Low deck BB #3151551
06/14/23 04:37 PM
06/14/23 04:37 PM
Pattison Texas
CSK Online shake_head OP
CSK  Online Shake_Head OP
Pattison Texas
is anyone making a BBM low deck block. ?
Re: Low deck BB [Re: CSK] #3151592
06/14/23 06:19 PM
06/14/23 06:19 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
indy
Without Data, you’re just another guy with an opinion.
Re: Low deck BB [Re: sr4440] #3151645
06/14/23 09:15 PM
06/14/23 09:15 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Indy.......been asking this ? for years. With no luck.
Re: Low deck BB [Re: racerx] #3151654
06/14/23 09:54 PM
06/14/23 09:54 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
I know that you could get a low deck Bulldog block. No idea if Jason Line is intending on doing them though, now that he's taken it over the Bulldog blocks.
Alan Jones
Re: Low deck BB [Re: CSK] #3151656
06/14/23 09:59 PM
06/14/23 09:59 PM
sweden
carter Offline
carter  Offline
sweden
Re: Low deck BB [Re: carter] #3151698
06/15/23 06:17 AM
06/15/23 06:17 AM
Mo.
racerx Offline
racerx  Offline
Mo.
[quote=carter]Bulldog.... shruggy
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2630332/1.html [/quo
4/26/22 03:17 AM
Was the last time anyone committed on that thread, So i would say it isn't looking good? frown
Re: Low deck BB [Re: racerx] #3151710
06/15/23 08:06 AM
06/15/23 08:06 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
I have a low-deck Bulldog that Barton machined and it checks good according to him.
Re: Low deck BB [Re: CSK] #3151723
06/15/23 10:08 AM
06/15/23 10:08 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Just curious: all reports of AM blocks say 100 lbs. (+/-) heavier than stock.
How do you know where that metal is, viz. is it useful for strength, or just a way of reducing machining costs?
Boffin Emeritus
Re: Low deck BB [Re: HardcoreB] #3151725
06/15/23 10:22 AM
06/15/23 10:22 AM
Pattison Texas
Pattison Texas
I looked on his website and he does not sell them, where did you get yours ?
Re: Low deck BB [Re: CSK] #3151756
06/15/23 12:52 PM
06/15/23 12:52 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have an Indy low deck in my 64....
Re: Low deck BB [Re: CSK] #3151807
06/15/23 03:25 PM
06/15/23 03:25 PM
AndyF Offline
AndyF  Offline
They have been made from time to time by various folks but have never been super popular. I'm not aware of any low deck blocks that are currently available. I did just receive a flyer from Bill Mitchel the other day saying they had Mopar blocks in stock.
Re: Low deck BB [Re: AndyF] #3151814
06/15/23 03:51 PM
06/15/23 03:51 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FWIW this is my third low deck aftermarket deal. The other two were both KB's, one a 525 the other a 572. Pretty sure Indy is still doing them
Re: Low deck BB [Re: Al_Alguire] #3151824
06/15/23 04:30 PM
06/15/23 04:30 PM
Pattison Texas
Pattison Texas
Thanks guys, KB said no, so far Indy is it, almost 10k with all the options I need. VERY disheartening.
Re: Low deck BB [Re: CSK] #3151864
06/15/23 07:46 PM
06/15/23 07:46 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
For BB’s, the block seems to be the only real place where we have to pay the Mopar tax. There isn’t a $3500 solution for the 800-1000 hp guys like the basic GM block offerings, that cost half the price of a Callies or Bill Mitchell block. It’s either use a stock block, keep the tune safe and risk it, or spend $7k or better for a serious race block.
Re: Low deck BB [Re: Blusmbl] #3151872
06/15/23 08:09 PM
06/15/23 08:09 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
An aluminum BBC is just as expensive as an aluminum Mopar block if not more. A dart block lists for $9700 and the Brodix block starts at $6300 but most would opt for the $8000 Brodix block as a starting point. Now comparing a Mopar steel block to a BBC there is about a $3k difference you can get a Dart Big M for about $3500 but no options and most order additional options when buying one. Last one I got in was $5700 with a few changes, .904" lifters and 55MM cam.
Re: Low deck BB [Re: Al_Alguire] #3151884
06/15/23 08:47 PM
06/15/23 08:47 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Agreed- was speaking specifically for cast iron. The difference is for the parts that fall somewhere between stock and the nice high end aluminum blocks. The Dart Big M or the Bow Tie blocks are totally ok for the not all out effort 900-ish hp crowd, which is where the only option is the $6500 Callies block for a Mopar, and isn't available in a low deck at all.
I also knew a guy that was making 950-ish on spray for at least 5 years grudge racing with a stock gen VI 454 block, but that isn't any smarter than making similar power with a 440 block!
Re: Low deck BB [Re: Al_Alguire] #3151960
06/16/23 08:15 AM
06/16/23 08:15 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I would not be afraid of a serious build in the right 400 block.
Re: Low deck BB [Re: B1MAXX] #3151962
06/16/23 08:22 AM
06/16/23 08:22 AM
Mo.
racerx Offline
racerx  Offline
Mo.
And which block would you be comfortable with a 230 block?
Re: Low deck BB [Re: racerx] #3151980
06/16/23 09:07 AM
06/16/23 09:07 AM
PA
moparacer Offline
moparacer  Offline
PA
The problem now is finding a "good" block to start with. Unless you have it sonic checked you have no idea.
I had 4, and 3 ended up in the junk pile because they were cracked, or too thin to even bore .030 over.
Low deck aftermarket availability was zero when I built my engine however.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Low deck BB [Re: racerx] #3151999
06/16/23 10:44 AM
06/16/23 10:44 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That would be a start, I got a 230 block once that was stuck from water in one bank. I was able to get it unstuck and turn over but after sonic checking it was going to need 5 sleeves between core shift and rust pitting to use it at .030 over.
