low rpm a 2 step is a waste of time. Been there, done that.
