Re: 727 Trans Expert Needed [Re: dvw] #3147458
05/29/23 04:21 PM
05/29/23 04:21 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted by dvw
Originally Posted by TJP
Originally Posted by moparx
please pick up the book : Torqueflight A-727, Transmission Handbook [How to rebuild or modify Chrysler's A-727 Torqueflight for all applications] by Carl H. Munroe.
it's a great handbook, and does a step by step TF-2 installation with pictures, starting on page 165.
it also details the rebuild process, as well as anything else you may want to learn about this transmission.
well worth the price.
https://www.amazon.com/Torqueflite-727-Transmission-Handbook-HP1399/dp/1557883998/ref=sr_1_2?
beer
might well be good advice as Trans go's Instructions used to be like walking a drunk duck. Loved the kits, but the instructions should have been written for a Dyson or Shark as they Sucked real well. Maybe they've redone them shruggy
I've found Trans Go's instructions very easy. Their tech line is great as well.
Doug
It's been quite a few years since I did one, so possibly they have rewritten them. They use to jump all over the place. Start with the valve body, go to the case cup restrictor, back to the valve body, modify the plate, lets do the check balls, Oops, now let's drill one of the channels, back to scratching you backside, WHERE WERE WE ? Oh yeah set the line pressure, back to drilling.
probably not quite that bad but close LOL beer
Re: 727 Trans Expert Needed [Re: TJP] #3148544
06/04/23 08:45 AM
06/04/23 08:45 AM
NW New Jersey
RSI700VIPER Offline OP
NW New Jersey
Update! So I got my Trans-Go kit, dropped and split the valve body. Everything looks as expected in the kit instructions and the factory service manual. HOWEVER, while removing the Regulator Valve End Plate, the throttle pressure plug, valve and sleeve came flying out and shot across the work bench. According to Trans-Go and the FSM, there should not be a spring in this port but there clearly was one in there. My FSM is for a 1970 and the trans is a 1978 from a Ram Charger. Should I put the spring back in when reassembling?
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5
1969 Daytona Charger 440 4-Speed, Dana, EV2
1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7
1970 340 Six Pack Callenger T/A 4-speed T8 Tan
1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth
1969 Talladega Torino, 428CJ
1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
Re: 727 Trans Expert Needed [Re: RSI700VIPER] #3148593
06/04/23 01:24 PM
06/04/23 01:24 PM
moparx Offline
moparx  Offline
i would see what the 78 ramcharger FSM had to say about that spring. shruggy
hopefully, JK will chime in on this discovery.
is that a lock up transmission ?
beer
Re: 727 Trans Expert Needed [Re: RSI700VIPER] #3148636
06/04/23 04:25 PM
06/04/23 04:25 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
That redesigned pressure regulator configuration was new for '78, yes leave the spring in.
Re: 727 Trans Expert Needed [Re: John_Kunkel] #3148759
06/05/23 07:45 AM
06/05/23 07:45 AM
NW New Jersey
NW New Jersey
Okay. Got the VB back together and it's ready to install. Last step is to change the accumulator spring and here is the problem. IT'S impossible! I've searched the internet and apparently I have to remove the tailshaft housing in order to pull the pin that holds the rear servo lever. I read one place where a guy had success prying the band and the lever apart and removing the square strut linkage thing to get at the servo but after trying his technique for an hour, I gave up. Can I just leave the trans kit spring out? I'm setting the trans up for street use only.
Re: 727 Trans Expert Needed [Re: RSI700VIPER] #3148851
06/05/23 12:55 PM
06/05/23 12:55 PM
Rio Linda, CA
Rio Linda, CA
No need to remove the lever pin, just back the adjuster all the way off and pop the link out. A little tricky getting it back in, be sure the link is properly centered when prying it back in. The heavy spring reduces the lag time on a manual 1-2 upshift but, yes, you could omit that step.
Re: 727 Trans Expert Needed [Re: John_Kunkel] #3148956
06/05/23 05:19 PM
06/05/23 05:19 PM
NW New Jersey
NW New Jersey
John,
I clamped the lever down as tight as it would go over the servo. I then reached under the lever and grabbed the edge of the band and pried it back tight against drum. This gave me maximum space to remove the strut. I could jiggle it around easily, but I pried under it and used every sort of pick, reach tool, screw driver, magnet, etc. I could find and it just won't come out. I see that the back side of the lever pin is 90% exposed and held in by a little tab of aluminum hanging off the tail housing. Can't I just cut that tab off, drive the lever pin out just enough to free the lever, perform the spring swap, then fashion a z-bracket and mount off the housing bolt to keep the pin in place?
