Re: Anyone ever use a back in the day Mark Ten CDI ignition?
[Re: A12]
#3163672
07/27/23 03:21 PM
07/27/23 03:21 PM
Posts: 15,754 Jefferson State
srt
ESYC
ESYC
Jefferson State
yes. It worked great with a mallory dual point. Then the thing quit working on a hot day when the smoke leaked out. It seemed to provide good spark throughout the entire rpm range even up to and beyond 7k rpm. I bookmarked this page as I believe the plug gap or ballast played into the failure. Mark 10 Instructions
[Re: TJP]
#3163832
07/28/23 10:18 AM
07/28/23 10:18 AM
Posts: 4,674 Wichita
GY3
Wichita
It most likely will not give you more power if your tune-up is on point.
Every car I get gets a CD ignition in the form of an analog MSD 6AL.
Starts easier, idles better, has rev limiting and allows add-ons like 2 step and timing retard.
I've been 10.0's at 133mph with nothing more than this box and a stock OEM electronic distributor in a 3,800 lbs car. No problems with spark whatsoever.
[Re: Moparite]
#3164142
07/29/23 04:15 PM
07/29/23 04:15 PM
Posts: 21,508 N.E. OHIO, USA
A12
N.E. OHIO, USA
If you are still in the stone age using a duel point anything is an upgrade. But why use "back in the day" technology when there is so much out there today that is leaps and bound better. Ah because I have it and will cost me $0 and it's fun and kind of like old tube audio equipment, vinyl records, and turntables, If I wanted all of that "upgrade" I'd buy a modern muscle car. Just playing with back in the day stuff and no I'm not going with fuel injection either at this point. Besides I like the challenge of setting dual points, well that's a little stretch
[Re: TJP]
#3164235
07/30/23 09:02 AM
07/30/23 09:02 AM
Posts: 6,250 nowhere
Sniper
nowhere
Finding any good points that aren't NOS is beginning to be tedious. Correct But the MARK 10 box will make them last a LONG time The NOS ones, yes, the stuff they are selling new today, no, the rubbing blocks wear out quick. In the case of my 51 Plymouth the solution is to convert the distributor over to electronic ignition using a /6 distributor and swapping in some of the original internals to mate it up to the oil pump tang.
[Re: Sniper]
#3164262
07/30/23 11:31 AM
07/30/23 11:31 AM
Posts: 4,769 Holland MI Ottawa
2boltmain
Holland MI Ottawa
In the current aftermarket who makes a truly stone cold reliable High quality ignition system for the old cars nowadays? The names still exist- MSD, Accell, Mallory etc. but the quality has been atrocious for years now. I watched a clip showing the Pertronics conversion kit uses fragile wire that does not last. Pertronix has been a legend in the hobby offering affordable solid state easy to perform conversion from points.
Keep old mopars alive.
[Re: 2boltmain]
#3164270
07/30/23 12:12 PM
07/30/23 12:12 PM
Posts: 984 rust belt
Moparite
rust belt
Ah because I have it and will cost me $0 and it's fun and kind of like old tube audio equipment, vinyl records, and turntables, So you still listen to music on 8 tracks?
[Re: Sniper]
#3164272
07/30/23 12:15 PM
07/30/23 12:15 PM
Posts: 15,358 Omaha Ne
TJP
Omaha Ne
Finding any good points that aren't NOS is beginning to be tedious. Correct But the MARK 10 box will make them last a LONG time The NOS ones, yes, the stuff they are selling new today, no, the rubbing blocks wear out quick. In the case of my 51 Plymouth the solution is to convert the distributor over to electronic ignition using a /6 distributor and swapping in some of the original internals to mate it up to the oil pump tang. You're not suppose to drive them, except for on and off the trailer LOL
[Re: 2boltmain]
#3164283
07/30/23 12:59 PM
07/30/23 12:59 PM
Sniper
nowhere
In the current aftermarket who makes a truly stone cold reliable High quality ignition system for the old cars nowadays? The names still exist- MSD, Accell, Mallory etc. but the quality has been atrocious for years now. I watched a clip showing the Pertronics conversion kit uses fragile wire that does not last. Pertronix has been a legend in the hobby offering affordable solid state easy to perform conversion from points. Pertronix might have had a good rep, till they sold out and the new owners cheaped out. Standard makes a kit, similar to Pertronix, to convert dual point distributors, actually they make kits for most of our points distributors.
[Re: Moparite]
#3164298
07/30/23 02:00 PM
07/30/23 02:00 PM
A12
N.E. OHIO, USA
Ah because I have it and will cost me $0 and it's fun and kind of like old tube audio equipment, vinyl records, and turntables, So you still listen to music on 8 tracks? YEP! My '69 GTX has an OE 8-track player so why wouldn't I ? Back in the summer of '69 I cut the back of my glovebox so I could fit an 8-track player in it so I didn't have to hang it under the dash above the console of my new '69 Road Runner and have my window broken by a thief. Should have seen the look on my girlfriend's face when she first got in and heard what she thought was the OE AM dash radio and dash speakers. If I'm not mistaken wasn't the magnetic tape used in an 8-track cassette the same type (quality) of magnetic tape used with high end reel to reel recorders back in the day?
[Re: Moparite]
#3164455
07/31/23 09:40 AM
07/31/23 09:40 AM
Posts: 75,012 U.S.S.A.
JohnRR
U.S.S.A.
If you are still in the stone age using a duel point anything is an upgrade. But why use "back in the day" technology when there is so much out there today that is leaps and bound better. Back in the stone age I switched between an Direct Connection orange box conversion and an Accel Dual point on the 340 I transplanted into my Dad's 72 Duster twister and the BUTT DYNO said the dual point was better than the orange box ... YMMV ...
[Re: A12]
#3164689
07/31/23 09:08 PM
07/31/23 09:08 PM
Posts: 3,488 Annapolis, MD, USA
Vert
Annapolis, MD, USA
I had a Edelbrock CD ignition back in the 70's. It would fire pugs gapped at .060 easily, fire thru fouled plugs, etc. It fired multi-spark but with shorter duration, so instead of ZP for each plug in sequence, it was [ZAP,ZAP,ZAP,ZAP...]. It made difference on my 383 Charger, and again when I swapped in the 440/4spd.
[Re: JohnRR]
#3164695
07/31/23 09:35 PM
07/31/23 09:35 PM
TJP
Omaha Ne
If you are still in the stone age using a duel point anything is an upgrade. But why use "back in the day" technology when there is so much out there today that is leaps and bound better. Back in the stone age I switched between an Direct Connection orange box conversion and an Accel Dual point on the 340 I transplanted into my Dad's 72 Duster twister and the BUTT DYNO said the dual point was better than the orange box ... YMMV ... My experience was the opposite definite difference with the electronic upgrade. I resisted my mentors advice as my dual point seemed fine. But once done i was a believer. he never said I told you so
