Calling all hemi experts #3159153
07/12/23 05:10 PM
07/12/23 05:10 PM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
Came across something I've never seen today, which isn't surprising since I've never had my hands on a 426. Buddy of mine owns a '69 Super Bee (former drag car). He told me the alternator bracket broke, which it did. BUT all my research says that a street hemi uses the same brackets and bolts that a 440 uses. The problem is his heads don't have a boss or bolt hole for the long bolt to go into so somebody fabricated a bracket that finally cracked under the stress. The question is, what heads does he have? Is there an off-the-shelf alternator bracket that will work or are we left fabricating something better?
I asked another friend of mine (George Longacre, for those who know him) and he didn't recognize them at all.
Thanks.
Re: Calling all hemi experts [Re: Jim_Lusk] #3159191
07/12/23 08:30 PM
07/12/23 08:30 PM
N
NITROUSN Offline
NITROUSN  Offline
N
What he has is not correct. Looks like the mount was milled off. I bet that top alternator bolt will line up with that hole on the milled off lug. Need to pull a valve cover and get a head casting number.
Re: Calling all hemi experts [Re: NITROUSN] #3159192
07/12/23 08:35 PM
07/12/23 08:35 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
This ^^
Re: Calling all hemi experts [Re: NITROUSN] #3159194
07/12/23 08:39 PM
07/12/23 08:39 PM
N
NITROUSN Offline
NITROUSN  Offline
N
My bets it was milled off for some sort of dual race distributor.
Re: Calling all hemi experts [Re: NITROUSN] #3159195
07/12/23 08:41 PM
07/12/23 08:41 PM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
Nope. Look closer. that hole is a dimple that is at about a 45 degree angle to the front of the head. Both heads are the same configuration. Nothing was milled.
Re: Calling all hemi experts [Re: NITROUSN] #3159196
07/12/23 08:41 PM
07/12/23 08:41 PM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
Both heads are the same.
Re: Calling all hemi experts [Re: Jim_Lusk] #3159200
07/12/23 08:54 PM
07/12/23 08:54 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Then pull a valve cover and get a casting number. I still say they are milled off on both heads.
Re: Calling all hemi experts [Re: NITROUSN] #3159214
07/12/23 09:56 PM
07/12/23 09:56 PM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
Probably won't bother at this time. No matter what we need to come up with a rear bracket to mount the alternator anyway. Might worry about the casting number if the valve cover ever has to come off, but not until then.
Re: Calling all hemi experts [Re: Jim_Lusk] #3159216
07/12/23 10:15 PM
07/12/23 10:15 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
When I put the hemi in place of a 440 the re was a threaded boss that used to 440 bracketry.
here
s a pic of another install beer
Re: Calling all hemi experts [Re: TJP] #3159219
07/12/23 10:33 PM
07/12/23 10:33 PM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
here
Yeah, that's what I've been seeing, but these heads don't look milled or ground in any way. We'll just make a bracket to bolt on and move it on down the road.
Re: Calling all hemi experts [Re: Jim_Lusk] #3159241
07/13/23 12:25 AM
07/13/23 12:25 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Could it be a K head?
Re: Calling all hemi experts [Re: Jim_Lusk] #3159252
07/13/23 01:34 AM
07/13/23 01:34 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
That dimple you see is all that remains of the threaded hole that was the mounting bolt hole.
They've been machined off on a 45 degree angle and what you see is all that is left of the boss.
Re: Calling all hemi experts [Re: SNK-EYZ] #3159333
07/13/23 08:15 AM
07/13/23 08:15 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Hey thats what I said.
Re: Calling all hemi experts [Re: NITROUSN] #3159394
07/13/23 02:16 PM
07/13/23 02:16 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
And that's why I was trying to show that you were correct since it shows that in your reply in the quote. laugh2
That it was milled off whether the OP wants to believe it or not. whistling
You can see the full boss in these pics....
Re: Calling all hemi experts [Re: SNK-EYZ] #3159395
07/13/23 02:22 PM
07/13/23 02:22 PM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
Well it looks like it could be milled down. He can either build another bracket or sculpture a new mount from epoxy and jb weld.
Re: Calling all hemi experts [Re: SNK-EYZ] #3159396
07/13/23 02:23 PM
07/13/23 02:23 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Probably milled off to clear a special distributor. K heads have the threaded boss. I have K-heads on my Hemi in the road runner
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Calling all hemi experts [Re: RoadRunner] #3159797
07/15/23 05:29 PM
07/15/23 05:29 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
They aren't K heads
2011 Drag Pak Challenger
Re: Calling all hemi experts [Re: RoadRunner] #3159855
07/15/23 10:56 PM
07/15/23 10:56 PM
N.W. Florida
Fat_Mike Online work
Fat_Mike  Online Work
N.W. Florida
He said "both heads" earlier in the post.
Re: Calling all hemi experts [Re: Fat_Mike] #3159872
07/16/23 02:37 AM
07/16/23 02:37 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Yeah, but if they were ever on a race car they would probably do both heads to be able to put them on either side.
Re: Calling all hemi experts [Re: SNK-EYZ] #3159889
07/16/23 09:34 AM
07/16/23 09:34 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Winner
