Anti roll bar #3164599
07/31/23 04:40 PM
07/31/23 04:40 PM
bonney lake washington
W
w2stroker Offline OP
W
Looking for recommendations on an anti roll bar. Trying to find good balance between quality and price. Not afraid to spend if that's what it takes. It is a full tube chromoly chassis
Re: Anti roll bar [Re: w2stroker] #3164600
07/31/23 04:44 PM
07/31/23 04:44 PM
W
W
Alot of separation on drivers side
Re: Anti roll bar [Re: w2stroker] #3164648
07/31/23 06:55 PM
07/31/23 06:55 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I use Chassis engineering, the heavy duty one.
Re: Anti roll bar [Re: FastmOp] #3164681
07/31/23 08:40 PM
07/31/23 08:40 PM
gregsdart Offline
gregsdart  Offline
Torquedlite? Try raising your instant center and compensating with a stiffer shock setting. It might get you to acceptable twist without spending $$.. if the suspension is right on the neutral line, it can cause twist like you have. Getting away from the neutral line will help . Only testing will reveal if it is enough to suit you.
Re: Anti roll bar [Re: gregsdart] #3164684
07/31/23 08:48 PM
07/31/23 08:48 PM
Connellsville
71Demon528 Offline
71Demon528  Offline
Connellsville
RJ Race cars (Quarter max) is what I run. It is the cheapest I found and good quality. I have played with my 4 link for a long time and no matter what adjustments I made, the body roll was present. We put the anti roll bar on, and it made a WORLD of difference. Car leaves so much nicer with the anti roll bar. Once you get one on, you will be very pleased. A lot of people say if you're running a 4 link, you need to be running an anti-roll bar.
Re: Anti roll bar [Re: 71Demon528] #3164731
08/01/23 02:08 AM
08/01/23 02:08 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I bought the small one for a Daytona chassis car. It worked. But the big ones are much sexier. Buy the biggest one that you can afford. The big ones are unbelievably expensive.
2011 Drag Pak Challenger
Re: Anti roll bar [Re: rickseeman] #3164738
08/01/23 05:59 AM
08/01/23 05:59 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I agree. I've installed a few chassis engineering ARB's in friends cars, and run one in my Road Runner.
IMO, every race car should run a ARB. Makes a big difference, even on ladder bar cars.
69 GTX 68 Road Runner
Re: Anti roll bar [Re: JERICOGTX] #3164755
08/01/23 08:26 AM
08/01/23 08:26 AM
PA
moparacer Offline
moparacer  Offline
PA
I put this one on my old Duster eons ago and have had one on my Dart for the last 10 years or so.
https://quartermax.com/quarter-max-anti-roll-bar-kit/
Its cheap and easy but I might go a step further and get the Pro series if the car is quick enough. It has a beefier bar for less flex.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Anti roll bar [Re: moparacer] #3164757
08/01/23 08:40 AM
08/01/23 08:40 AM
Connellsville
71Demon528 Offline
71Demon528  Offline
Connellsville
Yep, this is the same one I got. Works great.
Re: Anti roll bar [Re: 71Demon528] #3164766
08/01/23 09:09 AM
08/01/23 09:09 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
The ONLY thing I'm not a fan of with that ARB, is the Teflon bushings. I prefer the bronze bushings the Chassis Engineering ARB comes with. Both work, just a preference.
Re: Anti roll bar [Re: JERICOGTX] #3164830
08/01/23 01:18 PM
08/01/23 01:18 PM
W
W
certainly appreciate the input up
i was looking at this kit from Tim Mcamis https://timmcamis.com/product/rear-sway-bar-kit-unwelded/.
it is needle bearing rather than teflon bushing.
the car is a torqueflite. we have adjusted the 4 link as much as we can and played with shocks a bunch, we put limiters on the front.
our next move was going to be to add weight up front, but i want to flatten it out before i do. the difficulty i think is the motor sits 12 inches back from stock making for a very light front end smile
Re: Anti roll bar [Re: w2stroker] #3164831
08/01/23 01:25 PM
08/01/23 01:25 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
RJ Racecars who we use for almost everything. Just put one my Dakota
Re: Anti roll bar [Re: JERICOGTX] #3164883
08/01/23 04:04 PM
08/01/23 04:04 PM
PA
moparacer Offline
moparacer  Offline
PA
I pull mine off every couple years and clean and put a slight amount of grease on them. Never had any problems.
Re: Anti roll bar [Re: moparacer] #3164884
08/01/23 04:08 PM
08/01/23 04:08 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Tin Soldiers makes a nice one as well.
'63 Dodge 330
11.19 @ 121 mph
Re: Anti roll bar [Re: GY3] #3164916
08/01/23 06:36 PM
08/01/23 06:36 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
What an anti-rollbar.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Anti roll bar [Re: pittsburghracer] #3165226
08/03/23 12:07 AM
08/03/23 12:07 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I run a home made Pro Stock style 4130 chromoly A.R.B. with oil lite bronze bushings and greasable zerk fittings. (Pics added, during the rear end mock up stage).
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Anti roll bar [Re: w2stroker] #3165268
08/03/23 09:57 AM
08/03/23 09:57 AM
New York
polyspheric Offline
polyspheric  Offline
New York
When choosing diameter, even 1/8" is a huge difference
Boffin Emeritus
Re: Anti roll bar [Re: polyspheric] #3167855
08/14/23 01:53 PM
08/14/23 01:53 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Looking at the photos, I see a big difference in chassis geometry between them.
4 link? 3 speed trans? Good DA shock? Big power, light car, SLR in the 10-12:1 range can be a challenge.
AR bars are a good idea on most cars with power. Some folks will even use them for tuning touch ups rather than the chassis links.
If you need one, put a good one on it, or you just be twisting it up.
Re: Anti roll bar [Re: pittsburghracer] #3167869
08/14/23 02:45 PM
08/14/23 02:45 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Originally Posted by pittsburghracer
What is an anti-rollbar.
It's a passive mechanical device that when one wheel on an axle is loaded enough to compress that side's suspension (coil, leaf, air bag). it directly, less any compressibility of the sway bar, "lifts" the other tire and compresses the other side's suspension. the end result is a flatter chassis under unequal load, it does NOT contrary to many, equalize carried weight.[i][/i]
