mp solid lifter seat height vs comp cams solid lifter seat h #1977194
12/27/15 04:00 PM
12/27/15 04:00 PM
Rock Springs
Bob_Coomer Offline OP
Rock Springs
Hey guys.. been a awhile!
Have a comp cams solid flat tapped in the engine now, and want to buy a new model purples shaft 528 solid. Just don't wanna buy new pushrods
Re: mp solid lifter seat height vs comp cams solid lifter seat h [Re: Bob_Coomer] #1977257
12/27/15 05:37 PM
12/27/15 05:37 PM
AndyF Offline
AndyF  Offline
No guarantee that you won't need new pushrods, just depends on which vendor MP is using for lifters. If they use the same exact lifter dimensions as Comp then you'll get lucky, otherwise you might need new pushrods.
Re: mp solid lifter seat height vs comp cams solid lifter seat h [Re: Bob_Coomer] #1977339
12/27/15 07:36 PM
12/27/15 07:36 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Not many lifter manufacturers now. My bet is they'e all the same. Hydraulic and solid are different heights. But I'll bet all solids are the same. If your worried why not just get your lifters from Comp? Then you'll match what you have.
Doug
Re: mp solid lifter seat height vs comp cams solid lifter seat h [Re: Bob_Coomer] #1978092
12/28/15 08:25 PM
12/28/15 08:25 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Johnson Hy-Lift makes the MP lifters. Stanadyne was used before that,LONG ago,but they stopped making them.I'd be willing to bet Johnson Hy-Lift makes Comp lifters too.
Nautilus Racing-
Re: mp solid lifter seat height vs comp cams solid lifter seat h [Re: Bob_Coomer] #3169488
08/21/23 05:46 PM
08/21/23 05:46 PM
neche, ND
526 Offline
526  Offline
neche, ND
Hey bob trying t get a hold of u fr a question I will leave it in ur mailbox cool thc
Re: mp solid lifter seat height vs comp cams solid lifter seat h [Re: 526] #3169496
08/21/23 06:04 PM
08/21/23 06:04 PM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
The MP small block solids and the small block comp solids I have are the same in every way.
STOP POTATO HATE!
Re: mp solid lifter seat height vs comp cams solid lifter seat h [Re: Mr PotatoHead] #3169577
08/22/23 02:04 AM
08/22/23 02:04 AM
Mopar lifters, both hydraulic and solids had two different cup heights, 1952 to 1967 had a lower cup height than the 1967 and later lifters have.
OP, how about having your current lifter set bottoms reconditioned by a good cam regrind company? work scope twocents
