Re: Calling all hemi experts
[Re: Jim_Lusk]
#3159191
07/12/23 08:30 PM
07/12/23 08:30 PM
Posts: 18,423 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
What he has is not correct. Looks like the mount was milled off. I bet that top alternator bolt will line up with that hole on the milled off lug. Need to pull a valve cover and get a head casting number.
[Re: NITROUSN]
#3159192
07/12/23 08:35 PM
07/12/23 08:35 PM
Posts: 21,441 It's a dry heat
gtx6970
It's a dry heat
What he has is not correct. Looks like the mount was milled off. I bet that top alternator bolt will line up with that hole on the milled off lug. Need to pull a valve cover and get a head casting number. This ^^
[Re: NITROUSN]
#3159195
07/12/23 08:41 PM
07/12/23 08:41 PM
Posts: 18,678 Fresno, CA
Jim_Lusk
Fresno, CA
What he has is not correct. Looks like the mount was milled off. I bet that top alternator bolt will line up with that hole on the milled off lug. Need to pull a valve cover and get a head casting number. Nope. Look closer. that hole is a dimple that is at about a 45 degree angle to the front of the head. Both heads are the same configuration. Nothing was milled.
[Re: NITROUSN]
#3159196
07/12/23 08:41 PM
07/12/23 08:41 PM
Jim_Lusk
Fresno, CA
My bets it was milled off for some sort of dual race distributor. Both heads are the same.
[Re: NITROUSN]
#3159214
07/12/23 09:56 PM
07/12/23 09:56 PM
Jim_Lusk
Fresno, CA
My bets it was milled off for some sort of dual race distributor. Both heads are the same. Then pull a valve cover and get a casting number. I still say they are milled off on both heads. Probably won't bother at this time. No matter what we need to come up with a rear bracket to mount the alternator anyway. Might worry about the casting number if the valve cover ever has to come off, but not until then.
[Re: Jim_Lusk]
#3159216
07/12/23 10:15 PM
07/12/23 10:15 PM
Posts: 15,377 Omaha Ne
TJP
Omaha Ne
When I put the hemi in place of a 440 the re was a threaded boss that used to 440 bracketry. here s a pic of another install
[Re: TJP]
#3159219
07/12/23 10:33 PM
07/12/23 10:33 PM
Jim_Lusk
Fresno, CA
When I put the hemi in place of a 440 the re was a threaded boss that used to 440 bracketry. here s a pic of another install Yeah, that's what I've been seeing, but these heads don't look milled or ground in any way. We'll just make a bracket to bolt on and move it on down the road.
[Re: Jim_Lusk]
#3159252
07/13/23 01:34 AM
07/13/23 01:34 AM
Posts: 10,137 A Red State
SNK-EYZ
A Red State
What he has is not correct. Looks like the mount was milled off. I bet that top alternator bolt will line up with that hole on the milled off lug. Need to pull a valve cover and get a head casting number. Nope. Look closer. that hole is a dimple that is at about a 45 degree angle to the front of the head. Both heads are the same configuration. Nothing was milled. That dimple you see is all that remains of the threaded hole that was the mounting bolt hole. They've been machined off on a 45 degree angle and what you see is all that is left of the boss.
[Re: SNK-EYZ]
#3159333
07/13/23 08:15 AM
07/13/23 08:15 AM
NITROUSN
What he has is not correct. Looks like the mount was milled off. I bet that top alternator bolt will line up with that hole on the milled off lug. Need to pull a valve cover and get a head casting number. Nope. Look closer. that hole is a dimple that is at about a 45 degree angle to the front of the head. Both heads are the same configuration. Nothing was milled. That dimple you see is all that remains of the threaded hole that was the mounting bolt hole. They've been machined off on a 45 degree angle and what you see is all that is left of the boss. Hey thats what I said.
[Re: NITROUSN]
#3159394
07/13/23 02:16 PM
07/13/23 02:16 PM
SNK-EYZ
A Red State
What he has is not correct. Looks like the mount was milled off. I bet that top alternator bolt will line up with that hole on the milled off lug. Need to pull a valve cover and get a head casting number. Nope. Look closer. that hole is a dimple that is at about a 45 degree angle to the front of the head. Both heads are the same configuration. Nothing was milled. That dimple you see is all that remains of the threaded hole that was the mounting bolt hole. They've been machined off on a 45 degree angle and what you see is all that is left of the boss. Hey thats what I said. And that's why I was trying to show that you were correct since it shows that in your reply in the quote. That it was milled off whether the OP wants to believe it or not. You can see the full boss in these pics....
[Re: SNK-EYZ]
#3159396
07/13/23 02:23 PM
07/13/23 02:23 PM
Posts: 5,138 East Aurora (Buffalo) NY
RoadRunner
What he has is not correct. Looks like the mount was milled off. I bet that top alternator bolt will line up with that hole on the milled off lug. Need to pull a valve cover and get a head casting number. Nope. Look closer. that hole is a dimple that is at about a 45 degree angle to the front of the head. Both heads are the same configuration. Nothing was milled. That dimple you see is all that remains of the threaded hole that was the mounting bolt hole. They've been machined off on a 45 degree angle and what you see is all that is left of the boss. Probably milled off to clear a special distributor. K heads have the threaded boss. I have K-heads on my Hemi in the road runner
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: RoadRunner]
#3159855
07/15/23 10:56 PM
07/15/23 10:56 PM
Posts: 3,068 N.W. Florida
Fat_Mike
N.W. Florida
Probably milled off to clear a special distributor. K heads have the threaded boss. I have K-heads on my Hemi in the road runner He said "both heads" earlier in the post.
[Re: Fat_Mike]
#3159872
07/16/23 02:37 AM
07/16/23 02:37 AM
SNK-EYZ
A Red State
Probably milled off to clear a special distributor. K heads have the threaded boss. I have K-heads on my Hemi in the road runner He said "both heads" earlier in the post. Yeah, but if they were ever on a race car they would probably do both heads to be able to put them on either side.
[Re: SNK-EYZ]
#3159889
07/16/23 09:34 AM
07/16/23 09:34 AM
Posts: 8,273 fredericksburg,va
cudaman1969
fredericksburg,va
Probably milled off to clear a special distributor. K heads have the threaded boss. I have K-heads on my Hemi in the road runner He said "both heads" earlier in the post. Yeah, but if they were ever on a race car they would probably do both heads to be able to put them on either side. Winner