Re: 727 Trans Expert Needed [Re: RSI700VIPER] #3148964
06/05/23 05:40 PM
06/05/23 05:40 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Trust me you don’t want to do this again
Earlier I mentioned the servo pin/shaft o-ring
You went this far , why not finish the job and do it correctly
Loosen and remove those six bolts for tail shaft
Support the transmission up front
Remove the transmission mount
Look at your linkage , and remove what’s necessary
All you have to do is rotate the tail shaft so the pin/shaft will clear the tab - I have never had to remove the tail shaft or had issues with the tail shaft gasket itself
You DO NOT have to remove the tail shaft
REPLACE O-RING
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: 727 Trans Expert Needed [Re: bee1971] #3148981
06/05/23 06:57 PM
06/05/23 06:57 PM
NW New Jersey
NW New Jersey
10-4. I'm surprise the gasket will survive. So I don't have to take out the rear shaft snap ring or drive shaft? There is no o-ring in the TF-2 kit. Do you know the size so I can pick one up at NAPA?
Thx.
Re: 727 Trans Expert Needed [Re: RSI700VIPER] #3148992
06/05/23 07:48 PM
06/05/23 07:48 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
No on the snap ring
No on the drive shaft
No on the speedometer cable housing
I had to go with my local transmission shop on the o-ring - I couldn’t find it anywhere locally thru jobbers
They had a used double o-ring shaft for me also
Perfection - Not a drop in weeks
Pan is 100% dry and just using a basic cork/rubber gasket with zero rtv or sealant
Siberian Huskies
Re: 727 Trans Expert Needed [Re: bee1971] #3149091
06/06/23 10:43 AM
06/06/23 10:43 AM
NW New Jersey
NW New Jersey
I ended up supporting the trans in the front, removed the trans mount, linkage, etc. and spun the housing about 5 degrees and got the shaft out as you suggested. Took all of 20 minutes. My shaft has the double 0-rings and they looked in good shape so I just reused them. The servo spring supplied in the TF-2 kit was so stiff that I had to jack off the floor to press the servo in far enough using a socket in order to get the snap ring on. I'm going to install the VB tonight and hopefully I didn't mess anything up and my shift points improve. I'll use the cork gasket suppled in the kit without rtv. I also installed new shaft seals.
Re: 727 Trans Expert Needed [Re: RSI700VIPER] #3151862
06/15/23 07:41 PM
06/15/23 07:41 PM
NW New Jersey
NW New Jersey
Update - So I test drove the car today after installing the TF-2 kit and I'm somewhat disappointed. The WOT 2-3 shift is much improved and occurs about 4500 as apposed to about 3300 but the 1-2 shift is l occurring about 2800 rpms but better than the 2500-2600 rpms I was getting before. Also, the kickdown from 3 to 2 lags and takes about 2-3 seconds to downshift. The 2 to 1 downshift is non existent. I check linkage and throttle lever is all the way back against the stop at WOT. Trans shifts tight with no slippage. Bands adjusted per kit specs. What's next, governor weights? line pressure check? New Trans??
Re: 727 Trans Expert Needed [Re: RSI700VIPER] #3151882
06/15/23 08:36 PM
06/15/23 08:36 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Did you take the governor apart? Did you check the governor seal rings? some governors have a screen to catch debris. Even a low performance governor should shift higher. Unless the throttle pressure linkage isn't correct. I'm asuming you checked the throttle pressure valve and cam along with the shift valves for freedom of movement when you installed the TF 2 kit?
Doug
Re: 727 Trans Expert Needed [Re: RSI700VIPER] #3151996
06/16/23 10:39 AM
06/16/23 10:39 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
2 - 1 downshift should be non existent except for a full stop , downshifting into first moving is a good way to take out the rear sprag with no low band applying, so I believe the kit is working as designed.
Did you check to make sure the throttle valve lever weld underneath was not broken ? What are you using for Throttle vale linkage , stock or aftermarket cable ?
Put a gauge on it and do some checks , do you have a shop manual ?
Re: 727 Trans Expert Needed [Re: JohnRR] #3152169
06/16/23 10:08 PM
06/16/23 10:08 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Not wanting to hijack the thread, but am I understanding that with the TF2 Kit and the part throttle kickdown from 3-2, the ability to kickdown from 3-1 at low speed is eliminated? confused
Re: 727 Trans Expert Needed [Re: dvw] #3152618
06/19/23 08:33 AM
06/19/23 08:33 AM
NW New Jersey
NW New Jersey
Doug
I haven't touched the governor yet. Linkage is adjusted correct with all factory components installed. Pressure valve was adjusted per TF-2 instructions and valved moves in and out freely.
Re: 727 Trans Expert Needed [Re: JohnRR] #3152619
06/19/23 08:38 AM
06/19/23 08:38 AM
NW New Jersey
NW New Jersey
I did check the weld per your previous post. Linkage is bone stock and correct for this application. I'm not sure what would cause the 2-3 shift to vastly improve after installing kit bit the 1-2 shift is still early at WOT. Coming home from a show yesterday, I was going atbout 30 mph up a hill and punched the throttle. Took almost 3 seconds to kick down into second.
Re: 727 Trans Expert Needed [Re: TJP] #3153113
06/20/23 06:11 PM
06/20/23 06:11 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Can't answer that , it's been a long time since I installed one in anything and my play cars are 4 speeds. , but a 3-1 down shift ... panic
