minin starter ? #3169767
08/22/23 06:40 PM
08/22/23 06:40 PM
s. e. pa.
calrobb2000 Offline OP
s. e. pa.
hi
is there a hi torque mini starter with the short armature that will spin the engine over at hot restart .
my 340 has a silver colored unknowen brand mini starter that bogs down when engine temp is app195 deg .
remind me of the old chevy ones .
funny thing the hemi has the identical appearing one and it spins that bad boy fast even when hot ?
i have one with a slightly longer body but it hits the ex pipe .
thank you !
Re: minin starter ? [Re: calrobb2000] #3169769
08/22/23 06:47 PM
08/22/23 06:47 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Originally Posted by calrobb2000
hi
thank you !
Get a 92-93 v8 Dakota starter at a parts store, will work fine. Small and get the job done, even with lots of compression
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: minin starter ? [Re: B3422W5] #3169924
08/23/23 03:12 PM
08/23/23 03:12 PM
moparx Online content
moparx  Online Content
also check your wires and terminal ends for tightness and "green death". [the corrosion that can grow into wires from not having tight and moisture proof terminal ends]
do a voltage drop test when cold, then when hot. [watch your pinkies when around headers that are hot !]
i like to use marine grade shrink tubing with the glue that seals the terminal connection.
also make sure the wires are large enough to carry the current. i have seen some imported wire [insert your country of choice here] that claimed to be "xx" gauge size, and looked the part, only to find out the insulation was thicker, which made the wire gauge smaller than claimed.
and speaking of insulation, get a quality wire with the correct automotive grade insulation. [of course i forget the name of it at this moment !] a lot of wire on the market today has inferior insulation, not really meant for the heat and vibration of vehicle use. [again, insert the country of your choice here]
beer
Re: minin starter ? [Re: moparx] #3170043
08/24/23 02:45 AM
08/24/23 02:45 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
I have 3 different mopar mini starters. A 1.2kw a 1.6kw & a 2kw. The 1.2 with start a low compression big block when hot, but its a struggle. The 1.6kw is better but on my race motor when hot, you need a good charge in the battery. The 2kw will spin the earth oround your motor, even when hot, but, it dont have a snout so if you have a kickback, im sure it'll rip itself off the bellhousing. I ended up welding a snout on for extra strength.
Re: minin starter ? [Re: rebel] #3170047
08/24/23 06:07 AM
08/24/23 06:07 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
I use the middle one (2HP). After I rewired the car I ran a larger cross section "hot" cable and a separate earth to the starter, it spins the motor over way way better than before. The batteries are trunk mounted and it has no trouble turning a 13:1, 580 engine over hot or cold.
