2 step reaction time
#3171201
08/28/23 08:06 PM
08/28/23 08:06 PM
Posts: 1,606 westerly, ri. usa
440lebaron
westerly, ri. usa
installed switch on brake pedal for 2 step rpm staging, was using stock brake light switch, (to much throw) was only able to do .110-.130, now best i can do is .060 4000 lbs cordoba, need to be at least .030, more starting line rpm ? smaller front tire? anything else?
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
Re: 2 step reaction time
[Re: 440lebaron]
#3171221
08/28/23 09:26 PM
08/28/23 09:26 PM
Posts: 2,504 PA
moparacer
PA
what rpm was you leaving at? I say more 2 step rpm then go to the front tires.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: 440lebaron]
#3171224
08/28/23 09:33 PM
08/28/23 09:33 PM
Posts: 693 Dunnellon, FL
longram60
Dunnellon, FL
I adjusted the depth of the brake pedal switch to get my reaction times down. Also went to a hard sole shoe to-remove flexing of the sole.
1979 AMC Spirit, NHRA Q/SA
[Re: Cab_Burge]
#3171252
08/29/23 07:16 AM
08/29/23 07:16 AM
Posts: 12,388 Taxes & Virus's R-US, NY
Dragula
Honestly with a car that heavy and likely not to get any lighter soon, I would put the TB switch on the steering wheel or somewhere convenient. You will be more consistant, and be able to shim the switch better. Not that slowing it down helps, but you do get more range.
Normally when we need a quicker reaction time, we raise the launch rpm and or front tire pressure...That's about it. I have never had to speed mine up, I always had to figure out how to slow it down.
[Re: Dragula]
#3171257
08/29/23 08:03 AM
08/29/23 08:03 AM
440lebaron
westerly, ri. usa
thanks, running stock, no thumb/finger switch allowed, switch is adjusted all the way down, now leaving at 2500, converter should hold till 3000/3500, will try all ideas
[Re: 440lebaron]
#3171259
08/29/23 08:17 AM
08/29/23 08:17 AM
Posts: 2,504 PA
moparacer
PA
1000 rpm should be enough to help that 60 light. Raise it 200 RPM at a time and find the sweet spot.
[Re: dvw]
#3171331
08/29/23 12:43 PM
08/29/23 12:43 PM
Posts: 2,111 Byron, NY
W.I.N. Racing
Byron, NY
Not knowing what button you have but the button itself can make a great difference. In my truck, I have a plain old Moroso type button (Delay bypass for reverser shifting ) and an adjustable height soft button (thru the delay box) my reaction times are much more consistent (and quicker) with the soft touch button than the Moroso button. If you put a soft/short throw button in the pedal it may help
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: 440lebaron]
#3171376
08/29/23 02:46 PM
08/29/23 02:46 PM
Posts: 75,012 U.S.S.A.
JohnRR
U.S.S.A.
thanks, running stock, no thumb/finger switch allowed, switch is adjusted all the way down, now leaving at 2500, converter should hold till 3000/3500, will try all ideas Is the horn button considered a thumb/finger switch ?
[Re: JohnRR]
#3171404
08/29/23 04:08 PM
08/29/23 04:08 PM
440lebaron
westerly, ri. usa
i was using the horn button, (most likely would not pass tech) just a ground switch was going thru horn relay .140-.180 lights. switch on brake pedal is transbrake fast switch, will try tire pressure and starting line rpm
[Re: tboomer]
#3171434
08/29/23 05:50 PM
08/29/23 05:50 PM
Posts: 2,504 PA
moparacer
PA
I never had much luck with the button on the brake pedal. I put a Dedenbaer on the steering wheel. I drove a stocker one time that had a button on the pedal. Didn't like it either. Seemed to be inconsistent.
[Re: moparacer]
#3171467
08/29/23 07:27 PM
08/29/23 07:27 PM
Posts: 20,179 Park Forest, IL
slantzilla
Park Forest, IL
Quite honestly, at that low rpm a 2 step is a waste of time. Been there, done that.
