Anyone ever use a back in the day Mark Ten CDI ignition? #3163659
07/27/23 02:24 PM
07/27/23 02:24 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
Had one on my '69 Road Runner back in the day in 1969 and at that time it really seemed to work and improve performance. Don't know for sure but I think the Delta Mark Ten tech was the predecessor to the MSD (Multi Spark Discharge) ignition technology?? Anyway I found an NOS Delta Mark Ten "B" (B meaning you can deactivate it if desired) and wondering if it would work with a Mopar electronic ignition system? I think before I change the GTX's OE dual point system to the Mopar electronic system I'm going to "seat of the pants" see what happens and see if I can tell any difference as I did back in the day?
Re: Anyone ever use a back in the day Mark Ten CDI ignition? [Re: A12] #3163667
07/27/23 02:41 PM
07/27/23 02:41 PM
moparx Offline
moparx  Offline
will be interesting to see what happens, as will be proven by the "butt dyno". up
beer
Re: Anyone ever use a back in the day Mark Ten CDI ignition? [Re: A12] #3163672
07/27/23 03:21 PM
07/27/23 03:21 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
yes. It worked great with a mallory dual point.
Then the thing quit working on a hot day when the smoke leaked out.
It seemed to provide good spark throughout the entire rpm range even up to and beyond 7k rpm.
I bookmarked this page as I believe the plug gap or ballast played into the failure.
Mark 10 Instructions
Re: Anyone ever use a back in the day Mark Ten CDI ignition? [Re: srt] #3163673
07/27/23 03:25 PM
07/27/23 03:25 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
Re: Anyone ever use a back in the day Mark Ten CDI ignition? [Re: A12] #3163758
07/27/23 09:56 PM
07/27/23 09:56 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
A predecessor to electronic ignition. They basically took the current load off the points which in turn made them last a lot longer. Doing so improved the stability of the spark. Think of it as a relay that was designed to handle the current without deteriorating.
Re: Anyone ever use a back in the day Mark Ten CDI ignition? [Re: TJP] #3163832
07/28/23 10:18 AM
07/28/23 10:18 AM
Wichita
GY3 Online content
GY3  Online Content
Wichita
It most likely will not give you more power if your tune-up is on point.
Every car I get gets a CD ignition in the form of an analog MSD 6AL.
Starts easier, idles better, has rev limiting and allows add-ons like 2 step and timing retard.
I've been 10.0's at 133mph with nothing more than this box and a stock OEM electronic distributor in a 3,800 lbs car. No problems with spark whatsoever.
'63 Dodge 330
11.19 @ 121 mph
Re: Anyone ever use a back in the day Mark Ten CDI ignition? [Re: GY3] #3164059
07/29/23 10:06 AM
07/29/23 10:06 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
If you are still in the stone age using a duel point anything is an upgrade. But why use "back in the day" technology when there is so much out there today that is leaps and bound better.
Re: Anyone ever use a back in the day Mark Ten CDI ignition? [Re: Moparite] #3164142
07/29/23 04:15 PM
07/29/23 04:15 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
Ah because I have it and will cost me $0 and it's fun and kind of like old tube audio equipment, vinyl records, and turntables, If I wanted all of that "upgrade" I'd buy a modern muscle car. Just playing with back in the day stuff and no I'm not going with fuel injection either at this point. grin wink Besides I like the challenge of setting dual points, well that's a little stretch wink
Re: Anyone ever use a back in the day Mark Ten CDI ignition? [Re: A12] #3164143
07/29/23 04:31 PM
07/29/23 04:31 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Finding any good points that aren't NOS is beginning to be tedious.
