Re: minin starter ?
[Re: calrobb2000]
#3169769
08/22/23 06:47 PM
08/22/23 06:47 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
hi is there a hi torque mini starter with the short armature that will spin the engine over at hot restart .
my 340 has a silver colored unknowen brand mini starter that bogs down when engine temp is app195 deg .
remind me of the old chevy ones .
funny thing the hemi has the identical appearing one and it spins that bad boy fast even when hot ?
i have one with a slightly longer body but it hits the ex pipe .
thank you !
Get a 92-93 v8 Dakota starter at a parts store, will work fine. Small and get the job done, even with lots of compression
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Re: minin starter ?
[Re: B3422W5]
#3169924
08/23/23 03:12 PM
08/23/23 03:12 PM
Posts: 19,405 north of coder
moparx
also check your wires and terminal ends for tightness and "green death". [the corrosion that can grow into wires from not having tight and moisture proof terminal ends] do a voltage drop test when cold, then when hot. [watch your pinkies when around headers that are hot !] i like to use marine grade shrink tubing with the glue that seals the terminal connection. also make sure the wires are large enough to carry the current. i have seen some imported wire [insert your country of choice here] that claimed to be "xx" gauge size, and looked the part, only to find out the insulation was thicker, which made the wire gauge smaller than claimed. and speaking of insulation, get a quality wire with the correct automotive grade insulation. [of course i forget the name of it at this moment !] a lot of wire on the market today has inferior insulation, not really meant for the heat and vibration of vehicle use. [again, insert the country of your choice here]
Re: minin starter ?
[Re: rebel]
#3170047
08/24/23 06:07 AM
08/24/23 06:07 AM
Posts: 2,922 A shed in England
Tig
A shed in England
I use the middle one (2HP). After I rewired the car I ran a larger cross section "hot" cable and a separate earth to the starter, it spins the motor over way way better than before. The batteries are trunk mounted and it has no trouble turning a 13:1, 580 engine over hot or cold.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
