Low deck BB
#3151551
06/14/23 04:37 PM
06/14/23 04:37 PM
Posts: 2,885 Pattison Texas
CSK
Pattison Texas
is anyone making a BBM low deck block. ?
Re: Low deck BB
[Re: racerx]
#3151654
06/14/23 09:54 PM
06/14/23 09:54 PM
Posts: 6,151 Melbourne , Australia
LA360
I know that you could get a low deck Bulldog block. No idea if Jason Line is intending on doing them though, now that he's taken it over the Bulldog blocks.
Alan Jones
Re: Low deck BB
[Re: racerx]
#3151710
06/15/23 08:06 AM
06/15/23 08:06 AM
Posts: 4,105 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
I have a low-deck Bulldog that Barton machined and it checks good according to him.
Re: Low deck BB
[Re: CSK]
#3151723
06/15/23 10:08 AM
06/15/23 10:08 AM
Posts: 4,213 New York
polyspheric
New York
Just curious: all reports of AM blocks say 100 lbs. (+/-) heavier than stock. How do you know where that metal is, viz. is it useful for strength, or just a way of reducing machining costs?
Boffin Emeritus
Re: Low deck BB
[Re: HardcoreB]
#3151725
06/15/23 10:22 AM
06/15/23 10:22 AM
CSK
Pattison Texas
I have a low-deck Bulldog that Barton machined and it checks good according to him. I looked on his website and he does not sell them, where did you get yours ?
Re: Low deck BB
[Re: CSK]
#3151756
06/15/23 12:52 PM
06/15/23 12:52 PM
Posts: 19,403 Las Vegas
Al_Alguire
Las Vegas
I have an Indy low deck in my 64....
Re: Low deck BB
[Re: CSK]
#3151807
06/15/23 03:25 PM
06/15/23 03:25 PM
Posts: 31,117 Oregon
AndyF
is anyone making a BBM low deck block. ? They have been made from time to time by various folks but have never been super popular. I'm not aware of any low deck blocks that are currently available. I did just receive a flyer from Bill Mitchel the other day saying they had Mopar blocks in stock.
Re: Low deck BB
[Re: AndyF]
#3151814
06/15/23 03:51 PM
06/15/23 03:51 PM
Al_Alguire
Las Vegas
FWIW this is my third low deck aftermarket deal. The other two were both KB's, one a 525 the other a 572. Pretty sure Indy is still doing them
Re: Low deck BB
[Re: Al_Alguire]
#3151824
06/15/23 04:30 PM
06/15/23 04:30 PM
CSK
Pattison Texas
Thanks guys, KB said no, so far Indy is it, almost 10k with all the options I need. VERY disheartening.
Re: Low deck BB
[Re: CSK]
#3151864
06/15/23 07:46 PM
06/15/23 07:46 PM
Posts: 8,192 Plymouth, MI
Blusmbl
Plymouth, MI
For BB’s, the block seems to be the only real place where we have to pay the Mopar tax. There isn’t a $3500 solution for the 800-1000 hp guys like the basic GM block offerings, that cost half the price of a Callies or Bill Mitchell block. It’s either use a stock block, keep the tune safe and risk it, or spend $7k or better for a serious race block.
Re: Low deck BB
[Re: Blusmbl]
#3151872
06/15/23 08:09 PM
06/15/23 08:09 PM
Al_Alguire
Las Vegas
For BB’s, the block seems to be the only real place where we have to pay the Mopar tax. There isn’t a $3500 solution for the 800-1000 hp guys like the basic GM block offerings, that cost half the price of a Callies or Bill Mitchell block. It’s either use a stock block, keep the tune safe and risk it, or spend $7k or better for a serious race block. An aluminum BBC is just as expensive as an aluminum Mopar block if not more. A dart block lists for $9700 and the Brodix block starts at $6300 but most would opt for the $8000 Brodix block as a starting point. Now comparing a Mopar steel block to a BBC there is about a $3k difference you can get a Dart Big M for about $3500 but no options and most order additional options when buying one. Last one I got in was $5700 with a few changes, .904" lifters and 55MM cam.
Re: Low deck BB
[Re: Al_Alguire]
#3151884
06/15/23 08:47 PM
06/15/23 08:47 PM
Blusmbl
Plymouth, MI
An aluminum BBC is just as expensive as an aluminum Mopar block if not more. A dart block lists for $9700 and the Brodix block starts at $6300 but most would opt for the $8000 Brodix block as a starting point. Now comparing a Mopar steel block to a BBC there is about a $3k difference you can get a Dart Big M for about $3500 but no options and most order additional options when buying one. Last one I got in was $5700 with a few changes, .904" lifters and 55MM cam. Agreed- was speaking specifically for cast iron. The difference is for the parts that fall somewhere between stock and the nice high end aluminum blocks. The Dart Big M or the Bow Tie blocks are totally ok for the not all out effort 900-ish hp crowd, which is where the only option is the $6500 Callies block for a Mopar, and isn't available in a low deck at all. I also knew a guy that was making 950-ish on spray for at least 5 years grudge racing with a stock gen VI 454 block, but that isn't any smarter than making similar power with a 440 block!
Re: Low deck BB
[Re: B1MAXX]
#3151962
06/16/23 08:22 AM
06/16/23 08:22 AM
Posts: 4,087 Mo.
racerx
Mo.
I would not be afraid of a serious build in the right 400 block. And which block would you be comfortable with a 230 block?
Re: Low deck BB
[Re: racerx]
#3151980
06/16/23 09:07 AM
06/16/23 09:07 AM
Posts: 2,530 PA
moparacer
PA
I would not be afraid of a serious build in the right 400 block. The problem now is finding a "good" block to start with. Unless you have it sonic checked you have no idea. I had 4, and 3 ended up in the junk pile because they were cracked, or too thin to even bore .030 over. Low deck aftermarket availability was zero when I built my engine however.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
Re: Low deck BB
[Re: racerx]
#3151999
06/16/23 10:44 AM
06/16/23 10:44 AM
Posts: 75,136 A Banana Republic near you.
JohnRR
I would not be afraid of a serious build in the right 400 block. And which block would you be comfortable with a 230 block? That would be a start, I got a 230 block once that was stuck from water in one bank. I was able to get it unstuck and turn over but after sonic checking it was going to need 5 sleeves between core shift and rust pitting to use it at .030 over.
