Re: Anti roll bar
[Re: FastmOp]
#3164681
07/31/23 08:40 PM
07/31/23 08:40 PM
Posts: 10,036 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Torquedlite? Try raising your instant center and compensating with a stiffer shock setting. It might get you to acceptable twist without spending $$.. if the suspension is right on the neutral line, it can cause twist like you have. Getting away from the neutral line will help . Only testing will reveal if it is enough to suit you.
Re: Anti roll bar
[Re: 71Demon528]
#3164731
08/01/23 02:08 AM
08/01/23 02:08 AM
Posts: 2,692 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I bought the small one for a Daytona chassis car. It worked. But the big ones are much sexier. Buy the biggest one that you can afford. The big ones are unbelievably expensive.
2011 Drag Pak Challenger
Re: Anti roll bar
[Re: rickseeman]
#3164738
08/01/23 05:59 AM
08/01/23 05:59 AM
Posts: 10,050 MN
JERICOGTX
MN
I bought the small one for a Daytona chassis car. It worked. But the big ones are much sexier. Buy the biggest one that you can afford. The big ones are unbelievably expensive. I agree. I've installed a few chassis engineering ARB's in friends cars, and run one in my Road Runner. IMO, every race car should run a ARB. Makes a big difference, even on ladder bar cars.
69 GTX
68 Road Runner
Re: Anti roll bar
[Re: JERICOGTX]
#3164755
08/01/23 08:26 AM
08/01/23 08:26 AM
Posts: 2,530 PA
moparacer
PA
I put this one on my old Duster eons ago and have had one on my Dart for the last 10 years or so. https://quartermax.com/quarter-max-anti-roll-bar-kit/Its cheap and easy but I might go a step further and get the Pro series if the car is quick enough. It has a beefier bar for less flex.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
Re: Anti roll bar
[Re: 71Demon528]
#3164766
08/01/23 09:09 AM
08/01/23 09:09 AM
Posts: 10,050 MN
JERICOGTX
MN
I put this one on my old Duster eons ago and have had one on my Dart for the last 10 years or so. https://quartermax.com/quarter-max-anti-roll-bar-kit/Its cheap and easy but I might go a step further and get the Pro series if the car is quick enough. It has a beefier bar for less flex. Yep, this is the same one I got. Works great. The ONLY thing I'm not a fan of with that ARB, is the Teflon bushings. I prefer the bronze bushings the Chassis Engineering ARB comes with. Both work, just a preference.
69 GTX
68 Road Runner
Re: Anti roll bar
[Re: JERICOGTX]
#3164830
08/01/23 01:18 PM
08/01/23 01:18 PM
Posts: 251 bonney lake washington
w2stroker
certainly appreciate the input i was looking at this kit from Tim Mcamis https://timmcamis.com/product/rear-sway-bar-kit-unwelded/. it is needle bearing rather than teflon bushing. the car is a torqueflite. we have adjusted the 4 link as much as we can and played with shocks a bunch, we put limiters on the front. our next move was going to be to add weight up front, but i want to flatten it out before i do. the difficulty i think is the motor sits 12 inches back from stock making for a very light front end ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif)
Re: Anti roll bar
[Re: w2stroker]
#3164831
08/01/23 01:25 PM
08/01/23 01:25 PM
Posts: 19,400 Las Vegas
Al_Alguire
Las Vegas
RJ Racecars who we use for almost everything. Just put one my Dakota
Re: Anti roll bar
[Re: JERICOGTX]
#3164883
08/01/23 04:04 PM
08/01/23 04:04 PM
Posts: 2,530 PA
moparacer
PA
I put this one on my old Duster eons ago and have had one on my Dart for the last 10 years or so. https://quartermax.com/quarter-max-anti-roll-bar-kit/Its cheap and easy but I might go a step further and get the Pro series if the car is quick enough. It has a beefier bar for less flex. Yep, this is the same one I got. Works great. The ONLY thing I'm not a fan of with that ARB, is the Teflon bushings. I prefer the bronze bushings the Chassis Engineering ARB comes with. Both work, just a preference. I pull mine off every couple years and clean and put a slight amount of grease on them. Never had any problems.
Re: Anti roll bar
[Re: moparacer]
#3164884
08/01/23 04:08 PM
08/01/23 04:08 PM
Posts: 4,715 Wichita
GY3
Wichita
Tin Soldiers makes a nice one as well.
Re: Anti roll bar
[Re: pittsburghracer]
#3165226
08/03/23 12:07 AM
08/03/23 12:07 AM
Posts: 4,593 Motor City
6PKRTSE
Motor City
I run a home made Pro Stock style 4130 chromoly A.R.B. with oil lite bronze bushings and greasable zerk fittings. (Pics added, during the rear end mock up stage).
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
Re: Anti roll bar
[Re: w2stroker]
#3165268
08/03/23 09:57 AM
08/03/23 09:57 AM
Posts: 4,213 New York
polyspheric
New York
When choosing diameter, even 1/8" is a huge difference
Boffin Emeritus
Re: Anti roll bar
[Re: polyspheric]
#3167855
08/14/23 01:53 PM
08/14/23 01:53 PM
Posts: 11,795 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Looking at the photos, I see a big difference in chassis geometry between them.
4 link? 3 speed trans? Good DA shock? Big power, light car, SLR in the 10-12:1 range can be a challenge.
AR bars are a good idea on most cars with power. Some folks will even use them for tuning touch ups rather than the chassis links.
If you need one, put a good one on it, or you just be twisting it up.
Re: Anti roll bar
#3167869
08/14/23 02:45 PM
08/14/23 02:45 PM
Posts: 22,790 Bitopia
jcc
Bitopia
It's a passive mechanical device that when one wheel on an axle is loaded enough to compress that side's suspension (coil, leaf, air bag). it directly, less any compressibility of the sway bar, "lifts" the other tire and compresses the other side's suspension. the end result is a flatter chassis under unequal load, it does NOT contrary to many, equalize carried weight.[i][/i]