Re: Anyone ever use a back in the day Mark Ten CDI ignition? [Re: A12] #3164198
07/29/23 10:30 PM
07/29/23 10:30 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Re: Anyone ever use a back in the day Mark Ten CDI ignition? [Re: Sniper] #3164199
07/29/23 10:31 PM
07/29/23 10:31 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Correct wink But the MARK 10 box will make them last a LONG time wink
Re: Anyone ever use a back in the day Mark Ten CDI ignition? [Re: TJP] #3164235
07/30/23 09:02 AM
07/30/23 09:02 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
The NOS ones, yes, the stuff they are selling new today, no, the rubbing blocks wear out quick. down
In the case of my 51 Plymouth the solution is to convert the distributor over to electronic ignition using a /6 distributor and swapping in some of the original internals to mate it up to the oil pump tang.
Re: Anyone ever use a back in the day Mark Ten CDI ignition? [Re: Sniper] #3164262
07/30/23 11:31 AM
07/30/23 11:31 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
In the current aftermarket who makes a truly stone cold reliable High quality ignition system for the old cars nowadays? The names still exist- MSD, Accell, Mallory etc. but the quality has been atrocious for years now. I watched a clip showing the Pertronics conversion kit uses fragile wire that does not last. Pertronix has been a legend in the hobby offering affordable solid state easy to perform conversion from points.
Keep old mopars alive.
Re: Anyone ever use a back in the day Mark Ten CDI ignition? [Re: 2boltmain] #3164270
07/30/23 12:12 PM
07/30/23 12:12 PM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Quote
So you still listen to music on 8 tracks?
Re: Anyone ever use a back in the day Mark Ten CDI ignition? [Re: Sniper] #3164272
07/30/23 12:15 PM
07/30/23 12:15 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
You're not suppose to drive them, except for on and off the trailer LOL beer
Re: Anyone ever use a back in the day Mark Ten CDI ignition? [Re: 2boltmain] #3164283
07/30/23 12:59 PM
07/30/23 12:59 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Pertronix might have had a good rep, till they sold out and the new owners cheaped out.
Standard makes a kit, similar to Pertronix, to convert dual point distributors, actually they make kits for most of our points distributors.
Re: Anyone ever use a back in the day Mark Ten CDI ignition? [Re: Moparite] #3164298
07/30/23 02:00 PM
07/30/23 02:00 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
Quote
YEP! My '69 GTX has an OE 8-track player so why wouldn't I ? shruggy tonguue tonguue Back in the summer of '69 I cut the back of my glovebox so I could fit an 8-track player in it so I didn't have to hang it under the dash above the console of my new '69 Road Runner and have my window broken by a thief. Should have seen the look on my girlfriend's face when she first got in and heard what she thought was the OE AM dash radio and dash speakers. If I'm not mistaken wasn't the magnetic tape used in an 8-track cassette the same type (quality) of magnetic tape used with high end reel to reel recorders back in the day?
Re: Anyone ever use a back in the day Mark Ten CDI ignition? [Re: Moparite] #3164455
07/31/23 09:40 AM
07/31/23 09:40 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
haha
Back in the stone age I switched between an Direct Connection orange box conversion and an Accel Dual point on the 340 I transplanted into my Dad's 72 Duster twister and the BUTT DYNO said the dual point was better than the orange box ...
YMMV ...
Re: Anyone ever use a back in the day Mark Ten CDI ignition? [Re: A12] #3164689
07/31/23 09:08 PM
07/31/23 09:08 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
I had a Edelbrock CD ignition back in the 70's. It would fire pugs gapped at .060 easily, fire thru fouled plugs, etc. It fired multi-spark but with shorter duration, so instead of ZP for each plug in sequence, it was [ZAP,ZAP,ZAP,ZAP...]. It made difference on my 383 Charger, and again when I swapped in the 440/4spd.
Re: Anyone ever use a back in the day Mark Ten CDI ignition? [Re: JohnRR] #3164695
07/31/23 09:35 PM
07/31/23 09:35 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
haha
YMMV ...
My experience was the opposite definite difference with the electronic upgrade. I resisted my mentors advice as my dual point seemed fine. But once done i was a believer. he never said I told you so up
